Old 11-28-2006, 05:32 AM   #26
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
You need a windshield washer pump because if it fails, it will still let water through. Putting a 2-5 ohm 25W resistor inline will extend its life.
If you run high concentration of meths in the truck tank, always vent the breather hose outside the car. This will avoid any fire/explosion hazard caused by a certain concentration of math fume mixed with air.
Aquamist is offline   Reply With Quote
Old 11-28-2006, 02:11 PM   #27
benw
Member#: 103320
1998 swapped
Forester L
is 50% considered a high concentration Richard?
I'd like to hear anyone's experience with venting trunk-mounted tanks in new-age Imprezas. Specifically, the spec-C tank and the STI sprayer tank.
benw is offline   Reply With Quote
Old 11-28-2006, 04:57 PM   #28
Aquamist
NASIOC Manufacturer
Member#: 110029
I believe 75%+ to be regarded as ghigh concentration of methanol. Since the Aquamist forum is now re-opened, here is a link to some useful information regarding water/methanol mix.
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=65
Old 11-28-2006, 07:57 PM   #29
benw
Member#: 103320
1998 swapped
Forester L
what does flash point mean? does that mean it evaporates at the stated temperature according to that mixture?
Old 11-28-2006, 08:46 PM   #30
Aquamist
NASIOC Manufacturer
Member#: 110029
I don't know what that means either, I will try to find the answer from google and let you know tomorrow.
Old 11-28-2006, 09:12 PM   #31
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Good **** Richard. Also can that new fangled gauge that you have floating aroud work with this perrin system?
nosmo is offline   Reply With Quote
Old 11-28-2006, 09:17 PM   #32
hotrod
Member#: 14141
2002 Impreza WRX
Its one of several formal definitions of the characteristics of flamable liquids.
http://en.wikipedia.org/wiki/Flash_point
Larry
hotrod is offline   Reply With Quote
Old 11-30-2006, 01:51 PM   #33
benw
Member#: 103320
1998 swapped
Forester L
Thanks Larry!
Originally Posted by Wikipedia
The flash point of a flammable liquid is the lowest temperature at which it can form an ignitable mixture with oxygen. At this temperature the vapor may cease to burn when the source of ignition is removed. A slightly higher temperature, the fire point, is defined at which the vapor continues to burn after being ignited. Neither of these parameters is related to the temperatures of the ignition source or of the burning liquid, which are much higher. The flash point is often used as one descriptive characteristic of liquid fuel, but it is also used to describe liquids that are not used intentionally as fuels.
It would be nice if someone could determine at what ambient temperatures various mixes of water and methanol begin to evaporate.
Does the methanol evaporate sooner than the water, leaving more water than methanol, effectively "diluting" the mixture? Or do the two become a unified solution once mixed?
Old 12-03-2006, 04:53 AM   #34
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Methanol and water will form small bonds with each other since both are polar molecules and due to london forces but those are the weakest of all bonds and the methanol will still evaporate at a faster rate than the H20.
Old 12-08-2006, 12:44 AM   #35
pdxsilverwrx
Member#: 54935
Well I got one. The install should be tomorrow. I post some pics of the finished setup and how it went later.
pdxsilverwrx is offline   Reply With Quote
Old 12-08-2006, 06:06 AM   #36
Aquamist
NASIOC Manufacturer
Member#: 110029
congratulations, you own a very complete system, the failsafe tracks the flow against IDC full time. Very advanced piece of equipment.
Old 12-09-2006, 01:56 AM   #37
pdxsilverwrx
Member#: 54935
It's in, I'll get some pics up later. Install wasn't too bad but I had help. Jeff Perrin came over and did the tuff stuff.
Old 12-11-2006, 03:59 PM   #38
jkbrand
Member#: 107118
'02 STi Wagon
Please do post 'em. I just got the same kit and want to see where you and
Jeff mounted the pump, the controller, and the display. (Hoping most of the pix will apply to an '02 wagon....) Also, did you install a new tank?
Jeff
jkbrand is offline   Reply With Quote
Old 12-11-2006, 05:23 PM   #39
Aquamist
NASIOC Manufacturer
Member#: 110029
I have found a nice picture of perrin's system:
Old 12-12-2006, 10:32 AM   #40
pdxsilverwrx
Member#: 54935
I used the spec C tank
Old 12-12-2006, 10:35 AM   #41
pdxsilverwrx
Member#: 54935
This is where we mounted the pump
Old 12-12-2006, 11:31 AM   #42
dream
Member#: 37003
2015 WRX
Looking good
dream is offline   Reply With Quote
Old 12-13-2006, 08:11 AM   #43
Aquamist
NASIOC Manufacturer
Member#: 110029
This is a perfect place of the system. Pity it would be seen once the rain cover is replaced.
Looking forward to the next set of pictures.
Old 12-13-2006, 09:02 AM   #44
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
Hey pdx, ...nice camber plates!!!
Also, will the rain cover go back over the pump after installation or do you plan on leaving it open? If it's going back on do you plan on slotting the cover to allow for the lines to exit the area from the pump?,,,as opposed to holes with grommets.
BadTrip is offline   Reply With Quote
Old 12-13-2006, 09:52 AM   #45
jkbrand
Member#: 107118
'02 STi Wagon
Richard, Don't you mean wouldn't (be seen) ???
Also, people who have this kit should be aware that whether they're using the stock windshield tank or an auxilary tank in the engine compartment, according to the installation instructions--which recommend the pump assembly be lower than the lowest point of the tank--they'll likely need a primer pump if they install the pump assembly where PDX has installed his. (His Spec 2 tank has a primer pump built-in, I believe.)
PDX, Would love to see where you tapped for the nozzle....and where you mounted the dash display....
Jeff
Old 12-13-2006, 11:01 AM   #46
pdxsilverwrx
Member#: 54935
Dash display is over a switch blank.
Old 12-13-2006, 11:05 AM   #47
pdxsilverwrx
Member#: 54935
The rain cover is back in place and as I loomed everything up there is nothing to see.
We tapped the Y pipe intercooler inlet. I plan on running two jets, one in the Y and one right before the throttle body.
Old 12-13-2006, 11:07 AM   #48
pdxsilverwrx
Member#: 54935
There are holes with grommets already so you can just run the wires and hoses through there. There is no need to cut the rain cover at all.
Old 12-13-2006, 11:09 AM   #49
pdxsilverwrx
Member#: 54935
Other side, we ran the wires for the injector pulse and power and ground.
Old 12-13-2006, 01:09 PM   #50
jkbrand
Member#: 107118
'02 STi Wagon
PDX, where did you install your controller? Engine bay or cab?
FS: Perrin PWI-1 Water Injection System persian prince Engine/Power/Exhaust 4 10-14-2007 11:34 PM
Guaging Interest Perrin PWI-1 water injection pdxsilverwrx NWIC Private Classifieds 0 09-30-2007 07:38 PM
Perrin meth/water/alky injection kit BNIB ImprezvRS Engine/Power/Exhaust 5 08-20-2007 12:18 AM
Perrin alchy/water injection kits and Aquamist Kits in stock Dyno Flash Engine/Power/Exhaust 0 07-21-2007 09:26 PM
73.99 Fuel Pumps shipped, Coolingmist Water Injection specials, Turboxs, SBR, Perrin! IMPORTIMAGE Engine/Power/Exhaust 220 08-05-2006 01:12 PM
