Old 11-22-2006, 07:53 PM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default swapped to modified deatschwerk injectors - now CEL codes p0103 and p0113?
well, in preparation this thanksgiving weekend to complete my 18g project, i swapped out my pink injectors to modded deatschwerk injectors. car currently still has the OTS cobb 2.5 vf30 map. after installing the new injectors, i fired up the car to check for leaks. no leaks whatsoever, so the injector install was a success. car fired up fine and idled ok. however, i now have a CEL and I pulled the codes with the accessport - p0103 and p0113, which are MAF circuit high input and intake air temperature sensor high input. i have not yet reflashed to my custom PDX map tuned for the 18g and new injectors. i'm guessing after i am complete with the project and reflash to the new map, everything should be fine. any inputs on why the CEL's?
anthonyrb98 is offline   Reply With Quote
Old 11-22-2006, 09:23 PM   #2
ScottPWRX
Member#: 34238
2007 Legacy Spec B
Grey
Sorry, can't help with your question but I have one for you.
What instructions did you use to install the injectors? IF you would share them that would be great. Or if you did it from prior experience, you may have done it from memory...Tackling a similar project soon!
THanks,
Scott
ScottPWRX is offline   Reply With Quote
Old 11-23-2006, 06:41 AM   #3
anthonyrb98
Member#: 48307
02 bugeye
do a search for "pink injectors install" here
Old 11-23-2006, 07:53 AM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Sounds like the MAF is unplugged. Those cels are unrelated to the injectors so I wouldn't expect them to go away with a reflash.
LiquidForce is offline   Reply With Quote
Old 11-23-2006, 01:38 PM   #5
WRblueX_Guy
Member#: 53247
THanks,
Scott
http://www.projectwrx.com/modules.ph...howpage&pid=32
http://www.turboxs.com/faq/stage4.htm
In step 5 they have directions for the fuel injectors, also.
WRblueX_Guy is offline   Reply With Quote
Old 11-23-2006, 03:07 PM   #6
anthonyrb98
Member#: 48307
02 bugeye
yup, fixed the issue - maf wasn't plugged in all the way - stupid me
cel p0103 and p0113 - input? dehsiung Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-22-2009 03:55 PM
Ewg install. Now CEl code? Q's / a's??? 04works Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 03-27-2009 09:21 AM
Solid CEL, Code P0103 IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-07-2007 04:19 AM
FS MA: 750cc DeatschWerk Injectors, SPT Intake, VF-34 and stock TD-04 scooterforever Engine/Power/Exhaust 13 05-16-2007 08:48 PM
CEL codes P0102 and P0103 both NITROS Service & Maintenance 6 11-15-2005 06:13 PM
