Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-29-2006, 04:51 AM   #1
pio!pio!
Member#: 4190
2008 Impreza WRX STi
Default 2008 Nissan Altima Coupe
http://www.nissansportmag.com/newsno...timacoupe.html
Next-Generation Nissan Altima Coupe Brings Style, Emotion and Sophistication to Mid-Size Coupe Market
New Altima Coupe Debuts at Los Angeles Auto Show; Offers Upscale Styling, Sporty Performance, Driver-Oriented Interior and High Quality
The Nissan Altima is a car on the move. With its next generation design for the 2007 model year, Nissan’s best-selling vehicle in the United States is poised for even greater success as it establishes segment leadership in style, design, performance and innovation. The next-generation Altima is also expanding its model offerings with a new Altima Hybrid, set to go on sale in select markets in January 2007, and a dramatically styled new Altima Coupe, which will go on sale as a 2008 model in summer 2007.
The Altima Coupe, which made its debut in the shadows of Hollywood at the 2006 Los Angeles Auto Show, fills a desire among target customers for a more personal expression of style, individuality and fashionable appearance. The Altima Coupe’s unique exterior design is intended to stand out in a crowd of sedan-based two-door models with magnetic, perfectly proportioned styling with a shorter wheelbase, shorter overall length and lower height than the Altima Sedan.
The smaller size and lighter overall weight also contribute to the Coupe’s sportier driving feel – other desired attributes of the typically younger, more performance-oriented coupe buyers.
“Rather than just eliminating two doors from the Altima Sedan, we gave the Altima Coupe its own style, its own dimensions and its own interpretation of Nissan’s exhilarating driving pleasure,” said Bill Bosley, vice president and general manager, Nissan Division.
Though the new Altima Coupe shares much with the latest edition of the Altima Sedan, which went on sale in early November 2006, the Coupe’s smaller dimensions, driver-oriented cockpit and unique styling give it an extensive amount of separation from the Altima Sedan.
Dimensionally, the Altima Coupe rides on a 105.3-inch wheelbase, a full 4.0 inches shorter than the Sedan. Overall length is 182.5 inches – 7.1 inches less than the Sedan. The Coupe also has a lower profile – at 55.3 inches it is 2.5 inches shorter than the Sedan. In terms of major body panels, the two cars share only a common hood, with all other panels, grille, headlights and rear combination lights unique to the Altima Coupe.
Under the new Altima Coupe’s sophisticated exterior design, this latest addition to the Altima family shares the platform, powertrain and user-friendly features and innovations of the new fourth-generation Altima.
“A strong sedan starting point, such as the new Altima, also gives you a tremendous advantage – if you get the basics right, you can focus your efforts on the unique desires of coupe buyers, including wanting a purely personal space,” said Bosley.
The Altima Coupe, as part of the fourth-generation Altima design, utilizes Nissan’s all-new, highly acclaimed “D” platform with increased body rigidity and a redesigned suspension. This new platform was developed with the objective of making Altima one of the best performing large front-wheel drive vehicles available globally.
New suspension geometry, shock absorbers with rebound springs, engine placement that is lower in the subframe and equal-length half-shafts that have equal angles and are more parallel to the ground all help to virtually eliminate torque steer.
The rear multi-link independent suspension design separates the rear shocks and springs for reduced friction and the shocks are in line with the center of the rear wheels, providing better damping and less harshness. Front and rear stabilizer bars are standard. The Altima suspension has been specially tuned for use with the Altima Coupe.
The new Altima Coupe is offered with a choice of two engines and two transmissions. The 3.5-liter 24-valve DOHC V6 is the “next generation” version of the 12-time Ward’s “10 Best Engines” award-winning VQ-series V6. For use in the Altima Coupe, it is rated at 270 horsepower and 258 lb-ft of torque and offers strong acceleration and refined sound quality. The V6 features reduced friction, improved cylinder head cooling and new twin knock sensors.
