#1 |
Member#: 123043
RMIC
Vehicle:1999 legacy 2.5GT green |
***********so in a attemted to rivial my friends Rx7, i need suggestions!!! i was looking as well as asking around about the possiblity of have tein dampers, but most people tell me to just modify the ones for 2.5 rs...is that possible? . i have a 99 gt 2.5 stock supention. opened to any suggestions you have, oh yeah i have around a thousand to spend.
#2 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
what?
#3 | |
Member#: 38629
NWIC
Vehicle:1999 Legacy GT (STI) White |
Not to burst your bubble, but if it is a 3rd Gen you can spend to your hearts content, and you'll never come even close. I had a 3rd Gen RX-7 for 3 years. I still miss that car. Maybe one day I'll buy one with no motor and do a LS7 conversion. ![]() |
#4 |
Member#: 115154
Vehicle:2003 Legacy L Turbo silver |
used coilovers for a wrx, if the stock suspension can be used on BD's, so can the coilovers most likely.
#5 | |
Member#: 85763
I guess if you put your money, research, and time into the tuning, anything is possible. If you see Hot Version dvds...Amuse S2k used to be the MAOU (devil) of touge...but Now it's the RE amemiya FD...I mean of course those cars are the ***** but it also depends on the tuner and also the driver. |
#6 |
Member#: 67154
Vehicle:1997 Legacy GT/WRX White |
You can run Tein coilovers for the WRX on your GT, I did so for quite a while.
Bear in mind though, your range of adjustment at the front will be very small. Here is my 97 GT on Tein Flex: This is how much thread engagement I had on the lower brackets at that height: That was one of the reasons I sold them to a WRX owner, the other was that the stiff springs rates (559f/448r) on the Flex will really upset your ABS when braking on uneven surfaces, as the front wheels will tend to skip over any bumps (I believe the ABS on the BD/BG/BK series legacy is particularly touchy about this). |
#7 |
Member#: 123139
NWIC
Vehicle:1993 Turbo L Wagon RED |
No dampers for the WRX/2.5RS will not work on a 99LGT.
#8 |
Member#: 123043
RMIC
its a 2nd gen, yeah this isn't really encourging...lol well is there brand that is compare that would work?
#9 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
You're 100% incorrect (unless I'm misunderstanding you). WRX coilovers will mount up and the chassis weights are similar enough that they're an excellent option.
But what do I know, I've just run multiple different WRX setups for over 100k miles ![]() I'm currently on Flexes and while, like Dan, I wish I had more thread engagement in the fronts, it hasn't been a dealbreaker and I've been running the setup for fast road use for over 40k miles. The only issue you run into is the orientation of the front top hats (only an issue with camber plates). Swap the hats side to side (for WRX-specific hats) and you'll only have a ~10 degree misalignment, which just means you'll slightly adjust caster if you regularly use the full range of camber adjsutment on the hats. For the 95% that will set the top hats then get an alignment and never adjsut again, it's a non-issue. There's enough of a dearth of reliable information for 1ist and 2nd-gen owners on supesnion compatibility; please check your sources before spreading misinformation (especially in the magazine, as you have an opportunity to help a lot of people that can go awry if you're communicating limitations that aren't there.) Subarus are like Legos. Just get the right blocks for your application from the parts bin ![]() |
#10 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
Well said sybir.
I agree that there isn't enough info out there for us early legacy owners, since they weren't 'popular'. |
#11 |
Member#: 123139
NWIC
Ok, is the 99 the same as the 97? Becuase I know that the 2000-2004 are not the same. The rears are totally different.... (off checking)
Ah, yes, 99 is the BD chassis. Then yes they will work. 2000 is different, my bad. I am running 2005 RS H&R coilovers on our 97 LGT. However, there are no camber plates on that kit but the 05 top hats bolt right up. See this month's issue for the write up. |
#12 |
Member#: 67814
Vehicle:1995 legacy L white |
any 02 wrx damper will fit on your car. so start from there
I have tein hg's on my 95 legacy. just needed to buy wrx top hats for the front and the rubber ring. |
#13 |
Member#: 123043
RMIC
#14 |
Member#: 768
Vehicle:OB, legacy, 911, ram 1500, 1098s, m620 |
tein did make second generation legacy specific coilovers. i had a set of tein ha's on my 97.
#15 |
Member#: 67814
let us know how the coil over shoping went...
#16 |
Member#: 19681
RMIC
Vehicle:1998 Legacy Wagon GT Green |
If you go to KYB's website, they list the part numbers for all the Subarus. They have the strut and topmount numbers in their parts catalog, and you can see which Subarus use the exact same part.
http://www.kyb.com/catalog/ And the 95-99 Legacy uses the same topmount as the 02-04 WRX. |
#17 | |
Member#: 65823
NWIC
Vehicle:1996 Impreza L Red |
topmount is the same, but if you are running impreza springs you will need impreza upper spring perches... very important!!!! |
| Thread Tools | |
| Display Modes | |
| Lifespan of AWD on '92 Legacy? | MacNews | Legacy Forum | 6 | 08-20-2008 08:22 AM |
| location of PCV on '04 Legacy?? | bugeye829 | Normally Aspirated Powertrain | 2 | 08-27-2007 12:09 PM |
| Possible defective tein SS, or is rust on them normal? | Kwyjibo | Brakes, Steering & Suspension | 3 | 04-23-2005 08:01 PM |
| can I put tire load of 85v on my Legacy? | etam | Tire & Wheel | 0 | 09-12-2003 06:46 PM |
| Anyone have pics of 18's on a legacy? | nitrohuffer | Legacy Forum | 6 | 07-05-2001 04:56 PM |
