Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 11-27-2006, 10:23 AM   #1
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Default WI and little knock
I am running a Snow Performance stage 2 kit with their boost juice and a proper tune. I'm also running about 1.5 bar or 22psi. I still see my knock lite and utec flash on occasion. I thought WI would kill this for ever? I bought the kit to prevent knock and run a little more boost? Any insight to this? This system is bolted up to a 2.5 hybrid,FP Green,TMIC, and all other supporting mods.
Rexfan is offline   Reply With Quote
Old 11-27-2006, 12:40 PM   #2
Ultimate Collision Center
Member#: 69072
this could be phatom knock, aka vibrations in the car, do you have the turboxs tuner pro?
Ultimate Collision Center is offline   Reply With Quote
Old 11-27-2006, 12:43 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
H20 or 50/50 mixes do not "kill detonation". They're as good as the tune, just like tuning for 91 vs. 96 octane.
So, tell us what the "proper tune" is set up like as a start.
jblaine is offline   Reply With Quote
Old 11-27-2006, 02:00 PM   #4
Rexfan
Member#: 50993
02 WRX Wagon
Called Snow Performance and they recommend checking pump flow. They also want me to check the nozzle size as I may need a larger one?
A proper tune would be done by someone with plenty of experience. Hmm semantic games....I should have said, "I got a tune by someone with plenty of experience in WI installation and tuning within the Subaru community....
Old 11-27-2006, 02:02 PM   #5
Rexfan
Member#: 50993
02 WRX Wagon
I agree with phantom knock, but it still freaks me out. I do not have a TXS tuner pro.
Old 11-27-2006, 02:30 PM   #6
Member#: 69072
how many count knocks are they...
Old 11-27-2006, 02:30 PM   #7
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
pssssst, thats exactly what iv been telling him. However, still a good chance it is true knock. REX says it is happening under load, in low rpms and thats where i get some of my flashing cel, not often thou.
c'dalerider is offline   Reply With Quote
Old 11-27-2006, 02:34 PM   #8
c'dalerider
Member#: 92388
04 WRX, 06 STI
Yes, He should do a data log of it happening. Also should borrow an wideban. He also says the egts get pretty darn high, and that im alittle concerned about.
Old 11-27-2006, 02:35 PM   #9
Member#: 69072
if its under load in low rpms it is likely your tune, this is a common area of knock because of the transition from stock ecu to utec and the timing being much more aggressive on the utec...
Old 11-27-2006, 02:41 PM   #10
c'dalerider
Member#: 92388
04 WRX, 06 STI
Thank you
Old 11-27-2006, 03:00 PM   #11
Rexfan
Member#: 50993
02 WRX Wagon
Thanks for the input. I'm going to have it road tuned a bit more. It probably needs a bit of tweaking. My hopes are to one day have some tuning capabilities of my own.
Old 11-27-2006, 03:33 PM   #12
hippy
Member#: 36528
2002 Impreza Wrx
Using water injection with 93 octane(or whatever) is like having higher octane fuel. The engine can still knock, but it should be able to handle more abuse b4 this happens. If a car is tuned with a given safety margin, it doesn't matter how high the octane, the chance of knock is still the same. If the car is tuned less agressively(ie-larger safety margin and less power), the chance of knock is less. With water injection, you should be able to get more power from a less agressive tune then compared to if you were just using the gas you use when injecting water.
Imo, the chance that your tuner is to blame for real knock that's occuring is much higher then you seeing phantom knock. If this is the case, your tuner should fix the problem for free. Either way, your tuner should want to look at the car rather then have some people on here speculate about it. If I were you, I'd give him a call and see what he says.
peace
Old 11-27-2006, 08:14 PM   #13
Rexfan
Member#: 50993
02 WRX Wagon
^^^Thanks for the input. I spoke with my tuner and he's more than willing to spend time with me, road tuning. I thought I would do some of my own research to see what could learn.
Cheers,
Rexfan
Old 12-02-2006, 06:22 PM   #14
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
I get this too, which is why I am getting a complete retune. Primarily, I would see 1 count knocks, which are possibly not det, I have only seen one instance of 2 count knock, and nothing more, but that's just what I've logged, which is a small portion of drive time and knock i've seen.
Several gurus have talked about setting the utec to ignore a 1 count knock, because so likely to be phantom knock.
I am also buying a wideband.
Zornorph is offline   Reply With Quote
Old 12-02-2006, 07:13 PM   #15
Member#: 69072
I ignore anything below a 4 count besides under certain conditions, after tuning for a while you get a feel for what real knock is...
Old 12-02-2006, 09:11 PM   #16
hippy
Member#: 36528
2002 Impreza Wrx
I know I said this b4, but if you paid for a tune, you should not have to pay for a complete retune just because you're seeing knock. Once you get a tune, you should not have knock problems, and if you do, the tuner should fix them for free. Changing the utecs knock detection so it only reacts to knock when it sees higher then counts of 1 is not fixing the problem unless someone has listened for knock and determined that all 1 counts are false knock. I've heard pings many times when my utec read counts of 1, and many people have even heard knock without the utec detecting anything......
peace
Old 12-03-2006, 11:16 PM   #17
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
Hippy - you are right, but for me, it's not possible. I have to start over with someone new.
I appreciate that you have been there to comment on lots of utec threads - I am absorbing a lot. I did try your recommendation of that 0% column timing lockdown and it did cure my shift knock. See you around.
As for Rexfan - good luck
Old 12-04-2006, 09:29 AM   #18
Rexfan
Member#: 50993
02 WRX Wagon
I'll be seeing my tuner soon for a tweak. Thanks for the insight.
Rexfan
WI and BOV/throttle plate - Is it worth worrying about? bugeyes Water/Methanol Injection, Nitrous & Intercooler Cooling 1 03-23-2008 10:14 PM
WI and Misinformation..... Zackbo Water/Methanol Injection, Nitrous & Intercooler Cooling 31 06-21-2007 07:57 AM
Correlations between Knock Lite and negative knock correction xFactor Engine Management & Tuning 1 01-12-2006 08:36 PM
WI and NOS one wicked wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-06-2004 05:20 PM
Aquamist WI and the HSV DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-09-2003 09:48 PM
