Alaskan Impreza Club
Old 11-29-2006, 05:13 PM   #1
NegativeOne
Member#: 133568
2011 WRX-His
2006 LGT-Hers
Default I need fluid help!
What does everyone recommend in the 04 STi's tranny and rear diff? I know it's GL-5 but I wanna see if anyone's had any luck (or hardships) with different brands. Any help would be greatly appreciated
NegativeOne is offline   Reply With Quote
Old 11-29-2006, 05:30 PM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
arctic gear lube 75-90w...chevron!
SQUAD_907 is offline   Reply With Quote
Old 11-29-2006, 05:42 PM   #3
edo2000
Member#: 68709
2012 WRX
red
There are several threads about this which you can find if you search. Everyone seems to recommend NOT to use Mobil 1.
A lot of folks just recommend a good quality, GL-5, non-synthetic. Definitely a lot cheaper than the synthetics...
edo2000 is offline   Reply With Quote
Old 11-29-2006, 07:01 PM   #4
prometheum
Member#: 92003
04 bicycle!
uuh i hear the rear diff will take anything
prometheum is offline   Reply With Quote
Old 11-29-2006, 11:18 PM   #5
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
wow guys you are not thinking....
sti has a special lsd in the rear that requires special oil. i have seen one filled with gl-5 only and less then 1500 miles later it was making bad noises. i took it apart and the metal to metal clutches were galled and blued from heat.
so super duper sti oil comes in 1L cans, and cost about $30. the entire can is in japanese and i could not find a spec anywhere. soo... i gave a half full can to the bg oil guy that comes into my work to bring product, and he shipped it to bg to analyze. turns out it's just gl-5 with GM rear lsd additive.
a good subsitute for gm lsd additive is "equatorque" lsd additive, which can be bought for about 8-10$ at most parts stores. keep in mind if anyone trys this you are forging new ground....
so either buy the real thing, make your own cheap subsitute, or put away about $1000 for some rear diff parts.
oh yeah the trans just takes regular old gl-5
00Maddog is offline   Reply With Quote
Old 11-30-2006, 12:20 AM   #6
Getagrip
Member#: 2045
BRZ
If I had an STi or an STI, would only use OEM. Not worth the few bucks saved to "forge new ground" BTW Conti stocks the special sauce.
Jake
Getagrip is offline   Reply With Quote
noobie subie girl in need of help... jackee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 06-13-2010 12:42 PM
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 12:12 AM
Need some help with rear diff fluid change Blazin New England Impreza Club Forum -- NESIC 17 07-17-2006 02:54 PM
Quick Question - Tranny/Diff Fluid Help Needed mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 1 04-14-2004 12:18 PM
Need quick help-Tranny fluid T-REX Normally Aspirated Powertrain 3 06-27-2001 10:47 PM
