Old 11-27-2006, 12:13 PM   #1
frdawg
Member#: 24129
2002 wrx,EVO3 big16g
WRB 4.444fd Enginuity,E85
Default utec w/ ecuflash
ok i have my car tuned with utec, would reflashing the stock ecu to a map closer to the utec values make the transition from ecu to utec smoother, also should i reflash the ecu with 550cc injector info since i have them, or since the utec is controlling fuelling does it matter.
frdawg is offline   Reply With Quote
Old 11-27-2006, 03:36 PM   #2
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
I am not very knowledgable about UTECs but I believe they are different than stock ECU and they're not a basic swap conversion. I know there are people here that have done it here so if one of them can chime in, they'll be more helpful. My post is pretty useless
Ziggyrama is offline   Reply With Quote
Old 11-27-2006, 03:41 PM   #3
frdawg
Member#: 24129
Default utec
what I mean is my ecu is stock, my utec is a stage 4 map, if my ecu had a reflash that was closer to stage 4 when the utec takes over it shouldnt be as much of a difference in timing,fuel etc...
Old 11-28-2006, 08:04 AM   #4
TheMadScientist
Member#: 23717
2005 Big red
Set up the stock ECU/reflash to be your low boost safe running map, with the Utec set to map0. Then use the utec for the high boost high power maps. To do this corectly you will have to jump the MAP sense so the stock ECU "sees" the real MAP voltage for boost control.
You should have a much smoother car after the reflash, as the Utec is not doing as much "work" to get the tune where you want it.
TMS
TheMadScientist is offline   Reply With Quote
Utec over Ecuflash gaby UTEC 12 12-13-2006 10:39 AM
New GUI version of EcuFlash reflashing tool colby Engine Management & Tuning 5 05-11-2006 08:30 PM
ECUFlash and the ST darksands Engine Management & Tuning 4 12-08-2005 11:15 PM
OBD-2.com cable compatible with EcuFlash? IndyRacer Engine Management & Tuning 2 12-05-2005 11:55 AM
Wtt/wtb: Utec Utec Utec Utec Utec TRUDAWG Private 'Wanted' Classifieds 0 07-31-2005 10:41 PM