Also available with the new Altima Coupe is a 2.5-liter DOHC 16-valve QR25 inline 4-cylinder, producing 175 horsepower (170 hp CAL) and 180 lb-ft of torque (175 lb-ft CAL). This engine has been refined from the previous version, with a larger, equal-length intake manifold, increased compression ratio and reduced friction characteristics. It features a silent chain drive and a balancer system (with balancer changed to a center-mounted location for better NVH) that effectively negates vibrations without taking up much space – combining ideal packaging and smoothness.
Both engines feature continuously variable valve timing, modular engine design, microfinished crank journals and cam lobes, molybdenum coated lightweight pistons and electronically controlled throttles.
Both the 3.5-liter V6 and 2.5-liter 4-cylinder models are available with Nissan’s advanced Xtronic CVT™ (Continuously Variable Transmission) or 6-speed manual transmissions.
The V6 CVT features a “Sport” mode controller with a high-speed central processing unit and Adaptive Shift Controller with adaptive logic for faster shifting in both normal and manual modes. The adaptive logic feature delivers the best shift pattern based on the driving environment and driver’s perceived intentions.
“The driving performance of the Altima Coupe is biased toward sporty feel, especially when equipped with our award-winning V6,” said Bosley. “Handling is also a strong point of the new Coupe, as is the responsiveness feeling provided by the Xtronic CVT transmission.”
Also contributing to the Altima Coupe’s sporty performance feel are a standard twin-orifice vehicle-speed-sensitive power rack-and-pinion steering system and 4-wheel disc brakes with standard 4-wheel, 4-channel, 4-sensor Anti-lock Braking System (ABS) with Electronic Brake force Distribution (EBD).
Altima Coupe models with the 4-cylinder engine are equipped with 16-inch wheels and tires, while V6-equipped Altima Coupes come with unique-design 17-inch aluminum-alloy wheels and 215/55R17 tires.
The Altima Coupe’s performance feeling is also enhanced by a driver-centered interior. Though sharing much of the design and features with the new Altima Sedan, the Coupe includes unique sport-style front seats with more side support, in-board release lever and front kangaroo pouches. All Altima Coupes also utilize a parking brake hand lever (versus foot release for Altima Sedans with CVT). The Coupe also includes a 60/40 split and flat fold-down rear seat.
Like the Altima Sedan, the Altima Coupe’s instrument panel features a Fine Vision gauge display for enhanced readability and the L-shaped flow of the instrument panel to the center console adds to the driver-oriented cockpit feel.
The center console includes a double front cup holder, among the many convenient cup and bottle areas and storage compartments.
The list of impressive passenger amenities includes standard Intelligent Key with Push Button Ignition and available Bose®-developed audio system with nine speakers, Bluetooth® Hands-Free Phone System, satellite radio and dual-zone automatic temperature control.
The new Altima Coupe also comes equipped with a number of standard safety features, including Zone Body construction with front and rear crumple zones and Advanced Air Bag System (AABS), which includes dual-stage front supplemental air bags. Also standard are front seat side-impact supplemental air bags for chest protection and roof-mounted curtain side-impact air bags for front and rear outboard occupant head protection.
Other standard equipment includes front seat Active Head Restraints, the LATCH (Lower Anchors and Tethers for CHildren) child seat anchors and tether system and Tire Pressure Monitor System (TPMS).
The 2008 Altima Coupe will be available in four well-equipped models: 2.5 S 6MT, 2.5 S CVT, 3.5 SE 6MT, 3.5 SE CVT.
Available technology features include a RearView Monitor, which utilizes a small camera to help show the view behind the vehicle when in reverse gear, and Nissan Navigation System with a 6.5-inch color monitor.
“Along with the Altima Coupe’s extensive list of available features and amenities, it offers one more thing to discerning coupe buyers – the reassurance of Nissan durability, quality and reliability,” said Bosley.
The new Altima Coupe will be assembled at the Nissan North America Manufacturing Smyrna and Decherd, Tennessee plants.
