Old 11-26-2006, 10:33 PM   #1
Electronblue
Member#: 105290
97 Legacy GT Wagon
Default suspension/Wheel fitment questions...
Ive been looking at a set of 18x8 wheels for my 97 GT Wagon...
question is, what suspension combo would be the best to fit these wheels, and still be good for racing???
I want to lower the car a bit, and have them look "right" when its all done
(I assume I will be Rolling the F@#% out of the fenders to make them fit)
Would it be better to just get some 18x7.5? I only want the 8" because the Tarmac 3 only comes in Bronze in the 18x8...
Back to the question, what suspension have other people used to fit 18's nicely?
I auto-x and cruise backroads often, so it needs to be more than just for looks...
Anyone have Pics of wagons with 18's that look good? Ive searched through alot of the pic forums, not finding to many wagons with what Im looking for...
also, any Pics of a SILVER Legacy with BRONZE or GOLD wheels???
Electronblue is offline   Reply With Quote
Old 11-26-2006, 11:33 PM   #2
Sub_Speed_Guy
Member#: 25007
2004 WRX
OEM +
On my 7.5 wide wheels (+53) they were REALLY close to the lower spring pearch on my stock strut. I don't think you want to go much wider then that.
Best advice: Search
http://forums.nasioc.com/forums/show...ghlight=18%27s
Sub_Speed_Guy is offline   Reply With Quote
Old 11-26-2006, 11:49 PM   #3
ten80
Member#: 53625
00 EJ205 LGT-4SALE
+53 is a very conservative offset. You could do +46-48 18x8 wheels and should have clearance, depending on tire width.
ten80 is offline   Reply With Quote
Old 11-27-2006, 12:07 AM   #4
rougeben83
Member#: 115154
2005 Outback XT
White on grey
18" for autox? You may just want to just keep your stockers and mount some V700's or RS2's or something on them and use those for autox.
18" is more for show.
rougeben83 is offline   Reply With Quote
Old 11-27-2006, 01:09 AM   #5
Electronblue
Member#: 105290
97 Legacy GT Wagon
yea, the 18s are for show.. the stock GT 16's are gonna have stickyz
Old 11-27-2006, 01:18 AM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
oh as far as suspension...first thing to get is usually the rear sway bar. After that, I would go to the AGX struts for strut dampening, and use Ground Control coilover sleeves so you can have adjustment for your ride height as well.
It's sort of an in between a lowering spring/strut setup and going full coilovers; you get the adjustability to change your ride height if you have rubbing problems and to run lower for autox along with changing your dampers , without the expense of a full coilover.
Old 11-27-2006, 01:42 AM   #7
Electronblue
Member#: 105290
97 Legacy GT Wagon
where can i get these???
Are they for my car, or for a newer one??? (how do I find them)
Old 11-27-2006, 03:18 PM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
No, actually, the newer legs don't get AGX's (in the US anyway ). do a search here, I few people have run AGX's.
Old 11-27-2006, 06:59 PM   #9
limeylight
Member#: 5428
97 Legacy Outback
I have this AGX/Ground Control set up on my autocross and rallycross Outback. PM me if you want more details on it.
limeylight is offline   Reply With Quote
Old 11-28-2006, 08:12 PM   #10
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
Here's a pic when I put on the '04 STi wheels for fun...
Cajual is offline   Reply With Quote
Old 11-28-2006, 08:13 PM   #11
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
hot
Wiscon_Mark is offline   Reply With Quote
Old 11-28-2006, 08:51 PM   #12
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Give me your car, Cajual!
fibuz
fibuz is offline   Reply With Quote
Old 11-28-2006, 11:54 PM   #13
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Im running AGXs on my BG. I like em! They are for a 2.5RS, used with H&R's in the front and WRX Wagon OEM in the rear.
vitai0 is offline   Reply With Quote
Old 11-29-2006, 01:18 AM   #14
Electronblue
Member#: 105290
97 Legacy GT Wagon
That is exactly the kind of drop I want...
Old 11-29-2006, 01:28 AM   #15
Cajual
Member#: 12900
I'm running STi v5 struts w/Eibach Prokits.
More pics here: http://www.sl-i.net/FORUM/viewtopic.php?t=1005
Old 11-29-2006, 08:18 PM   #16
Electronblue
Member#: 105290
97 Legacy GT Wagon
What do I need to get to make the STI struts work? is it possible on the wagon?!?
Would It be better just to use aftermarket?
Quick STi wheel fitment question! boostinscooby Tire & Wheel 4 02-01-2006 02:09 PM
Wheel fitment question for STI 06 jtrafidlo Tire & Wheel 6 12-20-2005 02:40 PM
Wheel fitment question MitchGT Legacy Forum 9 06-29-2005 02:22 PM
Wheel fitment question on Sti's crystalhelix Interior & Exterior Modification 3 02-25-2004 11:27 PM
BE/BH Wheel fitment question leeberbs Legacy Forum 4 11-07-2002 02:36 PM
