Old 11-28-2006, 02:05 AM   #1
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Default Installed 04 Sti Cluster into my car and now my Alpine has no power.
Its late and I havent had time to investigate but like the title says, I installed an Sti cluster and now my deck wont turn on.
I was thinking Fuse, or somehow shorted it out b/c i had to move my boost gauge which is wired off the deck harness. Although i didnt un attach any wires maybe 1 could have wiggles loose? The gauge still lights up though.
Thoughts or ideas on things i should check tomorrow?
-Jeff
JeffrWRX is offline   Reply With Quote
Old 11-28-2006, 02:11 AM   #2
ThisizBrian
Member#: 106117
can u try the alpine w/ the cluster unplugged?
ThisizBrian is offline   Reply With Quote
Old 11-28-2006, 02:20 AM   #3
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Noted...I will try that tomorrow
FYI i didnt disconnect battery while installing the cluster.
Old 11-28-2006, 02:27 AM   #4
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
you didnt research NASIOC before installing your cluster.
On the bugeyes, you have to clip an Outside Temperature probe wire BEFORE installing it or it will blow your radio fuse and infinite amount of times as you replace it.
Look it up, its been covered
WRXDriftR is offline   Reply With Quote
Old 11-28-2006, 10:44 AM   #5
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Doh!! I bought it from a friend who had it in his 05 RS...he did the install. Go figure. I will search and fix it tonight.
Thanks!
-Jeff
Old 11-29-2006, 12:09 AM   #6
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Fixed it...had to cut wire B28...middle connector, pin28. Green/Yellow wire next to the red wire.
All is well.
Thanks guys.
-Jeff
Old 11-29-2006, 01:09 AM   #7
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
there ya go!
NASIOC is great if you use it absolutely every time before you even pick up a tool to mod!
Old 11-29-2006, 12:18 PM   #8
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
I always do...but this guy was 100% sure that he knew what to do. Last time i trust anyone (i have always done my own installs)
-Jeff
Old 12-28-2006, 11:52 AM   #9
Chapel
Member#: 3496
1995 Roadmaster
Beige
All is well.
Thanks guys.
-Jeff
AHHH!
Thank you!
I'm trying to compile a list of these things to get this sorted. you answered the question
THAT'S what B28 is for
Chapel is offline   Reply With Quote
Old 12-28-2006, 03:05 PM   #10
Chapel
Member#: 3496
1995 Roadmaster
Beige
how's that?
Old 12-28-2006, 09:06 PM   #11
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Wow tahts awesome...thanks. No problems with the cluster since i cut that wire.
ABS, DCCD, REAR DIFF lights are always on, but oh well.
-Jeff
Old 12-28-2006, 09:23 PM   #12
Chapel
Member#: 3496
1995 Roadmaster
Beige
you can ground pin B4 on the harness to get rid of the diff light
just tape the ABS light.
I left the DCCD alone.
http://forums.nasioc.com/forums/show....php?t=1166573
here's the FULL fix if you have an 05 STi cluster.
Old 02-10-2007, 12:10 AM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
So there is no way to make ABS light functional?
Old 02-10-2007, 12:45 AM   #14
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
subscirbe for the answer.
Honest Bob is offline   Reply With Quote
Old 02-10-2007, 10:08 AM   #15
Chapel
Member#: 3496
1995 Roadmaster
Beige
which answer?
I've answered everything but the ABS light in that thread^
Old 02-10-2007, 11:45 AM   #16
sc00ter
Member#: 117767
2015 WRX
CWP
As of right now none of us (that I know of) have gotten the ABS light to be functional.
sc00ter is offline   Reply With Quote
Searched many threads.. 04 sti cluster into 06 sti car with 05 rs dash wiring PATR1KI Electrical & Lighting 2 04-14-2010 06:38 AM
Just installed 07 STi cluster into my 07 WRX jonpark Electrical & Lighting 1 05-21-2009 06:30 PM
How do I install a USDM 04 STI cluster into my 02 WRX Nitrousspeed Interior & Exterior Modification 1 04-18-2009 07:36 PM
04 STi Cluster into 04 WRX Jubert69 Interior & Exterior Modification 5 02-24-2009 05:19 PM
04 sti cluster into 04 wrx acheung Electrical & Lighting 1 05-23-2007 11:16 PM