Altima Coupe becomes the seventh Nissan Altima model, joining the 2.5, 2.5 S, 2.5 S with SL Package, 3.5 SE, 3.5 SL and Altima Hybrid (Hybrid Electric Vehicle).
“The Altima name and outstanding reputation adds great credibility to the new Altima Coupe – and the Coupe makes the Altima brand stronger by appealing to a new segment of buyers,” said Bosley. “And like the Altima Sedan, the new Coupe will be a tremendous value when it goes on sale next summer. If you’re looking for style, performance and affordability, the new Altima Coupe delivers.”
pio!pio! is offline   Reply With Quote
Old 11-29-2006, 05:00 AM   #2
kg2128
Member#: 63698
2005 Wrx
Crystal Gray Metallic
looks ok..., but dont really see the point of the 6 cylinder one thats too close to the Z(im assuming it will be similiar to the price of the 6 cylinder sedan and some of those prices are higher than the lower end Zs) but it seems like its for someone that wants something more impractical and more "sporty" than the sedan but not as impractical/sporty as the 350z? Seems like worst of both worlds to me I doubt its much if at all faster than the sedan and not even better looking and of course can't compare to the 350z in performance.
kg2128 is offline   Reply With Quote
Old 11-29-2006, 05:00 AM   #3
Mopho
Member#: 32334
05 Outback
Caterham 7 Superlight R
I'm "driving" the car in the moving shots
Mopho is offline   Reply With Quote
Old 11-29-2006, 05:07 AM   #4
pio!pio!
Member#: 4190
hey mopho so how large is the car...like solara/accord coupe or g35 coupe sized?
or scion tc sized?
or somewhere in between
Old 11-29-2006, 05:09 AM   #5
Mopho
Member#: 32334
05 Outback
It's Altima sized.
I'd say slightly bigger than the TC.
It's really pretty in person (except for the front of it)
Old 11-29-2006, 09:22 AM   #6
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
That is awesome.
bjorn240 is offline   Reply With Quote
Old 11-29-2006, 10:26 AM   #7
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Aren't those the Scion tC rims? The grill area looks a bit funky to me
Hank3 is offline   Reply With Quote
Old 11-29-2006, 12:57 PM   #8
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
I think will sell
mhoward1 is offline   Reply With Quote
Old 11-29-2006, 01:06 PM   #9
fishandring
Member#: 124042
2012 VW Golf TDI 2dr
2013 Mazda CX5
It looks like a poor mans g35. how great! I would be a little aggravated if I owned a g35 coupe though...
fishandring is offline   Reply With Quote
Old 11-29-2006, 03:12 PM   #10
ktzdaddy
Member#: 125975
i would be pissed if i was a g35 customer. you could by this a jim wolf twin turbo set up, body kit, rims and suspension for much less than the cost of a g35. doesnt make any sense. or maybe it does and i dont get it.
ktzdaddy is offline   Reply With Quote
Old 11-29-2006, 03:35 PM   #11
pio!pio!
Member#: 4190
well for one it will still be FWD
Old 11-29-2006, 03:38 PM   #12
ktzdaddy
Member#: 125975
agreed, but styling wise its damn close. i know that if i owned a g, i would be pissed.
Old 11-29-2006, 06:29 PM   #13
VWGrk1
Member#: 57882
2004 WRX
Not terrible- it is the G6 that Pontiac should have built
I'd like to see some more real-life angles of the car before saying anything, but I'm going to guess that this will not turn into a big seller (not a big market for this sort of thing).
VWGrk1 is offline   Reply With Quote
Old 11-29-2006, 06:31 PM   #14
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Yeah, that's not a lot of work and issues. I'm considering a g35 coupe and I'm sure this car won't be on my list.
Snowphun is online now   Reply With Quote
Old 11-29-2006, 06:35 PM   #15
Len
Member#: 39937
2011 328i 6MT
LMB
Some people pay more to get an Acura TSX over a V6 Accord. And they really are the same cars, on the same platform. The more expensive one just has less power.
