Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-21-2006, 09:28 PM   #1
Dave G
Member#: 4738
2006 Baja Turbo
Default '06 Baja Turbo; How do I turn off the seat belt beeping?
I have a 2006 Baja Turbo.
Roughly 10 or 15 seconds after I turn the car on, I hear relentless annoying beeping until I buckle my driver's side seatbelt.
I believe in belting up, but I often don't buckle up that quickly after getting in the car. I'd like a minute or two, at least.
Is there an easy way to turn off the beeping?
I was thinking that I might need to get a wire harness from a driver's side seatbelt connection (from a Baja or Outback?), and plug it into the wires going to my seatbelt buckle, but create a loop, so the seatbelt beeping system thinks my seatbelt is always attached. Will that work? Or is there something more simple than that?
Thanks for any replies.
Dave G is offline   Reply With Quote
Old 11-21-2006, 11:41 PM   #2
Spacinjason
Member#: 110407
'06 Baja Turbo MT
Smile
I had the same problem with my '06 Baja Turbo. Try turning the ignition on, then fasten and unfasten the drivers belt about 20 times as quickly as possible. Then start up the vehicle. The bell should still chime, but should stop after about ten seconds and not sound anymore after that. Worked for me! All I get now is the initial 10 second chime after startup, then it stops after that. It was pretty annoying! Good luck
Spacinjason
'06 Baja Turbo MT
Spacinjason is offline   Reply With Quote
Old 11-22-2006, 12:11 AM   #3
jeffsmith
Member#: 118674
2006 Baja
yeah it feels a bit "dorky" while you are doing it
but it works
jeffsmith is offline   Reply With Quote
Old 11-22-2006, 01:46 AM   #4
baja6620
Member#: 111003
04 Baja Turbo
A guy here got hit last spring just as he backed out of his driveway. Hadn't buckled up yet, said he usually does before 'going too far'.
No belt = steeringwheel/windshieldface = brain damage.
Sit in car.
Start car.
Buckle up.
Drive.
Please.
baja6620 is offline   Reply With Quote
Old 11-22-2006, 07:50 AM   #5
Dave G
Member#: 4738
2006 Baja Turbo
I definitely advocate wearing seatbelts.
My question in no way was meant to suggest that I'm trying to avoid putting my seatbelt on.
I just can't stand the beeping noise. Maybe my hearing is super sensitive, but there are times when the beeping is almost ear piercing for me.
Yes, I could just make sure to buckle up before I even start the car, and I do that when I'm away from my home. But its not convenient or practical for me for when I'm at home. My driveway is 300 feet long. I park in my garage. When I back out of my garage, or before pulling into the garage, I sometimes get out of the car for a minute to do things. If I had to put my seatbelt on just to back out of (or drive into) the garage, and then take it off 20-seconds later, thats ridiculous. If I leave the car running in my driveway (just outside my garage), then the beeping starts as soon as I open the door and sit in the car.
Thanks for the responses.
Old 11-22-2006, 09:49 AM   #6
cnw
Member#: 98395
get an 05. no seatbelt chime
cnw is offline   Reply With Quote
Old 11-22-2006, 12:17 PM   #7
downhilbil
Member#: 74675
2005 subaru BAJA T
blue
Its better to be reminded than go without
downhilbil is offline   Reply With Quote
Old 11-22-2006, 12:43 PM   #8
Dave G
Member#: 4738
2006 Baja Turbo
Do the '03 or '04 models have the seatbelt beeping noise? Probably not.
So '06 is the only year with the seatbelt beeping? I wonder why.
Do the '06-'07 Legacy's, Forester's, Impreza's have the seatbelt beeping noise?
Old 11-22-2006, 04:01 PM   #9
bklynbaja
Member#: 106911
06 BAJA/ 95 SVX
IT'S ALL WE'LL DRIVE!
Spacinjason
'06 Baja Turbo MT
don't have to buckel the belt, just push the botton 20 times.
bklynbaja is offline   Reply With Quote
Old 11-22-2006, 09:26 PM   #10
bajawes
Member#: 128015
03 baja
yellow
my 03 don't do it, thank God. i wear anyways, but if i just go to the mail box or drop the kid off or pick at the bus stop, never.
i got the wiring diagramif you want to pm me an email address. i'll figure out how to send the file to you.
bajawes is offline   Reply With Quote
Old 11-24-2006, 09:28 PM   #11
Wallygator
Member#: 109789
Default Under the driver seat
There is a plastic connector attached to the underside of the seat. Although a bit of a pain to get to, disconnect and it will solve the problem. I advocate seat belt use but its a bit annoying when working on the car... swapping cars... headed to the end of the driveway...
Wallygator is offline   Reply With Quote
Old 11-30-2006, 02:40 PM   #12
butler1850
Member#: 87461
2005 Baja
Garnet Red
My 05 does... I can't stand it either, as I'm a "belt before you move" driver.
butler1850 is offline   Reply With Quote
Old 11-30-2006, 04:15 PM   #13
bajawes
Member#: 128015
03 baja
yellow
i have the seat belt light, but i don't think mine has ever chimmed. i got the schematic if you want, pm me with an email address and i'll send it to you. but, please wear your belt. someone else may care about you, even if you don't. also, life insurance will NOT pay if something happens. so all of you family guys, think about it!
Old 11-30-2006, 04:34 PM   #14
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
I don't know if that is true. As a matter of fact, I highly doubt it, unless it is a specific exclusion.
Regardless though, there is one justification for seatbelts OTHER than personal safety, that is the safety of others.
Wearing the belt can conceivably keep a driver behind the wheel during extreme conditions which MAY help him/her regain control of the vehicle or otherwise help to create a positive outcome once the vehicle has lost all or partial control during an incident.
Kev
kev m is offline   Reply With Quote
How do i turn off the annoying locking beep? Un0RiGiNaL Newbies & FAQs 7 09-28-2008 10:19 PM
How do you turn off the "clicker" sound an impreza 2.5i? rhinh25 Normally Aspirated Powertrain 10 08-06-2007 02:26 PM
How could I turn off the seat belt alert? sububusti Newbies & FAQs 22 09-19-2006 10:41 AM
How do I turn off the daylight driving lights? 04RCSTI Interior & Exterior Modification 7 07-13-2005 10:23 PM
How do I turn off the "click" noise? wyn525i Off-Topic 4 02-12-2005 11:14 AM
