Vancouver Impreza Club
Old 11-14-2001, 11:16 PM   #1
KenM
Member#: 353
2014 Forester XT
Satin White
Default Opinion/Input needed regarding brullen header and aircare
I'm thinking of getting the brullen header. I'm wondering by installing the header and replacing the 2 cats with the one hi flow that comes with the header, will I pass visual inspection assuming the inspectors know something about our cars coming with 2. Thanks in advance
Ken
KenM is offline   Reply With Quote
Old 11-14-2001, 11:37 PM   #2
Avenger
Member#: 1234
The people at air care usually doesn't know what they are looking for. As long as you have a cat in your car it would be fine. But I am not too sure if you'll get a low enough reading with only one high flow cat. But give it a shot and tell me how it goes cuz I'll be running one cat too later when I get my turbo in. Also who are you getting your stuff from?
Avenger is offline   Reply With Quote
Old 11-14-2001, 11:37 PM   #3
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
if u have a high flow cat....u might still not pass the emission test....chance is 50/50 w/ any header installed....most of the time i heard fail more than pass....and since it is supposed to be 2 cats and u replaced w/ one high flow....the chance for u to pass is even lower....
yeah....as for inspectors at air care center....they know nth and their training is really *****ty....even cop won't give u too much trouble compare to u have straight pipe, no cat at all....
5 Zigen is offline   Reply With Quote
Old 11-14-2001, 11:41 PM   #4
Avenger
Member#: 1234
My bro got a header for his car and the reading from before (a year before) and the result after seems almost compairable just a bit higher since the cat is one year older. So I don't think a header will affect the result too much..
Old 11-14-2001, 11:44 PM   #5
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
oh really? ur bro is lucky....
mine is way too high to pass and my friend is at the borderline....which he has to put stock header back to make sure it goes thru nice and clean
Old 11-14-2001, 11:51 PM   #6
KenM
Member#: 353
2014 Forester XT
Satin White
thanks guys I think this helps a little, I don't want to have to change the header back and forth to pass aircare so I think I'm gonna hold on the header and save $1000+ Dang aircare wish my car was home was in the interior where there is no sniffer test.
Old 11-14-2001, 11:54 PM   #7
Avenger
Member#: 1234
Well you can look at the bright side.. your car only need to be air cared every two years!
Old 11-15-2001, 12:03 AM   #8
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
do ur air care next Jan....then install the header and that will last u 2 years!!!
btw, labor for installing header onto a GC8 NA is not much....like $60?
Old 11-15-2001, 08:13 AM   #9
SubaruStu
Member#: 8972
2003 WRX Wagon
If you go over the thread again, there is the statement that it will
pass the ON clean air tests. If you can get the specs on that and
compare it to BC's, you should be able to confirm whether it'll
pass there or not.
SubaruStu
SubaruStu is offline   Reply With Quote
Old 11-15-2001, 11:51 AM   #10
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
I don't know guys. It really is a hit andd miss situation. If you don't pass, it won't be by much and you might have a nice guy doing your test and they could always suggest a way to make it pass and still look like stock readings.
nikkicalves is offline   Reply With Quote
Brullen header and Oil cooler - Any way to have both? awd4ever Normally Aspirated Powertrain 2 06-14-2004 10:38 AM
Brullen headers and highflow cat with stock catback? DeusExMachina Normally Aspirated Powertrain 3 02-20-2003 01:06 PM
midpipe adapter for brullen headers and cat jdsimpreza Normally Aspirated Powertrain 2 07-27-2002 08:48 PM
Brullen header and exhaust jetfan8178 Car Part Reviews 0 03-30-2002 10:30 PM
Brullen headers and Tanabe catback installed Mikey Normally Aspirated Powertrain 2 12-12-2001 12:12 PM