If a G owner is a badge whore, he wouldn't care since an Altima is still a Nissan,. If he's into performance, he still wouldn't care since an Altima will always be a FWD with 60:40 weight distribution and torque steer. So, why would you?
Len is offline   Reply With Quote
Old 11-29-2006, 06:51 PM   #16
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
Poor mans fwd g35.. priced very close to 30k..
amdmaxx is offline   Reply With Quote
Old 11-29-2006, 07:53 PM   #17
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
looks like a G35c humped a scion TC
which is to say, a good looking but generic offspring
lawn boy is offline   Reply With Quote
Old 11-29-2006, 11:07 PM   #18
Optimus Prime
Member#: 69847
2010 Evolution X
From the side on Autoweeks website, the back looks like a new Monte Carlo.
Optimus Prime is offline   Reply With Quote
Old 11-30-2006, 12:30 AM   #19
rice h8r
Member#: 94524
^ uh oh...
actually TSX = foreign Accord = smaller than US version...
Altima Coupe seems more of a Solara/G6 Coupe competitor, something fast, a bit sporty but not a sports coupe.
+1!
rice h8r is offline   Reply With Quote
Old 11-30-2006, 12:54 AM   #20
darknightohio
Member#: 50523
2010 GTI
The current G35 coupe is a much better looking car
Plus with the new refreshed G35 coupe coming, I don't see this car doing too well.
darknightohio is offline   Reply With Quote
Old 11-30-2006, 05:08 AM   #21
Mopho
Member#: 32334
05 Outback
In person it does not look that much like the G35, the proportions are much different and the C pillars meet the trunk much differently
Old 11-30-2006, 07:28 AM   #22
This Is Not Mike
Member#: 131737
2006 STI OBP
2013 Tacoma TRD OR
270 hp?
Price this at 25K, add a little more "youth" flair and you'd have a hit.
Of course, they're not going to option it right, and make the only way to get the high HP motor to by the premium package with leather, nav and a bunch of other parts that are just going to weigh it down, then price it only 4K less than a G35 and watch it fall on its face.
Too bad the base model is going to end up being a secretary's car (not knocking on secretaries, but you get my drift...aka Mustang V6, Solara, tC) and not any sort of serious performance car.
This Is Not Mike is offline   Reply With Quote
Old 12-01-2006, 05:19 PM   #23
BTR
Member#: 115282
BTR is offline   Reply With Quote
Old 12-01-2006, 09:03 PM   #24
BigFatGeek
Member#: 31215
2001 VW EuroVan MV
03 Legacy L-SE Wagon
Heck, I see the V6 model being a "secretary's car" as well. Seems like 80% of the Accord Coupes I see are driven by women.
BigFatGeek is offline   Reply With Quote
Old 12-01-2006, 09:12 PM   #25
G3Red04WRX
Member#: 66611
2007 Trailblazer AWD
3LT Sandstone Metallic
Heck, to be honest, i actually like the look of that better than the G35C. Th grill is a little funky, but that car has one sweet ass.
G3Red04WRX is offline   Reply With Quote
2008 Honda Accord Coupe vs 2008 Mitsubishi Eclipse vs 2008 Nissan Altima Coupe carbnjunkie Off-Topic 108 02-13-2008 03:00 PM
First Drive: 2008 Nissan Altima Coupe (Motor Trend) NYCshopper Non-Subaru News & Rumors 9 05-24-2007 09:46 PM
Tested: 2008 Nissan Altima 3.5SE Coupe (Car & Driver) NYCshopper Non-Subaru News & Rumors 18 05-22-2007 03:51 PM
2008 Nissan Altima Coupe WRXSIG Member's Car Gallery 26 12-04-2006 02:24 PM
Spyshots: Nissan Altima Coupe? (maybe future 350z???) NYCshopper Non-Subaru News & Rumors 61 11-27-2006 03:25 AM
