Old 11-29-2006, 02:29 PM   #1
NYCshopper
Member#: 5126
Default Goodyear Develops New NASCAR Cam Drive Belt (Carbon Fiber)
Press Release:
Heading into the final ten-race chase for the title, NASCAR Nextel Cup Series Champion Jimmy Johnson and Hendrick Motorsports made gambles on and off the track to find increased performance.
One bet was made on a new ultra-high-tech Goodyear Gatorback automotive camshaft timing belt that contains carbon fiber found in advanced composites.
Carbon fiber -- strong and flexible, weighing much less than steel of similar strength -- is added to heat- and oil-resistant rubber compounds for use in the belt's tooth and body construction, so both are stronger.
Earlier this year, Goodyear (NYSE: GT) introduced its Goodyear Eagle tire, featuring ResponsEdge Technology with carbon fiber.
Mike Gregg, Goodyear Engineered Products' chief belt engineer, said it's unusual to introduce a product upgrade late in the season, but "engine performance demands increased during the season and we didn't want to wait until the off-season to make changes."
Jim Wall, director of engine engineering for Hendrick Motorsports, contacted Gregg, looking for a timing belt that would tolerate a 25 percent increase in horsepower.
According to Jeff Andrews, engine program director for Hendrick Motorsports, "It was determined that a jump of that magnitude would
increase the demand on the belt by 50 percent."
Andrew said the improved Gatorback timing belt with carbon fiber allows engines to run more efficiently, handles increased loads and higher temperatures better, and provides precise timing in a very harsh environment.
"Goodyear came through for us," he said. "They designed, developed, tested and delivered the latest Gatorback belt in just seven weeks, making it available to all race teams, as we headed into the ten-race Chase to the Championship."
Before the season ended, drivers on the Hendrick team using the new Gatorback belt included Johnson, Jeff Gordon, Kyle Busch, Brian Vickers and Terry Labonte. Other race teams also tested and used the belt.
"We were ecstatic about the belt's performance," said Wall. "The size and weight of our cam drive components remained the same, but their
performance increased dramatically."
Gregg said the rapid product development process required to keep up with NASCAR race teams helps drive Goodyear's cutting-edge technology in the automotive aftermarket. For example, the same Gatorback Poly-V belts chosen by all NASCAR teams are available straight-off-the-shelf in major auto part stores and auto service centers."
According to Gregg, when conventional timing belts engage under extreme load with sprockets, tooth deflection or deformation occurs. Deflection affects a camshaft's precise timing of opening and closing air valves in sync with its crankshaft and pistons.
Gatorback's new carbon-fiber compound and belt construction virtually eliminate tooth deflection.
Wall said, "Less tooth deflection means more horsepower, and Gatorback's strength and consistency provide accurate ignition timing, which we continuously strive to improve."
Gregg said the belt's tooth face is made from nylon, with a patented polymer alloy coating that reduces friction and wear and withstands temperatures of 300 degrees Fahrenheit. In addition, the belt's cord is made using high-strength glass with finer, stronger filaments than that found in most timing belts."
Goodyear Engineered Products is the exclusive NASCAR Performance licensee of automotive aftermarket belts and hose. More information is available at http://www.goodyearbeltsandhose.com.
NYCshopper is offline   Reply With Quote
Old 11-29-2006, 03:20 PM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
New CF belt + leass tooth deflection + more better timing and HP = more violent crashes and profit?
02redwagone is offline   Reply With Quote
Old 11-29-2006, 08:23 PM   #3
BigFatGeek
Member#: 31215
2001 VW EuroVan MV
03 Legacy L-SE Wagon
And I assumed that NASCAR engines would use timing chains. Aren't they pushrod engines?
BigFatGeek is offline   Reply With Quote
Old 11-29-2006, 08:26 PM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Someone tell Goodyear to keep quiet. They're destroying NASIOC's belief in there being no technology in NASCAR.
Chromer is offline   Reply With Quote
Old 11-29-2006, 09:06 PM   #5
BigFatGeek
Member#: 31215
2001 VW EuroVan MV
dems cars still gots carbs
Old 11-29-2006, 09:11 PM   #6
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
I can appreciate the technology and work that goes into the cars, I just can't get into the driving in circles and calling a set of sticker headlamps a "stock car"
Old 11-29-2006, 09:45 PM   #7
teh POD
Member#: 90195
they don't need no timing chains now. that new belt is hard to damage
teh POD is offline   Reply With Quote
Old 11-30-2006, 08:27 AM   #8
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
or they could just go with gear drives, and have perfect timing forever.
I would hardly call anything in NASACAR high technology. Pushrods and carbs....
SCRAPPYDO is online now   Reply With Quote
Old 11-30-2006, 08:48 AM   #9
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
It's highly-developed old technology.
I'm with you guys.. I had no idea that they weren't just using cam chains.
I suppose it's something like this:
(click me)
Old 11-30-2006, 09:38 AM   #10
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Yeh, they all drive in circles yet no one ever uses an indicator........
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 11-30-2006, 10:49 AM   #11
MooreWRX
Member#: 6661
2004 STI
White/Silver
They use jesel belt drives. www.jesel.com. Cam gears would cause to many harmonics for the valvetrain to live through a 500 mile race.
MooreWRX is offline   Reply With Quote
DFS (FL): Symms / Syms Replica Wing (WRB Blue Double Sided Carbon Fiber) REX_22 Exterior/Styling 5 04-19-2010 06:20 PM
WTB: 03 Bugeye Hood (Mid-Night Pearl Black or Carbon Fiber) Doctorchu SCIC Private Classifieds 1 04-07-2009 09:19 PM
FS CO: Status Ring Seats (black w/carbon fiber) w. Buddy Club Sliders M K S Interior/Dressup/Audio & Security 1 10-05-2008 08:26 PM
Bocce with bling (and carbon fiber) TimStevens Off-Topic 15 05-14-2007 01:30 PM
STi Replica Unpainted V1 Front Lip (FRP + Carbon Fiber) in STOCK + Other Goodies ! Gruppe-S Exterior/Styling 33 09-07-2005 03:30 PM
