Old 11-15-2001, 06:42 PM   #1
subarud
Gone.. But not forgotten
Member#: 9863
02 WRX Blue & Fast
91 S10 Red & Abused
Default turbo hoses
I have been reading a lot of posts lately about mbc's, ebcs, and bleeder valves. I even made the $4 mbc. I noticed how there is a restrictor in the line that goes from the turbo outlet to the tee. I was wondering what the effect would be if you somehow put more restriction in one of the lines or even pinched one of the lines (either from the turbo to the tee, tee to fbc, or tee to wastegate). Any comments would be appreciated.
subarud
subarud is offline   Reply With Quote
Old 11-15-2001, 11:25 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I think you may want to post this (or have it moved by a moderator) to Factory Forced Induction. I don't think this is a very newbie question to ask, and the people who are likely to answer your question are probably not avid readers of this forum But who knows...give it a day.
jblaine is offline   Reply With Quote
Old 11-15-2001, 11:33 PM   #3
PunksWRX
Member#: 5504
2004 Impreza WRX STi
You would overboost as you would reduce or eliminate the signal to the factory boost control selenoid and the wastegate actuator. Guys running the Unichip are given a restrictor hose with a smaller diameter restrictor. This raises the boost the engine sees. If you completely plug it off the turbo would boost until fuel cut.
Punk
PunksWRX is offline   Reply With Quote
sri hose to turbo hose connector jdgrimm General Community 2 05-17-2006 02:59 PM
02 WRX:need a stock IC to turbo hose and BOV hose Wazoo Racing New England Impreza Club Forum -- NESIC 3 03-14-2005 11:03 PM
Turbo Hose Ethan Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-21-2002 02:07 AM
Dyno data on "Samco" turbo hose paulw Factory 2.0L Turbo Powertrain 1 01-14-2002 03:17 PM
restricted turbo hose subarud Factory 2.0L Turbo Powertrain 1 11-16-2001 08:59 PM
Message Board Statistics All times are GMT -4. The time now is 04:51 PM.
