Old 12-13-2006, 02:14 PM   #51
jkbrand
Member#: 107118
'02 STi Wagon
Richard, the schematic for the PWI-1 indicates the filter (Aquamist pn806257) "below water level," yet its location appears above the tank.
Is this a contradiction or a limitation of the drawing?
Jeff
jkbrand is offline   Reply With Quote
Old 12-13-2006, 04:14 PM   #52
pdxsilverwrx
Member#: 54935
I mounted the brain or controller in the cab. I have a Forester pocket under my after market stereo. I drilled a couple of holes and ran the wires into there.
pdxsilverwrx is offline   Reply With Quote
Old 12-13-2006, 05:45 PM   #53
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Jeff
The drawing is not to scale nor correctly orientated. The less air is trapped in the filter the better. Below the minimum water level can solve this.
Richard
Aquamist is offline   Reply With Quote
Old 12-17-2006, 01:51 PM   #54
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
This is the system I'm looking hard at...have the Spec C trunk tank so the install would be similar...pdx what is your feeling on hours to install this system just as you did? Thanks
JonR is offline   Reply With Quote
Old 12-17-2006, 05:08 PM   #55
pdxsilverwrx
Member#: 54935
Being careful and moving slow, 2-4 depending on your tools and abilities.
Old 12-18-2006, 02:52 PM   #56
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
do you have the pump still in the IC sprayer tank? Just wired it to the main pump control?
nosmo is offline   Reply With Quote
Old 12-18-2006, 07:12 PM   #57
41ants
Member#: 89458
2006 Superzilla STi
CGM
So is it okay to mount the pump in this location and use the IC sprayer tank that comes standard on the STI? I thought this had to be mounted below the tank?
41ants is offline   Reply With Quote
Old 12-19-2006, 12:25 AM   #58
pdxsilverwrx
Member#: 54935
As long as you use a primer pump it's OK to mount it above the tank. The Perrin kit has the ability to run a primer pump built in. If you use the factory intercooler spray tank just use the factory pump. If you get a spec C tank like I did it also has it's own pump.
Old 05-28-2007, 12:15 PM   #59
pdxsilverwrx
Member#: 54935
http://forums.nasioc.com/forums/show....php?t=1258368
Link to my final tune results and dyno plots.
Old 06-01-2007, 03:00 AM   #60
pooster.online
Member#: 120461
2004 WRX STi JBP
does anyone have any close ups of the dash display and where they mounted it?
pooster.online is offline   Reply With Quote
Old 06-01-2007, 03:49 PM   #61
pdxsilverwrx
Member#: 54935
as far as a close up all I have is this preproduction computer drawing.
I posted this already but this is where I mounted it.
Old 06-02-2007, 06:05 PM   #62
pooster.online
Member#: 120461
2004 WRX STi JBP
thanks a lot, it doesn't look too bad. one question though, is the only protection against running out of meth the led?
Old 06-02-2007, 07:37 PM   #63
pdxsilverwrx
Member#: 54935
no it triggers a fault and shuts off your boost solenoid so you only have waste gate pressure.
Old 06-04-2007, 01:02 AM   #64
LittleBlueGT
Member#: 96204
2013 STI GR
Check out this thread for a complete walkthrough (you may have to register to see the pics). I installed it in my ashtray and it fits perfectly.
http://www.legacygt.com/forums/showt...ighlight=pwi-1
LittleBlueGT is offline   Reply With Quote
Old 06-04-2007, 08:26 PM   #65
pooster.online
Member#: 120461
2004 WRX STi JBP
^ thanks.. ill definitely check it out.. how are the gains?
Old 06-04-2007, 09:32 PM   #66
LittleBlueGT
Member#: 96204
2013 STI GR
Never tuned the car with new turbo w/o alky, just a basic "get you by" tune in case of a failure.
Gains would be about the same as any alky kit, just maybe a little better then some due to the IDC controlled injection rate.
Maybe 35 hp.
Old 06-11-2007, 03:33 PM   #67
Zak Shaker
Member#: 146250
1999 STI type R
white
I have read that the perrin kit can change from 1 to 100 % duty in 10ms. how does it compare with a aquamist 2D hsv reaction speed ? any figures for this last one ?
about that dash display, I have seen silver paint and black unit. what is the latest production color ?
Zak Shaker is offline   Reply With Quote
Old 06-12-2007, 02:46 PM   #68
sutter2k
Member#: 92467
08 STI
couple pics of my setup.
http://sutternow.com/pics/lgt/perrin_wi/index.html
However, I need more flow.
How much will an accumulator alone add anything to a setup with the 1.0 nozzle?
e.g.
http://www.urdusa.com/product_info.p...s_id=124806410
Has anyone added an priming pump to this setup?? Anyone have any pics / diagrams?
Does anything else need to be purchased besides this-->
http://www.urdusa.com/product_info.p..._id=1260198021
sutter2k is offline   Reply With Quote
Old 06-12-2007, 03:48 PM   #69
MrTransAm
Member#: 80744
2005 Subaru STI
Maybe 35 hp.
Actually, I netted 47.3HP and 43.1TQ, not that a few hp or tq make that much of a diff,but I did pass my 400/400 goal.
In case anyone is interested.
http://forums.nasioc.com/forums/show....php?t=1264513
A couple interior shots with the new black panel also.
MrTransAm is offline   Reply With Quote
FS: Perrin PWI-1 Water Injection System persian prince Engine/Power/Exhaust 4 10-15-2007 12:34 AM
Guaging Interest Perrin PWI-1 water injection pdxsilverwrx NWIC Private Classifieds 0 09-30-2007 08:38 PM
Perrin meth/water/alky injection kit BNIB ImprezvRS Engine/Power/Exhaust 5 08-20-2007 01:18 AM
Perrin alchy/water injection kits and Aquamist Kits in stock Dyno Flash Engine/Power/Exhaust 0 07-21-2007 10:26 PM
73.99 Fuel Pumps shipped, Coolingmist Water Injection specials, Turboxs, SBR, Perrin! IMPORTIMAGE Engine/Power/Exhaust 220 08-05-2006 02:12 PM
