Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 11-15-2001, 09:50 PM   #1
wrx182
Member#: 9531
2002 WRX Sport Wagon
Default Messed Up Noises
I've got some really really strange noises coming from the shifter assembly / area...Recently installed the STi shift kit and Kartboy bushings....what could be causing this? or is this normal?
wrx182 is offline   Reply With Quote
Old 11-16-2001, 12:12 AM   #2
aov
Member#: 7193
MY02 WRX
What kind of noises??? Is it a rattle, crunching...
-anders
aov is offline   Reply With Quote
Old 11-16-2001, 08:20 AM   #3
wrx182
Member#: 9531
like a plastic on metal kind of rubbing noise....and there is a little kind of clunk noise also - both only happen when i'm giving it no gas while driving...the clunk happens if i am giving it some gas and then let off quickly....
any ideas guys? it's driving me up the wall
Old 11-16-2001, 12:04 PM   #4
GOT_WRX
Member#: 7241
If it's not the gear whining you are talking about (different from off throttle rattle), then check your tire pressure. This has been discussed a lot, but make sure your front tire has 3-4 more psi than rear tires.
Of course you will hear more noise by installing hard bushings(kartboy, cusco, etc) and any rattles or noises that you heard when using stock bushing will be amplified. After you adjust the tire pressure, the only noise you should hear is gear whining.
Dunno about the clunk, it maybe the muffler hitting the walls.
GOT_WRX is offline   Reply With Quote
UP and DP install, car messed up bad!! Lurkin4Life Newbies & FAQs 50 02-17-2008 03:40 AM
Messed up with touch-up paint 04luchini Car Care & Detailing 14 05-28-2007 07:31 PM
so i go to LA mess up my brakes and end up on the Fast and the Furious set gokou006 Southern California Impreza Club Forum -- SCIC 4 03-18-2003 07:27 PM
Someone messed up my baby!!! Saw Jai Bay Area Impreza Club Forum -- BAIC 10 12-09-2000 12:46 AM
