Old 11-27-2006, 07:26 PM   #1
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Default How to check if I do indeed have ECUtek?
Just curious if theres a way to check the ECU to see if I do infact have the ecutek software?
Im am suppose to have it, but I want to make sure before I install my VF39 and go and try to get tuned.
JeffrWRX is offline   Reply With Quote
Old 11-27-2006, 07:39 PM   #2
hondaeater69
Member#: 60324
i think a EcuTeK dealer would have to look at it with their SW to see if the license is thar.
Old 11-28-2006, 07:14 PM   #3
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
ok thanx
Old 12-10-2006, 10:38 PM   #4
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
you could try changing between the high/low maps ..
try it like this - floor it, once you feel like you cant go faster push defrost button. did your boost jump up or down a bunch?? if yes - its ecutek, if no - its not.
from http://ecutek.com/products/mapswitch/
Switching Maps
EcuTek Map Switching allows dynamic selection of two sets of performance levels. To switch between these performance levels, the driver simply holds full throttle and toggles the rear heated window switch from off to on. This may be done with the engine off or on, so long as the ignition switch is on. The performance levels may also be switched from DeltaDash using the User Tuning feature.
How it Works
EcuTek have customised the function of the software in the ECU to allow dynamic switching between two sets of performance maps. Selection of the performance level via the car dashboard or DeltaDash determines a choice between two sets of boost control configurations within the ECU. One setting might be for a constant 0.5 bar (7 PSI) whilst the other might be 1.2 bar (17.5 PSI), tapering to 1 bar at the redline.
Applications
The two performance levels may be specified by you to your chosen EcuTek tuning partner. You may choose to have one performance level for road use and on for drag racing. Alternatively, you may choose to have a high performance and an economy mode.
How to get it
To use map switching on your WRX, your ECU must be reprogrammed with a special map switching ECU calibration. If you have already had your ECU reprogrammed by an EcuTek tuning partner, contact them for an upgrade. If you are a new customer, simply choose an EcuTek partner from the dealer list and specify that you would like the map switching feature when your ECU is tuned.
ronaldwrx is offline   Reply With Quote
Old 12-11-2006, 12:46 AM   #5
Gethin
Member#: 2998
^^^ That's assuming his tuner flashed 2 different boost maps......
Gethin is offline   Reply With Quote
Old 12-25-2006, 02:41 AM   #6
B16A2NR
Member#: 88676
So your saying that every ecutek programmed ecu has the ability to switch between two maps using this technique? Or is that an upgraded ecutek tool?
B16A2NR is offline   Reply With Quote
Old 12-25-2006, 03:47 PM   #7
B16A2NR
Member#: 88676
Bump for a response to a question thats burning a hole in my soul.
Old 12-25-2006, 03:55 PM   #8
LateApex31
Member#: 135686
Read the responses pal.
Originally Posted by ronaldwrx View Post
How to get it
LateApex31 is offline   Reply With Quote
Old 12-26-2006, 12:43 PM   #9
hondaeater69
Member#: 60324
actually it's not every EcuTeK flashed ECU... IIRC it only works on certain MY's... and i don't think it works on STi's. I think the 02 wrx does have the ability to have two seperate boost maps though.
Old 12-29-2006, 01:08 PM   #10
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
I believe the two boost option (EcuTeK maps) is available on the 2002 WRX ecu......maybe 2003 ecu also but not the 2004+ WRX ecu.
I have a 2005 WRX with a 2002 or 2003 (the seller told me 2002, the tuner said it's a 2003...whatever!) ecu and I asked for the two boost option maps.
Kosmic is offline   Reply With Quote
How to Check if AVCS is on. Tirpitz56 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-16-2007 12:47 AM
How to check if the bpv is leaking? albie1kanobi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-23-2007 11:12 PM
How to check if the shocks are dead? bwco Brakes, Steering & Suspension 7 12-25-2003 03:44 PM
how to check if someone died Keith Off-Topic 16 11-21-2003 01:25 AM
How to check if my alternator is working ? NicEJ25 Electrical & Lighting 2 05-25-2003 01:54 PM
