Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 11-23-2006, 02:16 PM   #1
sub-dub
Member#: 132861
Default I have searched!!After market turbo kit
Hi guys nice site you have here,just trawled thru search but cant find an answer to my query?basically would a turbo kit designed for an ej25 bolt up to an ej22?Thats it.!!
sub-dub is offline   Reply With Quote
Old 11-23-2006, 02:47 PM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
It *should* but if you want to know take off your header and compare it to a 2.5 header, if they are the same legnth and connect to the mid-pipe in the same places then yes.
But a header designed for a 2.5 won't fit a 2.2 because the 2.2 heads are single port heads.
Sko is offline   Reply With Quote
Old 11-23-2006, 06:05 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
/\ Wrong!!!
Only a year or two of the late 2.2s were single port.
Old 11-23-2006, 11:39 PM   #4
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Yeah, not all EJ22s are single port. Basically, if you have the dual-port heads on your EJ22, I don't see why an AVO or FAT kit for the EJ25 wouldn't work.
HondaH8er is offline   Reply With Quote
Old 11-24-2006, 03:08 AM   #5
sub-dub
Member#: 132861
Superb,where can i gat the FAT kit i have seen the avo kit,which is the better or are they much alike?
Old 11-24-2006, 07:10 AM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
1. http://www.forcedairtech.com/
2. 6 of 1, half dozen of another.
3. No.
Be sure you wanna go this route. It's gonna cost some bux.......over and over again.
Tats is offline   Reply With Quote
Old 11-24-2006, 10:31 AM   #7
sub-dub
Member#: 132861
3. No.
Why is it going to cost over and over?The problem i have is that there is a lot more involved if i do a wrx swap,as it is in this car below(please dont flame me!!)The bolt on will be easier to make fit.
Old 11-24-2006, 11:51 PM   #8
psychochild
Member#: 59353
2003 2.5 TS-Turbo
Pearl Ridge Blue
HOT! I like it, you might need to do some custom piping though, i think depending on your skill level you might get much better results out of a custom setup, i dont even know if youll have clearace behind that engine for the turbo, check out some of the sandrail setups too, that should help
psychochild is offline   Reply With Quote
Old 11-25-2006, 03:28 AM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Simply pull the motor out, replace the stock NA pistons with stock turbo ej22t pistons (about $250 online plus $75 for rings) and you will NOT blow that motor up unless you DONT have EM, or are stupid.
Its a winner. Just be carefule and think about each thing you are doing.
TN: Anyone have an after market catback they don't want? socomcaptain05 Private 'Wanted' Classifieds 4 06-25-2008 01:18 AM
after market body kits/trim the_crazy_canadian Interior & Exterior Modification 2 12-12-2007 12:13 PM
My JDM lights are working crazy with after market HID kit. Help! wrx2 Electrical & Lighting 4 06-28-2005 09:27 PM
Legacy Turbo Swap? Or After-Market Turbo? ejicon Legacy Forum 6 05-08-2002 09:52 AM
NE1 have a 98 or later Legacy GT With an after market Turbo??? Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-01-2001 08:04 PM
