Old 11-28-2006, 04:50 PM   #1
brokenarrow
Member#: 119767
2006 wrx
Default Supertech valves.NEED HELP FAST
Sorry for not taking the time to search.. I did a little ..but have no time..
MY shop is working on my heads RIGHT now and THEY need to know the info now.
MY question:
I got the OVERSIZED supertech vavle (1mm over) .
The SHOP says that the VALVE STEMS are WAY TOO long. They say that thay will have to cut the stem almost in half...
They need to know if this is normal.. OR IF I GAVE THEM THE wrong vavle..
I tried to call supertech but no one picked up the phone.
so if you can please help fast... THANKS ALOT
brokenarrow is offline   Reply With Quote
Old 11-28-2006, 05:10 PM   #2
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Call [email protected] as he sells Supertech Valvetrain parts and can help you determine wether the valves you have a the proper ones.
They should not have to cut the valves at all. they are only +.5mm longer as indicated on the box. I am running Supertech Valves and Springs in my heads.
ShaggyGT is offline   Reply With Quote
Old 11-28-2006, 05:11 PM   #3
ShaggyGT
Member#: 19221
Ron's # is: 314-443-7414
Make sure you are speaking to Ron.
Old 11-28-2006, 05:19 PM   #4
brokenarrow
Member#: 119767
2006 wrx
I just spoke with him. ( THANKS shaggygt)
He says that thay are prolly the older valves( very long stem).
he says it normal for the older ones. but the new ones are a little shorter(or something like that...
BUT anyways.. thanks very much.!!!!
problem solved
Stromung Midpipe Help! Need Help FAST! CoBB_tHiS! Normally Aspirated Powertrain 5 02-02-2009 07:02 PM
Need help fast- front hub assembly- please help soslow General Community 1 03-04-2006 09:38 PM
need help fast! help me get out of work snyper784 Off-Topic 10 10-17-2003 03:45 PM
Blown MAF!?! Need help fast!-Thanks DaveK Normally Aspirated Powertrain 3 03-26-2001 08:03 PM
Need help fast! w/internet exploerer, i messed somthing up! munkis General Forum Archive 8 09-28-2000 06:34 PM
