Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-22-2006, 10:46 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Forged 2.5 - $2299, WB02 Combos, Helix V3 EWG Uppipe, Turbobacks @ $599, WRX Cobb APs
Hey guys,
We have a special deal on our Gruppe-S Stage 1 engine. This particular engine was installed in a customer's car who did not follow proper break in procedure and was driven for only about 1500 miles. We pulled the motor and FULLY REBUILT the engine.
GRUPPE-S STAGE 1 2.5 FULLY FORGED ENGINE
-FULLY REBUILT
-BRAND NEW Rings
-BRAND NEW Gruppe-S coated race bearings
-Repolished crank
-Sleeves rehoned
-Wiseco Pistons and Helix Rods (forged) have ONLY 1500 miles on it
-Professionally assembled and balanced with +/- 1 gram
-Good for up to 600HP
Basically it's as good as new
$2299 + Shipping
Hey guys,
I have some cool combos:
Wide Band 02 Combos
I just installed the PLx M300 WB02 setup in our 06 STI with the Helix V3 downpipe. The M300 downpipe is an awesome entry level WB02 system, featuring very rapid response, quick warm-up times, and is very easy to setup. Coupled with the external WB02 port of the Helix V3 downpipe (located right in the exhaust stream) the readings are both accurate and rapid.
-PLX M300 WIDEBAND CONTROLLER
-Includes LED Display & WB02 sensor
-Helix V3 Downpipe with Wide-Band 02 sensor port 6" behind turbo
$479 shipped!!
HELIX V3 UPPIPE (EXTERNAL WG FEATURES)
The Helix V3 uppipe was created for the 400+ horsepower EJ25. The V3 uppipe is designed to achieve real horsepower gains and improved torque curves by allowing the use of an external wastegate (EWG). An EWG eliminates the power-loss associated with internal wastegate turbos by moving the exhaust vent turbulence away from just before the nozzle area of the turbo. Not only does this result in improved power levels for high horsepower cars but also greater boost control and better torque curves. The V3 uppipe is mandrel bent from 2.3 SS304 tubing, TIG welded, and employs CNC machined flanges. The full 2.3 tubing allows for greater exhaust gas flow and only reduces down to 2.0 after the EWG port. The uppipe flange can be ported to 2.3 provided a 2.3 gasket is used (not included). The V3 uppipe can also be used as an internal wastegate uppipe with the included block off plate.* **
*External wastegate and external wastegate setup kit is not included. Optional V-band outlet is available.
**To use EWG option, internal wastegate must be secured by either welding the flap or locking the swing-arm.
HELIX V3 UPPIPE
-BIG 2.3" pipe diameter
-EWG Ready
-Direct bolt-on fitment
$199 Shipped!! (Introductory Price - EWG setup kit will be available shortly)
HELIX V3 UPPIPE & V3 DOWNPIPE COMBO
-Includes V3 Uppipe
-Includes V3 Downpipe
-Full SS304 Construction, TIG welded, CNC mandrel bent
$359 Shipped!!!
BIG TORQUE COMBO
We have seen HUGE gains in torque with the use of the Gruppe-S 4-1 headers and the Helix V3 Uppipe on the stock turbo STI. The reason is the huge 2.3" that allows substantially increased exhaust flow. Check out the dyno graph (sorry the scanner just broke).
COMBO INCLUDES:
-Gruppe-S 4-1 Headers
-Helix V3 Uppipe
-Helix V3 Downpipe
-Helix Cat-Back Exhaust
$1099 Shipped!!!
SWITCH OUT TO GREDDY EVO II - Add $125
TANABES ALSO AVAILABLE - CALL FOR PRICING!
HELIX TURBO BACK COMBO
-V3 Downpipe (Catless)
-V2 Cat-Back Exhaust (3.0" no tapers)
-Mechanical Cel Fix
$599 Shipped!!!
CRAZY COBB AP & FUEL SYSTEM SPECIALS!
ALL WRX 2002-2005 COBB ACCESS PORT COMBOS
-Cobb Access Port (All 2002-2005 WRX)
-Helix 660cc OR 820cc Injectors
-Walbro Fuel Pump with setup kit
-This fuel system supports 475HP to 550HP respectively
$959 shipped!!!
AP ONLY $499 shipped!!!
Please contact us for ordering. Thanks!
Gary
Gruppe-S
Gruppe-S is offline
Old 11-22-2006, 10:52 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 11-23-2006, 12:51 AM   #3
9vapors
Member Sales Rating: (40)
Member#: 92582
Can that motor be used with WRX heads?
9vapors is offline
Old 11-24-2006, 08:57 AM   #4
TheMadScientist
Member Sales Rating: (3)
Member#: 23717
2005 Big red
Originally Posted by Gruppe-S View Post
Hey guys,
HELIX V3 UPPIPE
-EWG Ready
Gary
Gruppe-S
How much more for the optional V-band? Does that refer to the wastegate?
TMS
TheMadScientist is offline
Old 11-25-2006, 08:42 PM   #5
BriBoogie
Member#: 127754
2004 JBP WRX
2006 XB12R
$499 shipped for an accessport? are these version 1? and are they brand new?
BriBoogie is offline
Old 11-26-2006, 11:55 PM   #6
preacher#1
Top Scoob 022
Member Sales Rating: (17)
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Default helix turbo back
will you sell just catback? if so, how much shipped to 90254?
preacher#1 is offline
Old 11-27-2006, 06:27 PM   #7
qazxswqazwsx
Member Sales Rating: (8)
Member#: 103016
2007 STi
are the helix v3 w/ wastegate and dump tube (399 package) avilable it shows it on the site just trying to confirm before i order
qazxswqazwsx is offline
Old 11-27-2006, 06:55 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
9Vapors - Yes! You will need the thicker head gasket unless you want to run the higher compressor (the WRX heads have a smaller quench area).
TheMadscientist - Sorry the V-band version is still in the works, will be available sometime next year.
Briboogie - Yes V1 APs, brand new. We have maybe 5-6 left if you're interested, I think WRX only.
Preacher $479 shipped for the Helix cat-back only. Good in stock
qazxs - Sorry the dump tube is not currently available, it's being redeveloped from the Tial WG (the Helix wastegate looks like it will be available late Jan).
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 11-27-2006, 11:34 PM   #9
Huff
Member Sales Rating: (5)
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
How would that motor be with a set of version 7 heads and 8,000rpms with a gt30r rotated
Huff is offline
Old 11-29-2006, 12:49 AM   #10
WRXtasy05
Member Sales Rating: (6)
Member#: 81116
2012 WRX Sedan
Lightning Red
Pm'd you
WRXtasy05 is offline
Old 11-29-2006, 05:38 PM   #11
"blade"
Member Sales Rating: (1)
Member#: 75239
2003 Another one
of Andrewtech's beast
Can you pm me for shipping on the stage 1 2.5 engine
"blade" is offline
Old 11-30-2006, 01:54 PM   #12
gogoguasco
Member#: 133404
Default yo
I am really interested in buying ur block because i just threw a bearing in mine and i have 2 choices, either buy a new block or rebuid it!
gogoguasco is offline
Closed Thread
