Old 11-22-2006, 04:17 PM   #1
JLwrx06
Member#: 117952
06 ltd. wrx awdm'd
CobB StG. 2 SgM
Default any prob with a non cat dp on an 06
I just order my megan dp for my 06 and it is catless. I was wondering if any one is having any problems with a catless dp on their 06? Should i sell it and get a catted one. If its not really that big of a deal, Im going to just put it on. i already have em. thanks all
JLwrx06 is offline   Reply With Quote
Old 11-22-2006, 05:31 PM   #2
bluestonepath
Member#: 123641
'04 WRX Wagon
Platinum Dirty Metallic
I don't have an 06 but I do have the megan catless DP. You should be fine with EM, although there are lots of stories of boost creep problems with 06's floating around here.
bluestonepath is offline   Reply With Quote
Old 11-22-2006, 05:33 PM   #3
JLwrx06
Member#: 117952
06 ltd. wrx awdm'd
CobB StG. 2 SgM
is there any where that has a way to fix the boost creep prob?
Old 11-22-2006, 05:35 PM   #4
bluestonepath
Member#: 123641
'04 WRX Wagon
Sorry, I'm not the person to ask. This should be a little helpful http://forums.nasioc.com/forums/show...06+Boost+creep
try a little searching too, that's how i came across that^^
Old 11-22-2006, 05:54 PM   #5
limitedblkwrx
Member#: 121269
2006 subaru wrx
black
I have a megan dp on my 06 wrx and i dont have any problems its well worth the money..only thing is if your going to use the stock catback its most likly going to leak but other than that no problems.
-Rob
limitedblkwrx is offline   Reply With Quote
Old 11-22-2006, 09:23 PM   #6
robert46123
Member#: 130355
2006 Impreza WRX
I'm running a catless DP (Cobb) with stock CBE and Cobb AP. No bost creep or leaky exhaust. Nice setup and very stealthy.
robert46123 is offline   Reply With Quote
Old 11-24-2006, 09:52 AM   #7
JLwrx06
Member#: 117952
06 ltd. wrx awdm'd
CobB StG. 2 SgM
thanks all for the help. i was getting kinda nervous about the boost creep problem. im still a little uneasy about it but ill guess ill just wait to get a cbe. probably not tho. ha
Old 11-24-2006, 09:54 AM   #8
Davenow
Member#: 23676
Before you go trying to fix boost creep, you should make sure you actually are having boost creep.
Not that it isnt likely, but there is no sense doing anything about it until you know you have it. Not everyone does.
The solution is porting the wastegate. More specifically, reshaping the entry into the wastegate passage.
Old 11-24-2006, 09:56 AM   #9
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Hi dave
~v6
V6TurboTA is offline   Reply With Quote
Old 11-24-2006, 09:56 AM   #10
V6TurboTA
Member#: 9090
09 Forester Gump
Hi dave
~v6
Old 11-24-2006, 09:56 AM   #11
Davenow
Member#: 23676
Hi
Old 11-24-2006, 11:33 AM   #12
JLwrx06
Member#: 117952
06 ltd. wrx awdm'd
CobB StG. 2 SgM
thanks i was just wondering if it happens, which my luck it probably will. is porting the WG something I can do at my house or would I hav to take it somewhere to have it done?
Old 11-24-2006, 03:06 PM   #13
littlewhitewagon
Member#: 103068
11 STI sedan
This is dependant on your capacity to remove the turbo from the car. If you can do it, then you can port your own turbo, if not, then you can't.
littlewhitewagon is online now   Reply With Quote
Old 11-24-2006, 03:15 PM   #14
CynicX
Member#: 48199
06 WRX
I'd personally suggest making sure it creeps with the dp AND EM. The 06 is going to need EM to run safely.
I had my WG ported and it didnt do too much for the creep. Once I had EM it was under control...MAYBE in a LONG 5th WOT pull it might start to creep but I doubt it would go to far and besides I dont go that fast so I dont worry about it...
So get your dp with EM. See if it creeps then go from there...
CynicX is offline   Reply With Quote
Old 11-25-2006, 09:07 AM   #15
chirp the 1-2
Member#: 113095
06 wrx tr
I also was very worried about this but i put on my invidia catless dp with cobb stage 2 and have no probs!
chirp the 1-2 is offline   Reply With Quote
catless dp on an 06 wrx cel or not??? (stock tune) hector Newbies & FAQs 16 12-30-2007 02:15 PM
Has anyone had any probs with the new SPT intake on an 02/03 wrx? Nettalp Factory 2.0L Turbo Powertrain 5 08-02-2006 08:59 AM
2 piece DP on an 06 WRX? Bluemanchu Factory 2.5L Turbo Powertrain 5 06-04-2006 11:18 AM
Cat Back on an 06 WRX TxWrX Newbies & FAQs 10 04-25-2006 04:57 PM
MO- WTT Catted DP for non Catted DP go1d1e MWSOC Private Classifieds 0 02-02-2006 05:49 AM
Message Board Statistics All times are GMT -4. The time now is 12:48 PM.
