Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-14-2001, 10:07 PM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default Boost gauge problem, need some help!
heres the deal, i got my boost gauge. i went with the autometer sport comp, the gauge looks great and is in new shape. after waiting one day for it to come in at the store, i pick it up. when i open it up its missing parts, like the fittings and light bulb. i went back there today and they gave it to me. now i hooked up the gauge and it doesn't work but i can hear the pressure sucking. i hook up my bros autometer and it works perfectly on my car. the damn gauge is a dud, the thing is, shouldn't the meter be at zero when it isn't connected? mine is at 30 vacuum and it doesn't move, the thing is also i cut like half of the screw thingy that sticks out on the back but they should take it back regardless b/c i had to install it to find out that it doesn't work. so what should i do? since its not at zero when not plugged in, would that be a dead giveaway that its broken?
dennis
datdudedennis is offline   Reply With Quote
Old 11-15-2001, 12:35 AM   #2
Elwood
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
Default you're right...
I'd definitely try to take it back. I hear mixed opinions about autometer boost gauges. I bought the same one as you and it seems to work fine, calibration seems right on. maybe I was a lucky one though....?
Elwood is offline   Reply With Quote
Old 11-15-2001, 12:52 AM   #3
PunksWRX
Member#: 5504
2004 Impreza WRX STi
Yep, take it back. You should not be hearing a "sucking" sound and the gauge should be at zero. I would say there is either an installation problem or the gauge has an internal leak, but it is a moot point anyway on the installation issue as the gauge should be reading zero right out of the box.
I have the Autometer Sport Comp too and it has worked flawlessly. Another post tonight mentioned something about Defi gauges being somewhat inaccurate. If that is true I would be really pissed as expensive as they are!
Punk
PunksWRX is offline   Reply With Quote
Old 11-15-2001, 01:35 AM   #4
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Angry
Return it. My Autometer boost gauge has always worked well. Yours should too. Good Luck.
Ken Levin is offline   Reply With Quote
Old 11-15-2001, 11:01 PM   #5
2.0 guy
Member#: 5670
If its reading 30 vacuum, sounds like maybe it was dropped and the needle is pointing in the wrong place?
2.0 guy is offline   Reply With Quote
brake problem, need some help fast 96imp Brakes, Steering & Suspension 0 07-07-2004 11:51 AM
brake problem, need some help Scoobyslack1 Brakes, Steering & Suspension 12 05-12-2004 03:32 PM
Install problems, need some help kinger Car Audio, Video & Security 7 05-02-2004 12:19 PM
Boost Guage problem -- Need some help Redneck Ricer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-10-2003 07:18 PM
Got a problem, need some help - long jaywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2003 07:26 PM
