Old 11-28-2006, 08:27 AM   #1
NYCshopper
Member#: 5126
Default Full Test: 2007 BMW 335i Coupe (edmunds.com)
Click Link for Video Review:
http://www.edmunds.com/insideline/do...ticleId=117669
The case for M-power just got a lot weaker
The data doesn't make any sense. We're tearing our collective hair out trying to determine why the track-test numbers from our 2007 BMW 335i test car are so far off.
Our freshly minted 3 Series twin-turbo coupe has not only eclipsed BMW's own impressive performance figures — by a ton — it's also smoked those of the 2005 BMW M3 Competition Package, a car we called "The Best M3 Ever Sold in America." And while that admittedly turbo-deprived car had been a six-speed manual, the Arctic Metallic 2007 BMW 335i Coupe cooling in the driveway is but an automatic. Nothing about our Austrian First Drive of the car prepared us for this.
More than half fast
Consider the facts: This 2007 BMW 335i test car blazed from zero to 60 in 4.8 seconds. BMW says the new coupe mit twin-turbo engine and Steptronic six-speed autobox should make that trip in 5.5 seconds. Seven-tenths of a second quicker? That's 13-percent better than BMW's claim. Folks give aftermarket tuners wads of cash for that kind of performance bump, especially when a car starts out in the mid 5s to begin with.
Our 335i similarly scalded the quarter-mile in 13.3 seconds at 105.9 mph. For comparison, our 2005 M3 Competition Package used up 5.5 seconds getting to 60 and finished the quarter-mile in 13.7 seconds at 105.4 mph — close, but still a rearview-mirror performance. We almost beat the all-powerful 2007 Audi RS4, too. Despite a 120-horsepower advantage and all-wheel-drive launch superiority, it just nicked our 335i's 0-60 and quarter-mile times by a paltry 0.1 second each.
Something's up. Could BMW be soft-pedaling the output and performance numbers to leave marketing headroom for a more outrageous 2008 M3 V8 to come? Did the luck of the draw or some other means provide us with an overachiever? We've gotta check into this.
Dyno hum
There can be no doubt that BMW's new twin-turbo 3.0-liter straight-6 engine, complete with direct injection and a high 10.2:1 compression ratio, is impressive. Two smaller snails were assigned to only three cylinders each so they'd spin up faster, reducing lag and increasing torque at low engine speeds. Boy, does it work, as this beastie is rated at 300 hp at 5,800 rpm and 300 pound-feet of torque spreading from 1,400-5,000 rpm. In a rear-drive coupe weighing in at 3,579 as-tested pounds, that sounds about right — for 5.5-second 0-60 bursts, that is.
In order to see what she's really putting out, we've brought our 335i to the chassis dynamometer at MD Automotive in Westminster, California. And since chassis dyno figures are always lower than manufacturer ratings because the former includes drivetrain losses and the latter does not, we've secured the help of an alert reader who has volunteered his month-old 335i for comparison. Steve Harrison's identically equipped 335i automatic is fresh off a trip up the California coast and all broken in. We should be able to tell if our press car's performance is unique or not.
After a short time, two sets of fresh numbers sit before us. Steve's car produces 272 rear-wheel hp at 5,970 rpm. Considering drivetrain losses, he's easily seeing the promised 300 horses at the flywheel, probably more. Our test car produces a similar 273 at 5,970. But wait, there's more: While Steve's motor gently tapers off as rpm exceeds six grand, our mill continues to make more power until it tops out at 279 at 6,295 rpm, at which point Steve's 335i lags 19 ponies behind. Notably, our car maintains its advantage for the remainder of the rev range.
So what's up?
A comparison to BMW data shows that Steve has nothing to be worried about, as his 335i's rear-wheel output curve looks about right when compared to factory flywheel data. Our car is simply stronger in such a way that makes our pavement-melting 4.8-second 0-60 more understandable. But why?
We're glad you asked. MD's dyno can also measure turbo boost during runs. It turns out that at any given rpm in the disputed region between 5,000 and 6,500, our car consistently makes about 0.5 psi more boost. Subtle, but a little goes a long way. Is this mere production variation? We can't dig deep enough to know for sure. If anything, this exercise underscores the potential of aftermarket chip tuning. Ain't electronically controlled turbo engines fun?
For the record, during a desert freeway assault to Vegas at an average speed we don't care to print, the 335i achieved 25.9 mpg, compared to a 29-mpg EPA highway rating. With a lot of city and freeway stop-and-go thrown in, the overall average drops to 20.3 — just above the 20-mpg EPA city rating. With less lead in the shoes, the EPA figures actually seem attainable.
Enough already
Even though the motor is the main thrust of the new 335i, we're sure some of you want to know about the car it sits in, the E92 3 Series coupe. Track and dyno numbers are all well and good, but what's it really like?
