Old 11-21-2006, 06:20 PM   #1
DTSJR
Member#: 73780
2000 Impreza 2.5RS
SRP
Angry Broke something on my 93 SS
Im working on installing a new CTS (PITA) and while taking the intake off, this nifty little plastic peice broke in a few places. Im still working on taking off the part that connect to the block. What does it do, do I need it, how do I fix it?!
DTSJR is offline   Reply With Quote
Old 11-21-2006, 06:44 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
gum & duct tape ftw?
PM subiegal and try to find a part number for replacement?
fibuz is offline   Reply With Quote
Old 11-22-2006, 11:15 AM   #3
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
This comes from the area near the turbo, right? If so, it's just a plan old pipe - part of the PCV system.
Options
1) Buy a new one from a dealership
2) Try to glue it back together with JB weld (seems like a pain, and you'd definitely have to check for leaks)
3) Replace it with hoses and a y-splitter you can pick up at any local auto parts store. You might want to chop off the bottom fitting and re-use that fitting in your new contraption if it's not something standard (I've honestly never seen the bottom half of this part!).
4) Install a catch can, which I believe would effectively replace this fitting anyway.
5) Grab a used one from the junkyard or from a partout on bbs.legacycentral.org. You'd could also PM Blackbart on there.
cowapult is offline   Reply With Quote
Old 11-22-2006, 02:25 PM   #4
DTSJR
Member#: 73780
2000 Impreza 2.5RS
SRP
Last night I went out and bought some parts to make a new one of those out of hose connectors and tubing. I also have one on order from the dealership. I was hoping I could get it today, but it might not come until Tuesday.
Old 11-22-2006, 03:39 PM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
The coolant tank on the driver side of the engine is the most common thing to break on the older turbos. Heat and age take their toll.
DLC is offline   Reply With Quote
Old 11-23-2006, 07:41 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Make sure to order the rubber hose that connects that "F" tube to the block. If you can't wait for the rubber part just go to an auto parts store and ask to see their hoses. I found some that fit and just used it (only needed like 2 inches).
subiekid is offline   Reply With Quote
Old 11-24-2006, 01:42 AM   #7
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
I broke mine a few weeks ago, I went to napa and made one out of hose and plastic tees.
biggreen96 is offline   Reply With Quote
help, broke something on shifter instal RS 1986 Transmission (AT/MT) & Driveline 6 05-23-2010 10:16 PM
Broke 1kmls on my 05' STI!! Got $2000 to spend on Mods speedyralph Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 10-12-2004 01:06 AM
HELP! I broke something in my WRX! -=Ice-T=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-10-2004 01:01 PM
Need Help, I broke something on my WRX anant369 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-11-2002 06:05 PM
