Old 11-15-2001, 01:48 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Arrow Anyone cross-referenced Suabru Fuel Injectors?
I am so tired of aftermarket parts for Subaru's being so darned expensive! EIGHT injectors for the Vette's I work on cost $295! And people tell me that 4 injectors for my car cost over $600!
Has anyone ever cross-referenced the Subaru injectors or am I screwed? Are they low or high Impedience? Thanks
Eric
Eric SS is offline   Reply With Quote
Old 11-15-2001, 02:18 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
eric i should have more details for you soon.. 8complex and i are going to see about fitting RX-7 Injectors in...and yes i agree with you...but just remember those designs you are suing on those vettes have been paid for since the 80's....this is a new game out here and an expensive one at that.
Jeremy
Old 11-15-2001, 02:20 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I hope you guys come up with some good news. do you know if they are High or low impedience?
Eric
Old 11-15-2001, 02:33 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
high
Old 11-15-2001, 02:35 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
That's good. That means you can at least run low impedience if you need to.
Eric
Old 11-15-2001, 03:06 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Eric:
Just bore out the injector bosses and use the Bosch injectors you probably have in the shop. That's what I am currently planning.
Ben
bsquare is offline   Reply With Quote
Old 11-15-2001, 03:47 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
ben i was wondering if that would work...get a set a 52lb/hr GM Bosch PFI injectors...they are 16.0-16.8 ohm injectors....but they aren't dual spray...which ours are and that might be a problem...i'd be concerned with fuel puddling on the cylinder head and running down the walls into the chamber.
jeremy
Old 11-15-2001, 12:14 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Here's another trick guys. Don't buy the Bosch injectors from GM. get the SVT injetors from Ford. They are a lot cheaper and exactly the same thing. THat's actually what we use on our Vettes. I was wondering if those would work. THey look very similar
Eric
Old 11-15-2001, 01:42 PM   #9
bsquare
Member#: 1911
2000 Impreza 2.5RS
If you bore out the bosses, shouldn't the injectors seat deeply enough into the head to avoid puddling?
Ben
Fuel Injector Service rsemrad South East Region Forum 0 06-02-2010 12:14 AM
Anyone ever maxed out fuel injectors on stage 2 freetors Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 04-29-2009 07:36 PM
Has anyone tryed the APS Auxiliary fuel injector settup on there WRX? 2002WRXSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-08-2005 06:44 PM
Need rubber wrx fuel injector o-ring or fuel injector Shaitiger Private 'Wanted' Classifieds 2 02-11-2004 09:17 AM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 08:51 PM
