Old 02-22-2007, 04:42 AM   #126
Jaylyons1
Member#: 113884
2013 BRZ
I'm still interested to see if i can feel any difference with the VF-43 turbo. Getting it installed on my 05 STi since my old one crapped out on me.
Jaylyons1 is offline   Reply With Quote
Old 02-22-2007, 03:14 PM   #127
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
You probably won't notice a difference. Let us know.
WRXRallyBlue is offline   Reply With Quote
Old 02-27-2007, 08:42 PM   #128
sutter2k
Member#: 92467
08 STI
bump, blouch added a new turbo.
http://blouchturbo.com/turbos/Subaru...minator_2.5R_/
Subaru WRX/STi Dominator 2.5R "Polka Pickle"Full Ball Bearing Turbocharger
Application: Subaru WRX / STi
Horsepower: 475 HP
Bolt On: Yes
Yes, the name is a bit of a stretch but the performance of the WRX/STi Dominator 2.5R leaves nothing to the imagination! The turbo experts at Blouch Performance have teamed up with Garrett Performance Turbo to bring you cutting edge Garrett GT efficiency and ball bearing response in a bolt-on package for your WRX/STi complete with stainless steel turbo oil feed line and steel oil drain tube and coolant lines.
The WRX/STi Dominator 2.5R features a state-of-the-art Garrett GT compressor design supporting 47 lb/min maximum combined with a race proven GT turbine design in a custom WRX/STi ported turbine housing with enlarged wastegate port to facilitate boost control via internal gate. Adjustable upgrade actuator is standard issue on the "Polka Pickle" and is pre-calibrated to operate at 15 PSI unless otherwise specified (upgrade actuators are available in incremental pressures from 9 PSI to 19 PSI).
No need to rotate the mount for this bad cucumber-the WRX/STi Dominator 2.5R "Polka Pickle" is a complete bolt-on package that utilizes the stock compressor inlet pipe and requires no modification to oil, coolant, intake and exhaust connections for installation.
When you see this cutting edge Subaru bolt-on appear on our competitors' website, just remember where you saw it first-at the home of performance turbocharger innovation-Blouch Performance Turbo!
Waiting for reviews on this thing.
sutter2k is offline   Reply With Quote
Old 03-01-2007, 03:04 AM   #129
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Should be a good green/superzilla competitor.
Old 03-03-2007, 06:55 AM   #130
dollan
Member#: 142320
very well post
dollan is offline   Reply With Quote
Old 03-04-2007, 08:45 PM   #131
JonnyRex04
Member#: 103791
oFor FXTi
OhhhSix B9T
Very nicely done! Keep up the good work!
JonnyRex04 is offline   Reply With Quote
Old 03-05-2007, 11:12 PM   #132
GankerBanker
Member#: 142657
thanks, this thread is very helpful
GankerBanker is offline   Reply With Quote
Old 03-05-2007, 11:34 PM   #133
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Good to hear
Old 03-12-2007, 02:07 PM   #134
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Waiting on info for the Dominator 2.5R!!!
CoolRex is offline   Reply With Quote
Old 03-14-2007, 12:14 AM   #135
Hobbes2.2
Member#: 143350
2000 2.5RS GC6
wow...this will be very helpful later! way to go y'all!
Hobbes2.2 is offline   Reply With Quote
Old 03-20-2007, 02:42 PM   #136
WRXer 4 Life
Member#: 143343
2002 WRX wagon
Thank you for this amazing info. I was just wondering, what is the difference between cfm and lb/min? also, Why if the FP 16G is a smaller turbo and is not ball bearing, capable of just as much or more hp than a SBR GT-10? Which is a ball bearing.
WRXer 4 Life is offline   Reply With Quote
Old 03-20-2007, 05:04 PM   #137
hotrod
Member#: 14141
2002 Impreza WRX
They are both measures of the turbos mass flow of air per time.
One CF/Min is approximately 0.07 lb of air per minute.
This would be under standard conditions. Many turbo compressor maps specify what the temperature and pressure conditions were for the developement of the map.
Garrett uses an inlet temp of about 85 deg F, and a depression of .5 psi below standard atmospheric pressure on their maps, so 85 deg F, and 14.2 psia at the inlet would be the standard conditions for the Garrett compressor maps.
Mitsubishi uses about 20 deg C if I remember correctly and an inlet pressure of 14.5 psi (some of their maps quote other temperatures).
