Old 11-23-2006, 05:22 PM   #1
snowcrzy
Member#: 110895
Default Throttle position sensor and speed sensor pinout 04 WRX?
I am installing a dccd unit and I can't find the Throttle position sensor and speed sensor pinouts on an 04 wrx ecu.
This is the only diagram that I found that looks like my harness(02-03):
http://www.northursalia.com/modifica...ng/wrxpin.html
Anyone have a 04 ecu pinout diagram that looks like this one?
snowcrzy is offline   Reply With Quote
Old 11-26-2006, 12:00 PM   #2
snowcrzy
Member#: 110895
Bump need help!
Old 11-26-2006, 01:39 PM   #3
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
06STi is offline   Reply With Quote
Old 11-26-2006, 01:51 PM   #4
snowcrzy
Member#: 110895
Why do you think I post here? Because I want to pay for $35.00 to maybe get the information that I need...?
The answer is out there and all it takes is someone to come accross this thread who has installed an aftermarket dccd controller into an 04 wrx and tell me where the tapped into the tps and speed sensor.
thanks anyway
Old 11-26-2006, 02:00 PM   #5
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
thanks anyway
Quit being a cheap basturd.... I used to do that. But if you want correct info quick.. You got to pay. Least you'll know its correct. Right.....
This kids around here could be on crack and give you some made up diag, Then you go a fry your ECU.. $35 is cheap
Have you tried the button?
ahhah just poking fun.. Good luck.. That site I gave you is good stuff I use it when I need to now.
Old 11-27-2006, 10:31 AM   #6
snowcrzy
Member#: 110895
I'm not being cheap, I can just wait until someone gives me the info. I am just sick of all the nickle and diming that goes on by all these big companies.
To answer your question: yes, I have used the search button about 25 different times. I have even contacted the maker of the unit and he couldn't seem to pull up anything for my unit.
thanks anyway
Old 12-05-2006, 02:25 PM   #7
snowcrzy
Member#: 110895
bump.
Old 12-05-2006, 04:51 PM   #8
Mechie3
Member#: 120152
Mechie3 is offline   Reply With Quote
Nuts and Bolts of a 07 STi 6 Speed into an 04 WRX knakai1 Transmission (AT/MT) & Driveline 11 05-13-2008 10:04 PM
wtb wrx glovebox sways and speed sensor for manual trans wrxmase Private 'Wanted' Classifieds 4 03-12-2007 10:29 PM
03 wrx tranny harness and speed sensor etc simprezl25 Private 'Wanted' Classifieds 0 06-25-2006 10:54 AM
O2 sensor and speed sensor Seca2man New England Impreza Club Forum -- NESIC 3 04-06-2001 04:16 PM
