Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Closed Thread
Old 11-15-2001, 01:37 AM   #1
girl
Member#: 7768
Default 18" rim owners look here!!
whats the correct tire pressure for 18" 215/40/18? anyone help me out please?
girl is offline
Old 11-15-2001, 02:18 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default The correct tire pressure...
is located in your owners manual as well as your door jamb.
Click here for more info. Even though its for 17" wheels, it'll still work for 18" wheels.
http://www.i-club.com/forums/showthr...hreadid=114092
LaterZ!
Darren!!
Penphoe is offline
Old 11-15-2001, 02:26 AM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
The owner's manual isn't much help for aftermarket wheels. Did you read the manufacturer's recommendations or even the side of the tire?
Ben
bsquare is offline
Old 11-15-2001, 02:28 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
What do you want ot do with the car? on the street I usually run about 34-35psi hot and when autocrossing I run about 40-43psi hot
All tires are about the same though. Within reason, the higher the pressure, the better the gas milage but the worse the ride comfort. The lower the pressure (again, within reason) the better ride comfort but the worse the gas milage
Eric
Eric SS is offline
Old 11-15-2001, 02:55 AM   #5
Penphoe
Member#: 269
If you're unsure of what tire pressure to run, as long as the vehicle manufacture's recommended pressure (i.e. the ones stated on the door jamb and owners manual) fall within the allowable tolerances of a particular tire, I'd start with that. From then on, you can bump it up or down depending on your preference.
There have been alot of newbies asking basically the same question, hence they get basically the same answer from me.
LaterZ!
Darren!!
Penphoe is offline
Old 11-15-2001, 10:41 AM   #6
flipguy80
Member#: 5987
Platinum Silver Metallic
I usually run mine 35-40 psi.
flipguy80 is offline
Old 11-15-2001, 10:45 AM   #7
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Default Tire pressure trick!
We used to do this in the 4x4 world where premature or uneven tire wear was a real pain and happened all the time.
1) find a empty cul-de-sac or dead end road
2) draw a chalk line across the tread of each tire
3) drive down the road for a few hundred feet then stop
4a) if the chalk wore off in the middle first add air pressure
4b) if the chalk wore off on the outside and inside edges reduce pressure
5) repeat until chalk wears off evenly for all 4 wheels
BINGO that is your ideal pressure. Typically it will be higher in the front than the rear and for some cars it is different for each wheel. Remember this is the best pressure for even tire wear. For track/autocross adjustments are better made for traction reasons.
skidplatez is offline
Closed Thread
DRebel/10/20D Owners Look Here teknisa Mid West Subaru Owners Club Forum -- MWSOC 16 11-18-2004 12:46 PM
Borla Hush + Wagon Owners look here! KmanRuffian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 51 11-16-2004 06:26 PM
DBA 4000 Problem/Defects, Owners look here KanosWRX Brakes, Steering & Suspension 8 06-16-2004 05:12 PM
Jersey WRX owners look here for a min. please. 03WRX83 Tri-State Area Forum 5 07-03-2003 09:50 AM
Texas owners look here... montgog General Forum Archive 5 09-08-2000 03:29 PM
