Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 11-27-2006, 05:38 PM   #1
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Default Transmission ideas
Well I could post this in the transmission thread, but I thought I would ask my Legacy Brethren.
I thought it would last longer, but my 3rd gear pooped.
I was just shopping and coming home I have a steep hill. Going up the hill some horrible noises came out of the transmission. 3rd gear is gone.
I limped home in 1st, 2nd and 4th.
What would you replace the tranny with?
Kraziken is offline   Reply With Quote
Old 11-27-2006, 06:00 PM   #2
MannySoobia
Member#: 22139
2008 FXT Sport
Gee-Are-Pee
Well ken, If you have enough money I would go for the STI 6, Or I think Cobb has a Racing 5 spd for sale too.
Otherwise just go with a WRX tranny. Unless you don't like the final drive that is.
Lot's of choices bro
Forget about the Cobb Tranny. I just went to the site and didn't even see the sale section anymore. Then again the site is newly overhauled. I'm sure if you are interested you can call them an ask about tranny's
MannySoobia is offline   Reply With Quote
Old 11-27-2006, 06:32 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Best bang for the buck would be to outfit your existing 5MT with a performance gear-set. PPG is one option and makes a nice 1-4 syncro helical set for that model of tranny. One thing to note is that you SHOULD NOT continue to drive on it. Any gear fragments floating around in there can get lodged in other gears, syncros, or worst-case (and I’ve seen this) the front diff…
Not sure who in your area is a PPG reseller. I know Xcceleration does PPG, and of course my favorite, the nations largest PPG retailer, Andrewtech/Gearboxtech. They also do nationwide shipping. Pull your tranny, make a small wooden crate, ship it off ground service, and they’ll return it the same way fully built and ready for re-install.
PPG
xcntrk75 is offline   Reply With Quote
Old 11-27-2006, 06:46 PM   #4
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
So how would an adventure like this set one back?
Seems to be a better option than dealing with the DCCD wiring nightmare...sure its nice...If it'll ever work
Sneeky Pete is offline   Reply With Quote
Old 11-27-2006, 08:56 PM   #5
ten80
Member#: 53625
00 EJ205 LGT LTD
another option is a JDM 4.11 WRX 5mt. They run right around $700-1000 and have shot-peened gears and nice ratios. Should hold STi power just fine up to 300whp or so.
ten80 is offline   Reply With Quote
Old 11-27-2006, 10:54 PM   #6
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
My vote goes for the custom PPG gearset. A 6MT would be nice, but you're making enough power that shifting it all the time would become tedious.
Wiscon_Mark is offline   Reply With Quote
Old 11-28-2006, 02:25 AM   #7
Kraziken
Member#: 38629
My plans were to use this tranny until I could afford a 6 speed.
I guess now the question is, do I try to find another small band aid fix, or go full STI 6 speed. The problem is timing. Just before the holidays, plus my wife hasn't been working the last four months (new baby) that splurging for the STI 6 would be tough.
I was wondering if there was another set of gears I could use that would not be as expensive. I had the impression the PPG gears are pretty pricey.
Oh, I guess I should mention I used my Legacy tranny because I don't like the gear ratios of the WRX.
Old 11-28-2006, 02:35 AM   #8
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
wrc sequential tranny? I heard they just leave those laying about the service areas, stuff one in your suitcase. Rally GB is coming up...
biggreen96 is offline   Reply With Quote
Old 11-28-2006, 07:12 AM   #9
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Wait a minute; aren’t you running the LGT internals inside a wrx case to get the new clutch style setup?
If that’s so you’ll need to fix that tranny or switch over to an OE wrx model with stronger gears and install your front-diff or R&P. Those are the only cheap options. There are the less-expensive RA gear sets available too (i.e. shot-peened like jdm) but no idea if they’ll fit your unique tranny setup, plus are arguably no stronger then the 04+ wrx gears, plus people blow RA’s frequently too.
The PPG or STi 6-speed options are both in the same pricing category. Around 5k for a fully built 5MT PPG box (1-4) or 6k for sti tranny and misc parts. The only downside to the STi tranny is all the augmenting modifications required, new rear diff setup, new rear axle setup and/or rear hub setup, new driveshaft, dccd, etc. I could see the costs snowball quick for the sti setup…
Good luck…
Old 11-28-2006, 07:44 AM   #10
Kraziken
Member#: 38629
yep, this is the case.
I'm going to ask my contact today. The new legacy gt uses a 4.11 final drive. So I'm wondering if it is possible to take those gears and put it in my case. It might be a cheaper solution that will work with the power I'm pushing.
Old 11-28-2006, 02:56 PM   #11
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I'm going to ask my contact today. The new legacy gt uses a 4.11 final drive. So I'm wondering if it is possible to take those gears and put it in my case. It might be a cheaper solution that will work with the gear splitting crazy sti powa I'm pushing.
Fixed it for ya
Old 11-28-2006, 05:48 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
FWIW, I picked up a full STI tranny/rear end/axles setup on Ebay for about $3500 shipped. I don't intend to use the R180, so I'll sell that to recoup some costs and it makes the swap that much less involved.
Pat
RWD Subaru Transmission Idea JustinOlson Transmission (AT/MT) & Driveline 12 12-12-2009 01:54 PM
Upgraded Transmission Ideas coqui2004miguel Alaskan Impreza Club Forum -- AKIC 18 11-07-2009 02:02 PM
Need Transmission Upgrade Ideas TheShadowWRX Transmission (AT/MT) & Driveline 7 05-02-2006 11:09 PM
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken ciper Transmission (AT/MT) & Driveline 6 06-05-2003 03:54 PM
Crazy Idea For A "Bullet Proof" Transmission subarumantoo Transmission (AT/MT) & Driveline 1 12-26-2001 11:50 AM
