Old 11-30-2006, 02:15 PM   #1
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
Default Methanol without lube in it....
is it bad?
I have a good source for methanol, but i don't think it has any castor oil in it.
i get it from an oilfield supply company for less than three bucks a gallon.
should i toss in a bit of oil?
I run an SMC kit with a 10GPH nozzle.
banzai is offline   Reply With Quote
Old 11-30-2006, 03:50 PM   #2
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
The last time I spoke to Steve at SMC he told me NOT to use meth with lube in it.
PeteDucati is offline   Reply With Quote
Old 11-30-2006, 04:29 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Meth has lube in it?
Does this include the common meth found at your local speed shop or dragway, such as VP or Torco brands?
xcntrk75 is offline   Reply With Quote
Old 11-30-2006, 06:23 PM   #4
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
ScoobyDooo is offline   Reply With Quote
Old 11-30-2006, 06:41 PM   #5
banzai
Member#: 63926
deck EJ 20G stroker
yes. read the label very carefully. its a small percentage, but it's still there.
pete, now that you say that, i remember the conversation that i had with steve about this subject.
Old 12-02-2006, 09:23 AM   #6
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
http://powermist.com/methanols.html
This is where I get my meth.. I'm going to use the HoleShot when I get tuned again. The pure stuff is lube free, I asked. I was under the impression it was up to the end user to add the lube - almost like mixing for a 2 cycle engine. I'm also going to assume the lube is to help combat "cylinder" wash in race engines that run straight methanol.
Old 12-02-2006, 03:46 PM   #7
InfamousDX
Member#: 25413
^ What's their pricing like?
Old 12-02-2006, 06:05 PM   #8
WOR440
Member#: 106807
---> 2011 EVO X
I will be getting my meth from the local VP dealer
WOR440 is offline   Reply With Quote
Old 12-03-2006, 09:24 AM   #9
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
~$30 for a 5 gallon can. The HoleShot is only ~$5 more. During race season it's first come first serve. You can pick it up directly from them - it's a family run business.
Old 12-03-2006, 02:24 PM   #10
InfamousDX
Member#: 25413
Just realized it's 973 local. Sweet. Thanks for the tip.
Soooo apparently its not good to run your car without wate in it. Bluesoobdude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-03-2007 10:24 PM
Methanol?: I wan't it but don't want to buy 5 gallons... AaronWRX UTEC 4 06-16-2006 01:44 PM
place to buy redline gear lube in tampa mofugga South East Region Forum 0 04-15-2006 01:39 PM
Lube makes it so much better. m750 Off-Topic 28 01-01-2006 09:23 PM
Do I need to put lube in the drivesaft? Capt Crunch Transmission (AT/MT) & Driveline 0 08-07-2004 10:38 PM