In highway cruise mode, such as our L.A.-to-Vegas dash, stability and on-center steering feel are autobahn-grade, as the coupe tracks straight and true while giving copious feedback through a fixed-ratio 16-to-1 steering gearbox. We're not certain how the $1,250 active steering option, absent here, could make it much better.
Contorted canyon roads are no match for it either, as the E92 slices cleanly through corners like a Ginsu knife and sticks like Super Glue, as evidenced by our 68.4-mph slalom run, the best 3 Series number we've recorded recently, M or otherwise. The dual-pivot front strut suspension is certainly at work here, as is the 335i coupe's standard sport suspension, uniquely tuned to suit its more athletic persona.
Yes, the 0.88g skid pad figure lags slightly behind the M3 Competition's 0.92g, but we're chalking that up to the 335i's lack of a limited-slip differential, which the M3 had along with bigger-still 19-inch high-performance tires. And it's hardly worth mentioning that stopping distances from 60 mph are 2 feet longer as well. Who's gonna complain about 114 feet with a rock-solid pedal and excellent feel?
Despite the firmer springs, larger stabilizer bars, half-inch-lower ride height and optional 18-inch Bridgestone Potenza RE050A performance run-flat tires — part of the $1,000 Sport Package — it rides at least as smoothly as our long-term 2006 BMW 330i sedan. Road coarseness is nicely filtered out most of the time, but some sharp edges periodically come through. Still, compared to the soon-to-be-replaced M3, a car this one can run with, the 335i Coupe is a much more livable daily driver.
Inside job
That six-speed Steptronic transmission, a $1,275 option, is quite a nice piece. Not only are shifts firm and positive, but when commanded manually, they happen right now, with the throttle blipping up to match revs during downshifts. Manual control is available by slapping the shift lever to the left and flicking it forward for downshifts and back for upshifts. Steering wheel paddles that do the same are a worthwhile $100 upgrade.
Inside, where all of the above happens, is a welcome place indeed. Our 6-foot-2-inch tester had no trouble settling in behind the wheel, which tilts and telescopes like the one in the 3 Series sedan. More seat travel than he needs is available, and headliner and hairdo stay a respectful distance apart. The aforementioned sport package also includes substantially bolstered sport seats that clamp one in firmly, but don't confine or annoy.
Hurting our wallet, but not our backside, is the $2,450 premium package, which adds adjustable lumbar support and sumptuous black Dakota leather to those seats, along with Bluetooth and other electronic gadgetry. Navigation system aficionados who fork over another $2,100 will get on-screen traffic updates, which are a godsend, and iDrive, which still isn't growing on us. At least it's not compulsory here.
About the only miss in an otherwise impeccably trimmed interior is the apparent flimsiness of the robot arm that delivers the seatbelts to front-seat occupants. A neat idea, but our passenger-side unit came apart. It took a couple of tries to get tab A to snap back into slot B, but once accomplished, everything worked OK.
If you have the means…
For the base price of $41,295, or even our 335i coupe's optioned-up price of $49,195, you'd be hard-pressed to find a sport coupe with this combination of outright speed, handling prowess and sophistication. A similarly optioned 2006 M3 coupe with the Competition Package costs over $57 grand, will be more brutal to drive and is no faster.
And whether our car's muy rapido 0-60 performance was anomalous or not, the random customer car we dynoed should easily match, and perhaps exceed, BMW's impressive-in-their-own-right performance figures.
Leaving all that aside, there's no doubt that this car is an excellent piece of work. It's not an overstatement to say that the 2007 BMW 335i is a significant milestone in the storied history of BMW's 3 Series. Until that 2008 V8-powered M3 comes out, that is.
NYCshopper is offline   Reply With Quote
Old 11-28-2006, 08:30 AM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
wow! Thanks for that
jigga is offline   Reply With Quote
Old 11-28-2006, 08:30 AM   #3
NYCshopper
Member#: 5126
Old 11-28-2006, 08:49 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Wow, that's mean.
Old 11-28-2006, 08:53 AM   #5
Rev1
Member#: 51240
08 Lexus IS350
It was fairly noticeable that BMW downplayed the HP numbers for the 335i, so that it doesn't piss off the E46 M3 owners.
Once the E92 M3 is released, then that's another story
Rev1 is offline   Reply With Quote
Old 11-28-2006, 09:32 AM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
I'd love to lease that engine in sedan form!
Spenk is offline   Reply With Quote
Old 11-28-2006, 10:04 AM   #7
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Wow, that's impressive, though the body style does nothing for me.
Fold down rear seat, why can't Subaru remember how to add that to all their cars?