In most cases the differences are not terribly critical and for practical purposes you can just use .07 lb/min ~= 1 CFM and you will be close enough for comparison purposes. It takes about 1.45 CFM of air flow to make 1 hp or approximately 10 hp can be made for each lb/min of air flow.
There are so many variables in turbo comparisons that any two turbos that are within about 10% of each other are essentially equal for the purposes of power output potential, and you should look at other issues like bolt pattern, inlet diameter, spool characteristics etc. to determine which is best for your need.
To do it right you need to get a full compressor map for the turbo compressor and find out the standard conditions for the compressor map and then determine true operating conditions in use (ie inlet air temp and pressure at the inlet) then use the correction formulas to figure out the "corrected air flow".
Larry
hotrod is offline   Reply With Quote
Old 03-21-2007, 01:04 AM   #138
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks, Larry.
Rob
Old 03-24-2007, 04:01 AM   #139
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
BTW guys, I occasionally look back through the thread (because I often read my own thread to do research ) and notice that some information is dated or a link is no longer valid, etc. If you notice this, just let me know and I'll fix it.
Old 03-28-2007, 04:47 PM   #140
n801a
Member#: 85770
06 spec b bye STi
07 rs 04 Metro
I'm going to build my own out of plumbing parts suckers
n801a is offline   Reply With Quote
Old 04-02-2007, 09:03 PM   #141
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by Sharky NRK View Post
also I may be wrong but I think the VF39 doesn't have the P15 housing, I have heard P17 and I think deadbolt said he has seen them with P18s
Gruppe-S says the same thing:
Originally Posted by Gruppe-S View Post
Early 04 STI and some non-OEM production VF39's had the P17 hotside. The majority of VF39's are fitted with the P18 hotside.
Gary
Gruppe-S
What gives...
sponaugle is offline   Reply With Quote
Old 04-03-2007, 03:04 AM   #142
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Gary
Gruppe-S
What gives...
Not a clue.. If you find a conclusive answer, please let me know.
Old 04-03-2007, 03:06 AM   #143
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Originally Posted by TribecaAussie View Post
Does anyone know if I can turbocharge for Tribeca ? Thanks
Turbocharging a Tribeca is possible, I suppose. The cost and effort to do so would be monumental and, in my mind at least, not worth it.
Old 04-08-2007, 12:00 AM   #144
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
the 2nd time im posting in this thread and bragging!!!!!! you will need to update the link in the OP.
as of a few hours ago a new tune is in the car and done on a dynodynamics dyno at KTR performance. mods are the same as before but just to clarify as i did not list all items last time.....
fp green internal gate
hyperflow TMIC
aquamist WI (now 50/50 water/meth)
gt-spec header
pe 850's
ecutek
20.5psi
fujitsubo rma-01
daddys CATTED dp
acpt carbon fiber driveshaft
pump gas
my scanner is dead, ill get the plot up soon
pulls started at 2800rpms
2800rpm 135hp 252tq
3k 190hp 300tq
3200 200hp
3500 252hp 385tq (peak)
5k 360tq
5600 356.9hp(peak)
ted
nhsilversti is offline   Reply With Quote
Old 04-08-2007, 02:09 PM   #145
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Ok, I fixed it. Stop harassing me
Old 04-09-2007, 01:35 PM   #146
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Damn Ted I ain't got sh%t on you now. I'm catless, running 22lbs and external wastegate making 352whp/365wtq (Nov. 05'). Though, I'm still rocking the old tune that Franz never finished (when my clutch blew while tuning).
Either way rock on like it's 1999....
Rick
2800rpm 135hp 252tq
3k 190hp 300tq
3200 200hp
5k 360tq
5600 356.9hp(peak)
ami2fst4u is offline   Reply With Quote
Old 04-09-2007, 02:45 PM   #147
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Why did you run less boost on the meth/water map?
Old 04-20-2007, 03:17 PM   #148
elnino334
Member#: 56818
I have a VF34
elnino334 is offline   Reply With Quote
Old 04-23-2007, 11:03 PM   #149
Tank.
Member#: 146477
very informative thankyou.
Tank. is offline   Reply With Quote
Old 04-23-2007, 11:06 PM   #150
Tank.
Member#: 146477
Originaly coming from the DSM camp (still own one) and all of my friends have high hp evo's I don't understand why a lot of these turbos seem to make so much less hp on the suby 2.0. Any fairly indepth explanation would be great. Thanks.
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
