Old 11-25-2006, 09:42 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default How To Deal With Really High Torque Bolts
I've been working on my car on my own for a while now, and an upcoming mod has got me worried. I'm used to working with bolts requiring up to about 70 ft-lbs of torque and have since acquired a torque wrench covering 10-70 ft-lbs. However, some of the bolts with which I am about to deal have a spec of 168 ft-lbs. How on earth do you a) get them loose when you're jammed under the car and can't attach a 40ft long pipe to your breaker bar and b) torque them back to spec? I can find a torque wrench that is affordable by mere mortals (NASA maybe) that will go that high. So what am I supposed to do?
Ty
Old 11-25-2006, 09:56 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Use a breaker bar to remove them (I replaced the rear transverse link bushing on my car - used a 1/2" drive, 18" breaker bar to remove the bolts to the frame (180 ft-lbs), then a box wrench to remove the nut holding the bushing to the control arm (used leg power for that one since the wrench is much shorter - torque spec is 140 ft-lbs)) - torqueing things back down - well, for the nut holding it to the control arm, since I couldn't get a torque wrench on there, I just put it on really, really tight using my legs. For the bolts to the frame, I have a 1/2" drive torque wrench (craftsman) which is 25-250lbs, so I used that. Not a problem (as an aside - we don't really have a road salt issue down here, so rust wasn't a problem - for you, I would make sure I hit everything with pb blaster and give it some time to work first)
DrD is offline   Reply With Quote
Old 11-26-2006, 12:43 AM   #3
leecea
Member#: 37359
2003 WRX
Hitting wrenches repeatedly with a large hammer often works. It can be very hard if you can't get a socket and bar on there. The Sears torque wrench is not too bad - http://www.sears.com/sr/javasr/produ...id=00944597000
leecea is offline   Reply With Quote
Old 11-26-2006, 01:12 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The Sears wrench looks nice. Definitely a contender. However, I'm planning on doing an alignment at the end of this. That means the car will be on the ground and I'll still need to swing the wrench. I think that's definitely too long. Any other options?
Old 11-26-2006, 01:13 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Most of us "pro shadetree" guys use the "Gorilla method", which is a scale of 1 to 5 gorillas. 1 being exhaust, 3 being lugnuts, and 5 being suspension bolts. a wrench + dead blow hammer is a terrific tool, otherwise you need some cheaper pipe to create leverage. A dead blow hammer is the "torque wrench" of hammers as that shot flying around inside the hammer multiplies the force by about eleventy billion. I wouldny stress too much about specs, as long as you tighten the hell out of those big suspension bolts, you'll be alright.
Old 11-26-2006, 05:05 AM   #6
nerdydorkus
Member#: 67062
please.. just spend 10-15 bucks for a whole set of breaker bars.
and DO NOT use your torque wrench to break bolts..
harborfreight.com
nerdydorkus is offline   Reply With Quote
Old 11-26-2006, 02:03 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
harborfreight.com
I never claimed I was using a torque wrench to break bolts loose. Why would I do something so stupid? It's a precision instrument. In fact, in the OP, I mentioned that I have a breaker bar.
Old 11-26-2006, 02:03 PM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So just banging a few times on the end of a 24" breaker bar is sufficient to prevent keystone cops moments of wheel separation?
Old 11-26-2006, 04:52 PM   #9
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
....d00000d.....there are some HUGE idiots around here ....and you will be AMAZED at some of the incredibly stupid things that get posted.
Misuse of tools is one of the LEAST of these...
Old 11-26-2006, 04:56 PM   #10
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
my favorite torque problem:
http://forums.nasioc.com/forums/showthread.php?t=719262
(How do I apply 164 ft-lb of torque to a smooth ball?)
Mike Wevrick is offline   Reply With Quote
Old 11-26-2006, 05:31 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh. Dear. GOD.
I don't have the words.....
The most amazing part is that it's actually kind of a good question from a mechanics (as in physics) perspective. But the answers.....
Old 11-26-2006, 10:39 PM   #12
Mike Wevrick
Member#: 24654
1957 Taggart Comet
There were some good suggestions, and I'm pretty sure some of the bad ones were jokes.
Old 11-27-2006, 10:00 AM   #13
Boxologist
Member#: 21118
can't beleive i missed that thread
Boxologist is offline   Reply With Quote
Old 11-27-2006, 10:16 AM   #14
rkramer
Member#: 118209
2015 WRX Limitec
2 words... impact wrench.
rkramer is offline   Reply With Quote
Old 11-27-2006, 11:23 AM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I thought impact wrenches always banged away at their maximum rated torque. Can they be turned down to a precise setting?
Old 11-27-2006, 11:42 AM   #16
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Sheesh, nobody noticed the nut on the bottom huh?
Pretty much any 1/2" drive torque wrench should go to 168 ft/ lbs. And you should be able to produce the amount of force needed to achieve the "click". IT's alot, but your a man right?
No offense ladies.
Tim Sanderson is offline   Reply With Quote
Old 11-27-2006, 11:57 AM   #17
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^Read more carefully. Applying torque to the nut is easy; the problem is keeping the ball from rotating along with it.
Old 11-27-2006, 12:01 PM   #18
crash#2
Member#: 112128
2002 wrx
sedona red pearl
impact socket head, breaker bar. start with a gentle kick. if that doesn't work, hit it a little harder until it does. works well with eccentric bolts
crash#2 is offline   Reply With Quote
Old 11-27-2006, 12:24 PM   #19
Mike Wevrick
Member#: 24654
1957 Taggart Comet
3 words ... don't have one
Anyway, its an old thread; I got the bolt on and it seems quite solid.
Old 11-27-2006, 06:05 PM   #20
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
two words:
Lock
Washer
Old 11-27-2006, 06:53 PM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
wow, you know, I think I've seen this discussion in another thread. Could it perhaps have been in the thread initially discussion the hitch problem?
Old 11-27-2006, 07:15 PM   #22
4pOwnag3
Member#: 53200
2005 LGT
from personal experience: was taking off exhaust from a fellow subby owners car, the bolts were so rusted that they wouldnt bugde, after about 1/3 bottle of pb blaster i tried a new technique. . . i put the pipe around the wrench and carefully lowered the car untill the cars weight torqued and broke the bolts.
- not the best way to do it, but when you have limited choices you make it work.
4pOwnag3 is offline   Reply With Quote
Old 11-27-2006, 11:33 PM   #23
Mike Wevrick
Member#: 24654
1957 Taggart Comet
^^I used the same trick to loosen the plugs in my rear diff, and a few other places.
Originally Posted by Tim Sanderson View Post
two words:
Lock
Washer
3 words: Read more carefully. It has one.
Having an issue with the GF, how to deal with it. MattSEG Off-Topic 100 02-15-2007 04:36 PM
An interesting story of how to deal with Islamic extremist wolf8314 Political Playground 61 05-21-2004 11:57 AM
Jealousy. How to deal with it? 2.5RSMatt Off-Topic 39 11-04-2003 07:53 AM
Friends, and how to deal with them. bruticus Off-Topic 5 09-08-2003 01:36 PM
