Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 11-27-2006, 08:33 PM   #1
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Default installed the unabomber's sexy rear end
the one from turninconcepts.com that is. i put the bushings in bout a week ago and i could feel the difference with the rear in corners. i was able to coherse my manager into lettin me get my car on the alignment rack to put in the sub frame lock bolts. (were not allowed to work on our own cars) i wanted to read up an see what TIC had to say about the bolts before i put them in. it really changed my alignment too. had to acutally pay for that this time, but oh well. i had to move the subframe forward on the L-side to get the bolt in so that threw my front toe out a fair amount. didnt get a chance to get into her on the way home, but rest assured i will test out how this rear feels
romanlynch is offline   Reply With Quote
Old 11-27-2006, 10:02 PM   #2
JayD707
Member#: 51018
2005 Legacy
Well, I can tell you how the rear will feel...
MUCH more stiff and responsive.
Excellent mod.
JayD707 is offline   Reply With Quote
Old 11-27-2006, 10:24 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
got a pic of this sexy rear end?
which parts are these again?
Shane
PARANOID56 is online now   Reply With Quote
Old 11-27-2006, 10:30 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Shane
Ron's sexy rear end has three parts. Left cheek, right cheek, and crack.
I'm sorry - I couldn't resist.
It's made up of the race version of the rear diff mount bushings, race version of the Kartboy outrigger bushings, and the Whiteline rear subframe lock bolts.
Old 11-27-2006, 10:37 PM   #5
PARANOID56
Member#: 22035
2003 Brocoma DCab
that’s not a pic, that’s just a description.
hmm, how much does that increase noise? and dont need the kartboy stuff, already have 99% of what they make
Shane
Old 11-27-2006, 10:50 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
thatís not a pic, thatís just a description.
Shane
Old 11-27-2006, 11:30 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
ha, great image name
guess, i will be ordering shortly
Shane
EDIT, maybe when you site comes back up
Old 11-27-2006, 11:51 PM   #8
Scooby921
Merci Buckets
Member#: 88606
2016 Focus RS
2017 Lincoln Continental
can we change the title to "trying" or "using" instead of just "installed"?
I'm not sure what the lock bolts do performance-wise, but I can say the diff bushings are awesome. If I get another decent day around here I've got some outrigger bushings to install as well.
Scooby921 is offline   Reply With Quote
Old 11-29-2006, 07:06 PM   #9
romanlynch
Member#: 126684
02 wrx
i dont think that changing the title of this thread would look good on me considering my strong religious backround . anyways, i do feel the difference from just the bushings and adding the lock bolts. the pass. side went in ok, the drivers side i had to move the subframe forward bout 1/8". this in turn knocked out my drivers side toe to + 0.62, and then the rear needed a lil tweak as well. overall i am glad that i installed the kit. also im happy that im one of the few that can say
"Well, I can tell you how the rear will feel...
Excellent mod."
(thanks jayd707)
Old 11-29-2006, 10:01 PM   #10
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Glad you like my rear end.
Old 11-30-2006, 06:12 PM   #11
Fmjhp594
Member#: 120743
2006 WRX STI
So what does the lock bolts do exactly? Do they replace the studs on the back of the diff? Just a little lost and couldn't find an answer.
Thanks!
Fmjhp594 is offline   Reply With Quote
Old 12-02-2006, 12:47 PM   #12
romanlynch
Member#: 126684
02 wrx
u can get the info at www.whiteline.com.au but it locks out the rear subframe bushings by connecting the subframe to the frame. apparently subaru does this on the assembly line when the first align the cars to get a more precise alignment, then they take out the bolts. anyways there is a pic an install instructions that should give u a better understanding
http://www.whiteline.com.au/docs/ins...200_KSB750.pdf
hope this helps
Old 12-02-2006, 04:42 PM   #13
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You'll probably also find like I did, that your rear end is WAY out of whack when you install the subframe bolts. Not only does it align it, but they remove 100% of the bushings' compliance back there for a firmer rear end. Be sure to get your alignment checked if/when you get them as it WILL be off.
Old 12-02-2006, 05:00 PM   #14
Fmjhp594
Member#: 120743
2006 WRX STI
Sweet! Thanks for the info!
So if you leave them in all the time it will cause wear on the frame. So if you take them out between races, like it says on that pdf file, wont it mess up the rear end's alingnment?
Old 12-08-2006, 01:57 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
uee!!! my next mod....muahahah actually...the KAAZ LSD then this...I need the car to run first...damns....I need to get the bearing clamp and do my front wheel bearing...lols
FuJi K is offline   Reply With Quote
Old 12-09-2006, 09:30 PM   #16
romanlynch
Member#: 126684
02 wrx
i just went through some rear diff things recently and this is some of the stuff i didnt know
Well, the RS and MZ work differently. RS is a lot more responsive and its low initial torque setting gives it more ďbiteĒ. RWD cars that use CUSCO diffs typically use RS diffs. But then once again, it really depends on the tuner and the car. Itís all a matter of setup. I do know, however, that type MZ makes less noise.
