Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-26-2006, 02:52 AM   #1
IdenityCrisis
Member Sales Rating: (4)
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
Default FS: 2000 Impreza RSti
more changes have been made to the car and this is how its gunna stay.
its a 2000 RS with a 2004 sti motor swapped into it. swap work was done by East Coast Swappers.
http://www.eastcoastswappers.com/ima...oel/index.html
above are pics off their site when the work was getting done. since then i did alot of other work.
motor has 9000 miles on it and has only seen synthetic oil every 3 thousand miles and just got a change. car is extremely fast and should not be taken lightly. it will run low 11's to high 10's with a good driver. with good tires it runs in the mid 10's(slicks). car has been well taken care of and has no major problems. it doesnt have air conditioning because of a broken ac line and it needs a ne condenser. i'm asking 15,000 which i think is a fair price for what the car can do and all the time and money that has been put into it.
here is a brief parts list.
ENGINE:
Cobb AP tuned by PDX Tuning
2004 usdm sti motor
godspeed built 2.5l sti sb with malhe forged pistons
PE Timing Belt
Perrin Short Ram
Samco intake tube
Arp Head studs
ported tgv deletes
Deadbolt TD06h 20G
HyperFlow FMIC
Perrin Injectors
EXHAUST:
Megan Racing header/uppipe
Billy Boat 3in Turbo Back
DRIVELINE:
Exedy lightwieght flywheel
Spec stg 2+ clutch
custom short shifter
Kartboy shifter bushings
STi Motor Mounts
BRAKES:
Brembo rotors with Carbotech pads
SUSPENSION:
KYB agx struts
H&R Springs
Whiteline rear diff bushing kit
wrx front sway bar
RIMS & TIRES:
2002 WRX rims gunmetal in color
Kumho ECSTA ASX 215x50x16
GAUGES:
Auto-meter boost/vacume gauge up to 30 psi
Auto-meter oil pressure gauge
Looks:
V6 front lip
clear corner lights
clear side markers
sti pedals
20% tints
debadged
repainted flat black including sideskirts.
Electronics:
Hella 500 fog lights
highbeam and fog light mod from scooby mods
Kenwood 190w speakers
single cd player
IdenityCrisis is offline   Reply With Quote
Old 11-26-2006, 03:14 AM   #2
1FSTREX
Member Sales Rating: (47)
Member#: 109348
05 STI
CGM
Broken URL man...or at least for me.
1FSTREX is offline   Reply With Quote
Old 11-26-2006, 04:25 AM   #3
eyehate
Member Sales Rating: (10)
Member#: 10223
wont work for me either... would love to see some pics!
eyehate is offline   Reply With Quote
Old 11-26-2006, 04:33 AM   #4
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
i'll upload some pics on sunday evening .
Old 11-26-2006, 08:25 AM   #5
XyKo
Member Sales Rating: (17)
Member#: 23560
Here's the link. If it's the correct car.
Link to Joel's car.
XyKo is offline   Reply With Quote
Old 11-26-2006, 11:26 AM   #6
neko
Member Sales Rating: (34)
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
so, complete STi motor? heads n all? with complete STi wiring and ecu?
what about the DBW throttle? is the STi pedal setup tansplanted into your RS?
still running the remaining driveline from the RS right?
a/c is the only feature that doesn't work?
since you said she's been tuned, (and i'm usually the last person to care about numbers, but for reliability's sake...) What kind of numbers is she putting down?
(or is it only a PDX map-by-email?)
has it been tuned with all the the current parts on it of have some been added since the map was set?
your profile info says "resurrected and swapped". whatwas the resurrection? was she wrecked? damaged? has she even been hit?
whats the chassis mileage?
and most importantly, do you have any more current pics of the car together?
neko is offline   Reply With Quote
Old 11-26-2006, 11:30 AM   #7
Teh Legacy
Member Sales Rating: (7)
Member#: 9853
to keep your mouth
shut.
Stock RS Transmission?
Teh Legacy is offline   Reply With Quote
Old 11-26-2006, 04:49 PM   #8
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
ok.
first off. i'm going to buy a camera here as soon as i'm done with this note. so pics will be up tonight. but yes, those are the pics from ECS. that brings me back.
