North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 06-03-2001, 09:23 AM   #1
Fubaru
Member#: 6046
'08 Prius
Post High octane gas in Portland area
Does anyone know of a station selling
>92 octane nearby Portland?
I did a search in the PNW thread but there
was just a few discussions about locations
near Seattle.
Thanks,
Eric
Fubaru is offline   Reply With Quote
Old 06-03-2001, 09:40 PM   #2
Pat Green
Member#: 5818
2002 WRX, '72 510
V is for Victory, Hippie!
Cool
I posted the same in the BAIC forum a couple of days ago. Try www.76.com. It's been down for the day, but should be up tomorrow.
Pat Green is offline   Reply With Quote
Old 06-03-2001, 10:18 PM   #3
initialWRX
Member#: 3633
2002 WRX Sedan
Post
I only use Cheveron--91oct.
the highest I've seen is 76 with 92oct.
-initialWRX
initialWRX is offline   Reply With Quote
Old 06-03-2001, 11:30 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Post
"Trick" racing gas is available at Rose City Off-Road Center: SE 90th and Stark. At least according to some info I found.. but it may well be leaded.
Alan is offline   Reply With Quote
Old 03-15-2002, 11:31 AM   #5
Fubaru
Member#: 6046
'08 Prius
bump...
Anyone know of a source for at least 93 or 94 octane fuel around Portland?
Old 03-15-2002, 01:10 PM   #6
callawayv
Member#: 11732
1987 RX
White w/blue
If you don't run a Cat or yours is punched out, with a little effort, you can use AvGas, I believe 100 low lead. I don't recomend this unless it's for a race car that's only used on the track and not the streets......
I take a few 5 gallon cans to the airport and fill up.
callawayv is offline   Reply With Quote
Old 03-15-2002, 01:52 PM   #7
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally posted by Fubaru
bump...
Well, you can buy 104 at Race Central, but it is expensive. For my WRX (running 20psi), I use 1 gallon of Toluene per fill up, which raised the octane to about 93 or so.
Don't run the AVGas unless you want to destroy the front wideband and rear narrowband O2 Sensors, which will make your car throw codes left and right. I suppose a bit for the track day is fine, but not on a regular basis.
-Jeff
sponaugle is offline   Reply With Quote
High octane gas in Seattle RA North West Impreza Club Forum -- NWIC 18 06-17-2010 01:06 AM
High octane gas in NW PA? Pheasant Plucker Mid Atlantic Impreza Club -- MAIC 1 09-09-2004 11:27 AM
High octane gas in vancouver/abbotsford/mission? StealthWagon Vancouver Impreza Club Forum -- VIC 5 06-13-2003 08:19 PM
('93-'01) High octane gas in stock WRX. THEMUSH Impreza Forum 31 10-30-2001 09:26 PM
Higher octane gas in Portland? paulw North West Impreza Club Forum -- NWIC 3 06-15-2001 03:31 PM
