Old 11-24-2006, 03:29 PM   #1
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Default Higher CR w/ StgII cams and CNC'd heads.
As of right now my CR will be right around 8.78:1 (according to this calculator http://www.csgnetwork.com/compcalc.html). One of my heads was warped and required about .008" of milling. My builder thinks I lost about 1cc of chamber volume, which is fine by me. I'm also assuming the deck height will be around .001" less after resurfacing (or .37mm instead of .39mm). Everything will be measured (even the chamber volume) and calculated before final assembly (honest blueprint job). I'm going to keep the milling to a minimum since I don't want to ruin the cam timing, but I'm wondering if I should aim for something more like 8.9:1? It's difficult to calculate how milling will affect the combustion chamber volume. The .25mm I'm willing to mill away (per head) may not make much of a difference.
Supporting mods worth noting:
CP pistons
CNC'd WRX heads (program based on heavily ported v7 heads)
Crower Stage II cams, springs, retainers
td06h-18g
SMC (pure meth) injection with m15 nozzle
38mm EWG
TMIC
headers
no cats
I'm mainly looking for tons of low boost torque but still squeeze high 11's out of this setup.
PeteDucati is offline   Reply With Quote
NON AVCS cams and EJ257 heads ADJ cam sprockets saintluciascooby Built Motor Discussion 12 01-23-2012 09:12 PM
FS: WRX coil packs, cams and STI head gaskets subalou1 Engine/Power/Exhaust 8 09-25-2009 10:38 PM
2.5L VF39 E85 CAMs and Ported heads VS 2.5L VF39 E85 juanmedina Proven Power Bragging 156 09-05-2009 04:27 AM
Streettuner Cams and Higher Revs greysave AccessPort 9 03-21-2006 03:29 PM
HasCobb's Cams and Cylinder Heads combo for 99 2.5DOHC?? MY99 2.5GT Normally Aspirated Powertrain 4 03-22-2001 02:51 PM