ECS did the swap. so everything is 100 % right. sti pedals and all.
still running the RS drive line, why you may ask? because there is nothing wrong with it. i didnt want to spend the 4500 for a 6 speed for no reason, but the car is still wired for the dccd. the 5 speed performs flawlessly. just got to remember, the rs trans is actually stronger than a wrx trans.
i cant say it enough, the trans is fine with no problems, even with the 20g.
as much as i wanted to, i couldnt take the care to Oregon so they are email maps. i have 5 maps- 10psi on 91oct, 17psi on 91oct, 18psi on 93oct, and 21psi on 100oct. they are conservative tunes. i havent put it on a dyno yet, but i can if someone is really interested.
the resurrected and swapped is a 2 fold thing. 1. i had the stock RS motor supercharged and it threw a rod. 2. the car was rear ended in my subdisvion. it sustained no structure damage, it was all cosmetic. rear bumper, decklid, and left fender. the tail lights were cracked but were replaced with lights i got as a gift(blacked out altezza lights) they dont look too bad actually.
the chassis has 96xxx miles on it, i bought the car almost 4 years ago with 65,789 on it. so i havent put alot of miles on it.
any other questions ask away. again, i will get pics up later tonight.
Old 11-26-2006, 08:34 PM   #9
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
didn't know RS trannys are stronger than WRX...
Old 11-26-2006, 08:45 PM   #10
520hpsti
Member#: 108965
2005 Subaru WRX STi
do the 6 speed swap and ill trade you straight up for my sti.
520hpsti is offline   Reply With Quote
Old 11-26-2006, 10:46 PM   #11
subiedude03
Member#: 92599
I look forward to seeing pics. Would you be interested in trades?
subiedude03 is offline   Reply With Quote
Old 11-27-2006, 01:03 AM   #12
neko
Member#: 46500
Now with 200% more
hmm.. a trade for 520hpsti's car? that's quite the gold monster.
Old 11-27-2006, 08:18 AM   #13
520hpsti
Member#: 108965
2005 Subaru WRX STi
im kinda serious too. let me know.
Old 11-27-2006, 11:41 AM   #14
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
pics will be up as soon as i can get them on my computer. they are on the digi but i cant get them on the computer. lol. doesnt help i work 12 hours aday either.
btw, i have access to a 6spd, so if you want to put that in writing i'll do the swap this weekend ;-)
Old 11-27-2006, 04:15 PM   #15
520hpsti
Member#: 108965
2005 Subaru WRX STi
Get some pics whenver you can, and ill see from there.
Old 11-28-2006, 12:07 PM   #16
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
gunna have to put this on hold, trying to buy a house and the deal is falling through. end of the week we'll continue this.
Old 11-28-2006, 02:25 PM   #17
kyllc
Member#: 48654
??? ???shopping???
suprise
kyllc is offline   Reply With Quote
Old 11-28-2006, 03:22 PM   #18
darksc00by
Member Sales Rating: (26)
Member#: 102140
2016 herpderp
Originally Posted by kyllc View Post
suprise
surprise*
darksc00by is offline   Reply With Quote
Old 11-28-2006, 04:31 PM   #19
520hpsti
Member#: 108965
2005 Subaru WRX STi
no problemo. Gl on the house!
Old 11-29-2006, 09:25 PM   #20
MyScoobie28
Member Sales Rating: (6)
Member#: 59185
2014 Impreza WRX
pictures please! hope you got my pm! -arthur
MyScoobie28 is offline   Reply With Quote
Old 12-05-2006, 11:14 PM   #21
520hpsti
Member#: 108965
2005 Subaru WRX STi
any news?
Old 12-05-2006, 11:31 PM   #22
DrunkenDragon
Member#: 21471
its an oldschool RS thing. wrx/sti n00bs wouldnt know lol jk
DrunkenDragon is offline   Reply With Quote
Old 12-06-2006, 11:40 AM   #23
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
ok, house buying bullcrap is done, and might i add- NEVER AGAIN!
car is back up, this weekend it'll be nice so i'll wash it up and get more pics(a friend will post them for mesince i'm picture retarded)until then, its 20 degrees out outside, so no washing the car for me.
Old 12-06-2006, 11:49 AM   #24
boofer
Member Sales Rating: (5)
Member#: 73949
2008 Evolution X GSR
Octane Blue
Looking at any trades? 04 STi?
boofer is offline   Reply With Quote
Old 12-06-2006, 11:55 AM   #25
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
maybe, depends on what is done to it
FS: '00 Impreza RSTi Tokinwhiteguy NWIC Private Classifieds 29 03-02-2010 02:11 AM
CA FS: 2000 Impreza RSTi vinceGC8 Private Vehicle 'For Sale' Classifieds 17 04-28-2008 09:49 AM
SoCal: 2000 Impreza RSTi vinceGC8 Private Vehicle 'For Sale' Classifieds 15 07-17-2007 09:35 PM
FS: 2000 Impreza advance North West Impreza Club Forum -- NWIC 19 04-28-2002 06:07 PM
FS: 2000 Impreza 2.5 RS Blue Ridge Pearl kalex Tri-State Area Forum 2 09-08-2001 04:42 PM
