Old 04-26-2007, 05:32 PM   #151
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
The 4g63 is way different than our engines. Different heads, shorter exhaust paths, stronger engine means you can push the tune harder, etc.
WRXRallyBlue is offline   Reply With Quote
Old 05-07-2007, 12:41 AM   #152
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
Originally Posted by WRXRallyBlue View Post
Why did you run less boost on the meth/water map?
stock bottom end, the rods wouldnt take any more torque reliably.
nhsilversti is offline   Reply With Quote
Old 05-15-2007, 03:39 PM   #153
subawang
Member#: 17515
2007 Legacy GT
Brilliant Silver Metallic
VF-46 is the new turbo used on the MY07 USDM Legacy GT and spec. B. As quoted from legacygt.com,
"the VF46 is the world's first 5-arc scroll turbo. This new design has been adopted for the turbocharger compressor. By adjusting the flow of compressor air and improving compression efficiency, low and midrange torque has been increased/improved."
http://legacygt.com/forums/showthread.php?t=61765
subawang is offline   Reply With Quote
Old 05-15-2007, 03:48 PM   #154
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
EJ motors aren't a **** in the wind compared to the 4g63. Same turbo will produce significantly less power (and later most times) on the EJ (big16's typically make 290-325 on ej205's while they can crack 400 on the 4g). Exhaust path is MUCH longer and internals not as strong (wrx).
Originally Posted by Tank. View Post
Originaly coming from the DSM camp (still own one) and all of my friends have high hp evo's I don't understand why a lot of these turbos seem to make so much less hp on the suby 2.0. Any fairly indepth explanation would be great. Thanks.
japslapr is offline   Reply With Quote
Old 05-16-2007, 01:44 AM   #155
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks. I'll do a couple updates here in the near future. I have to rebuild my pc at home - mobo is quickly dying on it
Old 05-16-2007, 04:35 AM   #156
X-Factor
Member#: 101720
2006 Evo IX GSR/SSL
Electric Blue
...and we have found Unabomber's protege...
X-Factor is offline   Reply With Quote
Old 05-18-2007, 09:30 PM   #157
Prelude2WRX
Member#: 149194
very useful information, thank you op
Prelude2WRX is offline   Reply With Quote
Old 05-19-2007, 02:40 AM   #158
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I made a couple updates
Old 05-19-2007, 09:13 PM   #159
Mcahol3
Member#: 141517
02 WRX PSM
08 Forester X
sorry JusT a Totall Noobie Here... But how Do u Tell what Turbos are Bigger than Others and Are Right for Ur Set up?
i Got this Guy thats Tryin to Sell a VF27 for a few hundred... is that better than a Stock Td04?
oh and he has a Vf25 aswell that he had hooked up on a TwinTurbo Ap on his Wrx...
Should i Not even Waste my Time?
Mcahol3 is offline   Reply With Quote
Old 05-19-2007, 09:31 PM   #160
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
pm responded
Old 05-31-2007, 12:00 PM   #161
250R
Member#: 118646
2004 Dubyaroxorz!
IHI VF23
(388cfm at 18psi, 250-325whp, Bolt-On)
This is the standard equipment turbocharger used on the JDM MY95 Subaru Impreza WRX STi and the JDM Subaru Impreza WRX STi 22b. The VF23 is a ball bearing turbocharger that utilizes the P20 exhaust housing like the VF22. This housing is mated with the smaller compressor housing of the VF24 for fast response and excellent low and mid-range performance. It does not have the same top end power of the VF22, but spools up slightly quicker.
Expect to achieve full boost with the proper mods and a quality tune between 2800-3300rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles.
This is the first ive heard of this, AFAIK all ej20g's came with TD05-16G's except the wagons and autos.
250R is offline   Reply With Quote
Old 06-01-2007, 12:27 AM   #162
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Find definitive proof that contradicts what I wrote and I will update it.
Old 06-01-2007, 11:52 AM   #163
250R
Member#: 118646
2004 Dubyaroxorz!
http://www.grahamberry2.co.jp/impreza_gc8/index.html
If you want more definitive proof and you can read japanese its all in the GC8 bible. Or google ej20g td05 then google ej20g vf23, or go into the pre-02 factory turbo forum and take a quick peek.
Old 06-01-2007, 02:47 PM   #164
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
It says it uses this: IHI RHF5HB, which is a VF designation.
Old 06-01-2007, 03:36 PM   #165
Mbenoit
Member#: 150342
2007 wrx
wr blue
thnx for the info. helps with a lot of unanswerd Qs
Mbenoit is offline   Reply With Quote
Old 06-01-2007, 03:42 PM   #166
250R
Member#: 118646
2004 Dubyaroxorz!
Correct, thats for the Ver 3/4 EJ20K. A Ver 1/2 is an EJ20G that uses a td05.
Old 06-02-2007, 03:27 AM   #167
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I misread it.
Old 06-04-2007, 06:03 PM   #168
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Just for completeness, you may want to add the IHI VF45 to the list.
The IHI VF45 is a ball bearing twinscroll turbo that replaces both the IHI VF38 (5AT) and the MHI TD04HLA-19T (5MT) turbo for the JDM LGT starting with MY06. The IHI VF45 is similar in size to the IHI VF38 but supposedly flows as much as the MHI TD04HLA-19T in the top end.
The external appearance of the VF45 compressor cover resembles the VF46 compressor cover, but it is unclear if it shares the same 5 arc cross section as the VF46 cover.
http://legacygt.com/forums/showthread.php?t=51207
mickeyd2005 is offline   Reply With Quote
Old 06-05-2007, 01:30 AM   #169
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks.
Old 06-06-2007, 10:56 AM   #170
Spins4
Member#: 150663
2004 STI GT30R
PSM Silver
Love this list, I must've referenced it 100 times in the past couple months.
Spins4 is offline   Reply With Quote
Old 06-06-2007, 09:52 PM   #171
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I'm glad it helped!
Old 06-07-2007, 03:53 AM   #172
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
dont know if this is the right place to ask but does anyone know if the Evo IX Twin Scroll 16G 10.5 would directly bolt on to a 02? the guy selling it said id need a custom uppipe...?
MOBBiN is offline   Reply With Quote
Old 06-07-2007, 03:58 AM   #173
STi_VIII
Member#: 72957
2004 EJ257 VF37 51E
w/ TypeRA Roof Vent & Lip
If that turbo bolted on, everybody would have them!
STi_VIII is offline   Reply With Quote
Old 06-07-2007, 04:17 AM   #174
MOBBiN
Member#: 128441
2006 STi WRB
yea just found all the info i needed right afteri posted. < n00b thanks.
Old 06-08-2007, 07:17 PM   #175
DAGE
Member#: 150855
95 Stealth TT
red
very interesting to see what kind of turbo's are available for you subie owners, props to the people who put this together
Kyle
DAGE is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