Snowphun is online now   Reply With Quote
Old 11-28-2006, 10:18 AM   #8
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Just my $0.02:
- Nice to see that BMW hasn't managed to ruin the 3 like it has the 5.
- Audi still eclipses them on interiors.
- Coupe body style is fugly. Proportions are all weird. (I know, I know -- this, from a Subaru owner )
FromageTheDog is offline   Reply With Quote
Old 11-28-2006, 11:08 AM   #9
Chiketkd
Member#: 71634
In hibernation...
Great car, but it's a shame that a 300hp rwd car comes with stability/traction control but no limited slip diff...
Chiketkd is offline   Reply With Quote
Old 11-28-2006, 11:17 AM   #10
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I wish my RS had these.
Old 11-28-2006, 11:31 AM   #11
SubaDuba420
Member#: 102793
2016 WRX
Ugly Sedan
Originally Posted by FromageTheDog View Post
Just my $0.02:
+1, it may grow on me in time, but everything seems too looooooooong everytime I check them out in person. I'd get the sedan over the coupe, which I may do in the spring, bye bye M3 hello 335
SubaDuba420 is offline   Reply With Quote
Old 11-28-2006, 11:46 AM   #12
SplatZ400
Member#: 84377
2011 335d
personally i love it. and this is my next car as soon as i get back from iraq.
SplatZ400 is offline   Reply With Quote
Old 11-28-2006, 04:58 PM   #13
BigElm
Always under your radar!
Member#: 1568
This is the first Beemer coupe I've liked in a long time
BigElm is offline   Reply With Quote
Old 11-28-2006, 05:40 PM   #14
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
A wagon or X3 version for us old dudes with kids, please...
brizey is offline   Reply With Quote
Old 11-28-2006, 05:42 PM   #15
Len
Member#: 39937
2011 328i 6MT
LMB
Now let's wait for the 135i coupe.
Len is offline   Reply With Quote
Old 11-28-2006, 05:45 PM   #16
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
I'm there with money in hand, but I don't think it will happen in the US.
Old 11-28-2006, 06:02 PM   #17
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
GT35R + FMIC + H&R Coilovers + ECU + Exhaust =
From a Beamer
I'd Rock it
SubyDuz is offline   Reply With Quote
Old 11-28-2006, 06:06 PM   #18
Len
Member#: 39937
2011 328i 6MT
LMB
Don't give up completely. There's still small chance that it might happen in a couple years.
Old 11-28-2006, 08:53 PM   #19
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
I don't understand why people aren't jumping on BMW for sending out a ringer to the press? We'd certainly jump on SOA if they tried it.
Chromer is offline   Reply With Quote
Old 11-28-2006, 10:42 PM   #20
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
Z4 35 or 135 hatch - I would sooo sport that..
amdmaxx is offline   Reply With Quote
Old 11-29-2006, 01:16 AM   #21
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Sarcasm?
335i Dyno Revisited
Old 11-29-2006, 04:38 AM   #22
baltik
Member#: 58166
I don't get it, to prove that the first car isn't a ringer, they got a second car directly from BMW?!
baltik is offline   Reply With Quote
Old 11-29-2006, 01:44 PM   #23
sil0nt
Member#: 30584
05 STi Black
07 S4 Avant Black
How about Shiv's dyno testing/tuning from his bought-from-the-dealer 335? The numbers are just as impressive. Check www.e90post.com for yourself..
sil0nt is offline   Reply With Quote
Old 11-29-2006, 04:48 PM   #24
design1stcode2nd
Member#: 112178
335i sedan is nice too, isn't it on sale already? I'm looking forwards to the 335 cabrio. That one looks sweet.
design1stcode2nd is offline   Reply With Quote
Old 11-29-2006, 07:32 PM   #25
quentinberg007
Member#: 7887
Originally Posted by Beaverboy View Post
Holy Jesus! Did you watch the video? Daddy wants.
~~Quentin
quentinberg007 is offline   Reply With Quote
Edmunds.com Inside Line Full Test: 2008 BMW M3 Coupe USCTrojan4JC Non-Subaru News & Rumors 26 02-29-2008 08:04 PM
Full Test: 2007 BMW X5 4.8i (Edmunds.com) NYCshopper Non-Subaru News & Rumors 1 03-15-2007 08:00 AM
Follow-Up Test: 2007 BMW 335i Sedan (edmunds.com) NYCshopper Non-Subaru News & Rumors 8 03-05-2007 08:00 AM
Follow-Up Test: Vishnu Performance Systems BMW 335i Coupe (edmunds.com) NYCshopper Non-Subaru News & Rumors 18 02-06-2007 12:17 PM
Full Test: 2007 Saturn Aura XE (edmunds.com) NYCshopper Non-Subaru News & Rumors 12 10-20-2006 10:14 AM