You can reduce some of the noise by using different diff oil. I would recommend some Redline Light Duty Shockproof oil (blue stuff) and add some Redline slipping modifier into it.
Your car is similar to early JDM WRX/ WRX RA. If you had an RS, youíd be in trouble.
Diffís lock up does not go by %. LSDís always lock up, what you can change is how progressively quick it locks up and at what torque.
For gear sets, I would not bother with any aftermarket gear sets. RA gear set seems to be the most common upgrade. My preference is the 6MT non-DCCD swap. But RA set is the next best thing.
Quafe is nice. Itís mechanics are totally different and they donít make nearly as much noise. KAAZ are the dynosaurís of the LSDís. Very primitive and very aggressive. Even more so aggressive than RS cusco diffs.
If the dealership installed it, it should be installed correctly.
You just need to get used to the diff and how it works. It should work well for you. Low speed tight tracks will make your car understeer. You also have to remember, that your driving style has to change a bit. The car needs to be tossed around more and you must retain it in its powerband. Other wise the car will plow because the diff is locking up.
Donít stress. Try the oil I am suggesting and I think you will like it more.
i got it from www.z1auto.com but i would recommend goin to http://www.cusco.co.jp/english/e_cont.html if u are interested in a cusco. Bozz performance seemed to me to be a lot more helpful then Z-1. but thats my opinion
Old 12-10-2006, 03:12 PM   #17
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
What does that have to do with Unabomber's ass?
Counterfit is offline   Reply With Quote
Old 12-11-2006, 07:36 PM   #18
romanlynch
Member#: 126684
02 wrx
to let him know, just passin info on
Old 12-11-2006, 09:11 PM   #19
PARANOID56
Member#: 22035
2003 Brocoma DCab
ohh, my box of Unabombers sexy rear end just showed up. i would have figured that his rear end was much bigger then this, but either way. way cool. lots of free goodies from TIC as well.
TIC you rock
will install soon.
Shane
Old 12-11-2006, 09:23 PM   #20
Turn in Concepts
Member#: 93646
Many Track Records
TIC you rock
will install soon.
Shane
There is no way you can tell me Tom has ever sent you that many goodies. evAr!!
Old 12-11-2006, 09:28 PM   #21
PARANOID56
Member#: 22035
2003 Brocoma DCab
um, i think you are corect. This is the first time i have seen this many army men at once
Shane
Old 04-02-2007, 11:10 AM   #22
gregor2001
Member#: 84443
2012 STI Ltd WRB Sdn
2009 OBS Silver WifeWagon
Just wanted to share that I too installed this kit over the weekend and omg, especially the addition of the rear diff bushings, it feels great!!
Thanks to Clint at TiC for the info/quick shipment/army men and to all the folks who posted opinions/install notes - made it pretty easy to do myself.
I would recommend to anyone who wants to get rid of some of the sloppy play they feel in the rear end. I ordered the comfort version of both bushings and so far the NVH increase is barely noticeable.
gregor2001 is offline   Reply With Quote
Old 04-02-2007, 11:45 AM   #23
MasterKwan
Member#: 98961
2003 WRX
How much concern is there for the "premature wear" clause in the instructions?
Old 04-02-2007, 12:04 PM   #24
romanlynch
Member#: 126684
02 wrx
ill let u know when the rear falls out... but seriously, i put the lock bolts in and like it a lot. i think they just have to put that in there so there are no repercussions if something were to happen, like someone forgets to tighten the subframe back up or somethin. u can get the kit without the lock bolts to, i think its called the klunk killers race or somethin like that. id say go for the lock bolts tho. i was amazed at how off my alignment was after installed them.
Old 04-02-2007, 03:03 PM   #25
RayO
Member#: 42329
2002 WRX sedan
I've had subframe lock bolts in my 2002 for 70k miles.
The note about premature wear worried me, too. People on here who know told me not to worry, and they were right.
RayO is offline   Reply With Quote
Unabomber's sexy rear end combo review Unabomber Transmission (AT/MT) & Driveline 59 05-20-2014 02:41 PM
TIC unabomber's sexy rear end SQ3.0dotJP Car Part Reviews 25 05-16-2012 03:42 AM
WTB (NC): Kartboy Pitch Stop, GroupN Motor/Tranny Mounts, Unabomber's Sexy Rear End jstalford Private 'Wanted' Classifieds 12 02-13-2009 02:14 AM
Klunk killers & Unabomber's sexy rear end in stock - with prices posted Turn in Concepts Drivetrain 8 08-05-2008 07:54 AM
Does the UNABOMBER Sexy Rear End qualify for BSP? Kurokaze Motorsports 6 04-16-2007 01:56 PM
