Old 11-22-2006, 06:09 AM   #1
bigjon102
Member#: 132895
Default Dash bulb question about my 2000 Legacy GT
I need to replace a dash bulb, in my 2000 subaru legacy GT. I was wondering if anyone knew how easy it was to do, and if so step by step how would I go about doing it? If anyone has any information, I would greatly appreciate it.
Thanks,
Jon
bigjon102 is offline   Reply With Quote
Old 11-22-2006, 09:37 AM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Pretty easy to do, finding a replacement bulb is probably the hardest part.
You'll have to take apart most of the dash to do it;
Start with shifter trim(held on by clips, pops off),
Remove coin cup(2 screws),
Remove ashtray(1-2 screws underneath),
Remove "wood grain" center console surround(held on by clips, pops off),
Remove "wood grain" foglight/etc switch bank to left of steering wheel(held on by clips)
Remove gauge surround/vents(multiple screws/clips, don't forget to remove harness for hazard switch, slide out over steering column towards passenger side of car)
Remove gauge cluster(4-5 screws).
Determine bulb that is faulty, replace. You can unplug the cluster if need be for more space, you'll only lose the trip-meter info/clock info.
That should be about it. Good luck!
EDIT: I assumed you had a cluster bulb out, but after re-reading it could be any bulb on the dash. Which bulb is out?
fibuz is offline   Reply With Quote
Old 11-22-2006, 10:17 AM   #3
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
http://www.scoobymods.com/forums/showthread.php?t=91
These are the instructions I used for my legacy, however, i'm not sure the difference between working on mine and yours. Hope it helps some.
legacy1907 is offline   Reply With Quote
Old 11-22-2006, 11:49 AM   #4
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
fibuz instructions = dead-on
LetItSnow is offline   Reply With Quote
Old 11-22-2006, 12:14 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I only had to do it about a bajillion times
Old 07-13-2008, 10:49 AM   #6
TooLeg
Member#: 124456
Default parts number
Hi Did Someone have the bulb parts numbers for the Dashboard (all the bulb)
and in the same time if you have the number of the bulb in the button
i will appreciated
Best Regards
TooLeg
Legacy Gt Limited 2000
TooLeg is offline   Reply With Quote
About to purchase a 2000 Legacy GT... MandTPhotography Newbies & FAQs 3 11-13-2007 12:02 AM
2000 Legacy GT Wheel Tire Fitment Question BLK REX Tire & Wheel 0 01-14-2007 11:03 PM
New to Nasioc have a question about my 2000 subaru legacy gt bigjon102 Newbies & FAQs 1 11-21-2006 10:49 PM
Questions about my new Legacy Outback Al_Smokemcrack Newbies & FAQs 4 07-21-2004 05:43 PM
2000 Legacy GT limited shifting Question... spburns74 Legacy Forum 2 01-11-2004 08:31 PM
