Old 11-26-2006, 07:20 PM   #1
drewwrxrogers
Member#: 132574
04 Aspen White Sti
GT35r, axis motor,280cams
Default how do you to that fuel pump?
I am wanting to install my new 255 fuel pump....how the hell do you get to the gas tank......i looked under the car and the tank is in the middle so you cant really get it high enough to drop it, even if you could you would have to remove the difrential.....help please! pm with something....im wanting to do this tonight, thanks guys
drewwrxrogers is offline   Reply With Quote
Old 11-26-2006, 07:34 PM   #2
myleslong
Member#: 85736
05 STi
Pull the rear seat. It's under the right (passenger) side access cover.
Good luck!
Myles
myleslong is offline   Reply With Quote
Old 11-26-2006, 09:39 PM   #3
tasq
Member#: 62362
2005 wrx
CGM
What a concept!
tasq is offline   Reply With Quote
Old 11-27-2006, 06:44 PM   #4
thehollowrift
Member#: 86788
04 STi
Hate it when people do this in threads.......
Originally Posted by tasq View Post
What a concept!
thehollowrift is offline   Reply With Quote
Old 11-27-2006, 06:46 PM   #5
tasq
Member#: 62362
2005 wrx
CGM
I hate it when people ask questions that have been covered 100 times.
Old 11-29-2006, 09:18 PM   #6
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
you know it is true that the forum has gotten so large that successful searches are becoming MORE difficult rather than easier due to overwhelming numbers of results jamming the search function, especially on common keywords.
Go easy.
Zornorph is offline   Reply With Quote
Old 11-29-2006, 09:21 PM   #7
tasq
Member#: 62362
2005 wrx
CGM
Go easy.
Like this thread?
Old 11-30-2006, 08:37 AM   #8
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
tasq - I hadn't thought of that, but I guess you are right that it's snowballing.
Just try searching for "clutch install" - when I did it, it never gives a result because it goes on essentially forever.
Old 11-30-2006, 08:49 AM   #9
hippy
Member#: 36528
2002 Impreza Wrx
Old 11-30-2006, 09:20 AM   #10
trustSTI
Member#: 100673
04 STi
Aspen
Dont forget to check scoobymods.com
trustSTI is offline   Reply With Quote
Old 11-30-2006, 09:22 AM   #11
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
maybe it's my connection...
Old 11-30-2006, 09:46 AM   #12
hippy
Member#: 36528
2002 Impreza Wrx
Two easy ways to narrow down search results-
1) The word "and" is required if you want to search for more then one word. Ie- "clutch install" will only search for clutch while "clutch and install" will search for both words. If you want to search for the words clutch and install, you must put the "and" between them. If you get too many results for your liking, adding another "and", like "clutch and install and how" might narrow down the results, since it would look for those three words.
2) Searching just thread titles is a search option, and it can also help reduce the amount of search results. Ie- There are probably less threads with clutch install in the title then in the thread, and the search lets ya just search through titles if ya want....
peace
Old 11-30-2006, 10:00 AM   #13
Swordfish II
Member#: 95554
2007 The Surly Squad
Originally Posted by hippy View Post
For what it's worth, the word "and" goes a long way. "clutch install" will search for just clutch because you didn't put the and in there. "clutch and install" or, "walbro and pump and install" and so on is key(in case ya didn't know). There are probably a lot more threads with "clutch" in them then clutch and install. If you get too many results for your liking, add another "and", like "clutch and install and how" as in how to install a clutch. Another thing that might help is narrowing the search to thread titles. Chances are there are less threads with clutch install in the title then in the thread, and the search lets ya just search through titles if ya want....
peace
but then you find threads like this, with a title about installing a fuel pump that has more discussion about searching and how to search than about the install.
Swordfish II is offline   Reply With Quote
Old 11-30-2006, 10:06 AM   #14
hippy
Member#: 36528
2002 Impreza Wrx
This thread is the first one that comes up if ya type "install and fuel and pump" in the search. There are two links that I posted above which have pictures and directions on how to install a fuel pump. Is it a bad thing if people find this thread when trying to find out how to install a fuel pump? Now if I type the word walbro , this thread will come up when people add that to their search making this thread that much easier to find for people who want to install a walbro fuel pump. I bet if someone did a search on how to search, this thread would come up too. That's the whole point. The key is knowing how to look for what you want.
peace
Old 11-30-2006, 11:13 AM   #15
hotrod
Member#: 14141
2002 Impreza WRX
And if all else fails use Google's search function and limit the search to only this forum. With their advanced search features you can search for an exact phrase with ease.
Also if you limit your search to threads with a large number of responses you are more likely to get threads with detailed discussion in them --- I usually start a 10 or 20 reponses. Searching is an aquired skill --- the more you use it the better you get at it. Think about words or phrases that are very likely to be related to the issue involved like in the case of fuel pumps, "inspection plate" "filter sock" etc.
Larry
hotrod is offline   Reply With Quote
Old 11-30-2006, 01:25 PM   #16
rebos123
Member#: 67669
2005 2.5 Hybrid WRX
evoIII 16G
Good luck!
Myles
and just to clarify, when everyone says pull the rear seat, they are really talking about pulling the rear seat BACK, which requires you to remove the rear seat cushion first. Once you remove the rear seat BACK then you need to pull back the trunk mat on the passenger side to reveal the instpection plate that covers the access to the fuel pump.
just to clarify...
rebos123 is offline   Reply With Quote
Old 11-30-2006, 01:46 PM   #17
benw
Member#: 103320
1998 swapped
Forester L
well, since he said remove the rear seat, he means ALL of it.
My advice is this. if during the course of the install, you can't remove the rear seat, you should stop immediately and have a professional install the pump.
benw is offline   Reply With Quote
Old 12-01-2006, 05:05 PM   #18
dibblejr
Member#: 94070
05 LGT
If you have a wagon you have to remove all the black foam, then its by behind the pax side rear seat.
dibblejr is offline   Reply With Quote
Old 12-01-2006, 06:47 PM   #19
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
I love this board, I hardly ever have to post because 9 out of 10 times I find my answer in the archives. Seriously.
For something that is a quick answer, like "remove the back seat to install the fuel pump" then it is silly not to at least give that much information, and then bitch at them for not searching.
Slowsoul is offline   Reply With Quote
how do you test a fuel pump relay fyr3 Newbies & FAQs 2 04-04-2013 05:38 PM
How do I log for fuel pumps? Tommi300 Open Source Reflashes 5 04-27-2010 11:39 AM
How do you tell if Oil pump is Primed? Turbo Oil Line? Hayaboosted Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-25-2008 01:55 AM
why with ecutek do you need a fuel pump? mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 06-03-2005 04:16 PM
how do install a walbro fuel pump Jimmy Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-04-2001 04:06 PM
