Old 06-09-2007, 09:47 PM   #176
1A4
Member#: 145298
Very nice
1A4 is offline   Reply With Quote
Old 06-25-2007, 08:17 AM   #177
Ak-
Member#: 152325
2002 Silver 02 WRX
[email protected] 92oct gas
how many cfm's can push the vf39??? on 14.7psi???
Ak- is offline   Reply With Quote
Old 06-26-2007, 11:23 PM   #178
fastbluewrx07
Member#: 143703
wow! this is so cool!
fastbluewrx07 is offline   Reply With Quote
Old 06-30-2007, 08:04 PM   #179
mybluesubi
Member#: 53526
1997 Impreza
black
subscribed!
mybluesubi is offline   Reply With Quote
Old 07-01-2007, 03:32 PM   #180
francis520
Member#: 152527
1998 2.0GT Turbo
Blue Mica
very nice, thanks for the info
francis520 is offline   Reply With Quote
Old 07-02-2007, 02:52 AM   #181
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Happy it helps
WRXRallyBlue is offline   Reply With Quote
Old 07-13-2007, 04:57 PM   #182
Fai17
Member#: 153814
Thank you ...what a read
Fai17 is offline   Reply With Quote
Old 07-13-2007, 10:24 PM   #183
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
You're welcome.
Old 07-16-2007, 12:22 PM   #184
kkos06
Member#: 128591
2006 WRX
Ok so I cant decide now between a blouch, deadbolt or fp turbo (most likely going 20g but maybe 18g not sure what size for sure) I was wondering if anyone can tell me which is a better company, which turbos are better hp wise and realiability wise??? Who overall has the better turbo here...thanks guys
Just for reference I hav an 06 wrx tr w/
hks cb exhaust
custom dp
perrin short ram intake
perrin lightened crank pulley
big top mount w/ bov
ecutek tuned
Any help or feedback is greatly appreciated
kkos06 is offline   Reply With Quote
Old 07-16-2007, 01:27 PM   #185
karl750
Member#: 100977
2004 VF30 WRX
[email protected] 1.84 60'
hks cb exhaust
custom dp
ecutek tuned
A 20G will be really laggy on that 2.0. It will make good power and have decent traps at the track, but IMO it sucks as a DD.
EDIT: I just noticed that you have the '06 with the 2.5L so disregard the above.
karl750 is offline   Reply With Quote
Old 07-16-2007, 06:08 PM   #186
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
20g wouldn't be too big.
As for which company you choose it all comes down to brand preference, the ones you listed are all good. They will all be within a few hp of each other.
Old 07-16-2007, 06:45 PM   #187
SpoolinPA
Member#: 124662
The Original Spoolin :)
a 20g isnt too big for a 2L anyway....maybe the 8cm 20g is gettin on the big side for a 2L but the 7cm is great....depends on your driving style...never just blanketly state good or bad without driving style in mind, sure itd suck for a autox'er but for a dragger its great....
SpoolinPA is offline   Reply With Quote
Old 07-17-2007, 01:34 PM   #188
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
its this a typo?
"IHI VF23
(388cfm at 18psi, 250-325whp, Bolt-On)
Just curious..
TheShad0w is offline   Reply With Quote
Old 07-26-2007, 10:43 PM   #189
lingualorphan
Member#: 152178
2007 WRX
subscribe
lingualorphan is offline   Reply With Quote
Old 07-27-2007, 12:41 AM   #190
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Originally Posted by TheShad0w View Post
its this a typo?
"IHI VF23
Just curious..
That is the figure I received in my research. If you find this to be false and have evidence supporting you I'd gladly correct it
Old 08-06-2007, 02:40 AM   #191
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
I might've missed the post but is there any reason I don't see a turbochargers 18g turbo listed?
Magnum626 is offline   Reply With Quote
Old 08-06-2007, 01:42 PM   #192
wrxty
Member#: 121996
My guess is because it is so similiar to all the other 18g's out there.
wrxty is offline   Reply With Quote
Old 08-06-2007, 10:59 PM   #193
Magnum626
Member#: 62856
MBP SQC#197
^Yea but so are the fp18 and db18g.
Not that I'm a fanboi of TC or anything, I was just curious.
Old 08-07-2007, 03:18 AM   #194
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
I'm wondering how "daily driver friendly" would a vf22 be on a 2.0 motor.
With the correct supporting mods and tune.
xEJ20x is offline   Reply With Quote
Old 08-07-2007, 05:31 PM   #195
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
It won't drive stock, but in the realm of "daily driver turbos" it will do well.
Old 08-07-2007, 05:32 PM   #196
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I think at the time of writing tc.com didn't have an 18g listed on their site.
I'll try to get around to updating that soon.
Old 08-07-2007, 05:43 PM   #197
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Great writeup...one thing I noticed for the FP section (post #3, it looks like you copied and pasted the first paragraph but then didn't update some of the figures.
Great info though
Originally Posted by WRXRallyBlue View Post
Forced Performance Standard 16G
(510cfm, 275-330whp, Bolt-On)
This water cooled direct fit TD05H-16G-7cm2 turbocharger has a compressor flow rating of 510cfm and an unheard of compressor efficiency of 77%! This makes it the perfect low-cost easy install option for your 330whp 2.0 Subaru project.
The inlet and outlet flanges of the turbocharger are a perfect match for the stock flanges and high quality carbon steel studs are included so you don't have to scramble for hardware during installation.
The compressor inlet of the turbocharger is 2.4", so it is directly compatible with the factory air inlet tube and doesn't require expensive aftermarket intake tubes to install. The 2.4" inlet is ASME spec bell machined to maximize laminar flow into the compressor wheel to reduce inlet turbulence and improve compressor efficiency.
The FP16G comes fitted with brand new coolant lines and an 8psi wastegate actuator. The oil inlet thread is 10mm x 1.5mm just like stock, the water threads are 14mm x 1.5, and the oil drain flange is the same size and bolt pattern as the factory TD04, TD05, and VF series turbochargers allowing the use of any of these oil drain tubes.
Expect to achieve full boost with the proper mods and a quality tune between 3200-3700rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles.
Purchase $700
16G: FP or DB?
Forced Performance Big16G
(550cfm, 36 lb/min, 275-360whp, Bolt-On)
FP doesn’t have specific text for their Big16G: This water cooled direct fit TD05H-16G-7cm2 turbocharger has a compressor flow rating of 510cfm and an unheard of compressor efficiency of 77%! This makes it the perfect low-cost easy install option for your 330whp 2.0 Subaru project.
Purchase $850
16G: FP or DB?
Forced Performance Evo3 16G
(575cfm, 275-375whp, Bolt-On)
FP doesn’t have specific text for their Evo3 16G: This water cooled direct fit TD05H-16G-7cm2 turbocharger has a compressor flow rating of 510cfm and an unheard of compressor efficiency of 77%! This makes it the perfect low-cost easy install option for your 330whp 2.0 Subaru project.
Purchase $874
16G: FP or DB?
Forced Performance 18G
(605cfm, 275-390whp, Bolt-On)
FP doesn’t have specific text for their 18G: This water cooled direct fit TD05H-16G-7cm2 turbocharger has a compressor flow rating of 510cfm and an unheard of compressor efficiency of 77%! This makes it the perfect low-cost easy install option for your 330whp 2.0 Subaru project.
Expect to achieve full boost with the proper mods and a quality tune between 3300-3800rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles.
NASIOC Member subenerd Results w/8cm^2
NASIOC Member dbmartindbmartin Results
Purchase $874
z is offline   Reply With Quote
Old 08-07-2007, 05:48 PM   #198
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Great info though
FP doesnít have specific text for their Big16G:
FP doesnít have specific text for their Evo3 16G:
FP doesnít have specific text for their 18G:
Notice my disclaimer for each one
Old 08-07-2007, 10:28 PM   #199
z
Member#: 41762
04 STi
I see...but is the cfm rating accurate under each name?
Old 08-08-2007, 01:17 PM   #200
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Yessir.
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
