Old 11-30-2006, 05:56 PM   #1
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
Default Cusco Camber Plates?? Tein Coilovers
So I bought a set of Tein Basic Coilover about a year ago now, and I keep having neg camber issues. Now Im assuming that this is because it cannot be aligned properly (had it aligned twice now) because of the stock pillow ball mounts. So if I purchase Cusco Camber plates for the Front and rear will this correct my problem, and will they work with the Tein Basic Coilovers?? Any other suggestions, or input would be appreciated.
Boosted1456 is offline   Reply With Quote
Old 12-04-2006, 11:41 AM   #2
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
bump....
Old 12-04-2006, 05:27 PM   #3
grippgoat
Member#: 62182
2005 STI
You have too much negative camber, or not enough?
-Mike
grippgoat is offline   Reply With Quote
Old 12-05-2006, 02:18 PM   #4
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
-Mike
Too much... the inside corner of my tires wears really quick... even if i rotate them (which is a bitch to do every 1k miles )
Old 12-06-2006, 02:17 AM   #5
Solotoy
Member#: 99421
'13 BRZ
White Pearl
What's your toe? If you have zero toe and lots of neg camber, your tires shouldn't be wearing really fast. Granted they will wear more on the inside edge than the rest of the tire but it shouldn't be as bad as what you are describing. Toe (in or out) combined with camber is a sure tire killer. Are your front mounts pillow ball/slotted camber plates or pillow ball/fixed mounts? If they are fixed (single position) then get some slotted camber plates and that should fix your problem. If they are already slotted then you should have enough adjustability to get even tire wear.
Solotoy is offline   Reply With Quote
Old 12-06-2006, 05:22 PM   #6
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
Toe is at zero... never adjusted. But I have the STOCK pillow ball mounts with my Tein Coilovers. So I figured the Cusco Adj Camber plates would do the job. Just seeing if there was anyone who had used these, or had anyother ideas... Thanks!!
Old 12-06-2006, 06:09 PM   #7
jamesohoh7
Member#: 39070
GTF off my lawn!
If you adjusted your camber, you've adjusted toe inadvertently. Adding negative camber (or even just changing camber at all), as well as changing your ride-height, changes toe.. whether you adjusted the length of the tie-rods or not.
Why can't it be aligned properly?... the tie-rods adjust toe, the top strut bolt adjusts camber (what you can adjust, it's range is not huge), it's very simple. Any reasonable alignment shop should be able to figure it out.
Your toe needs adjusting is my guess.
jamesohoh7 is offline   Reply With Quote
Old 12-06-2006, 10:24 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Ahhh, if only it were that simple. For one, your toe was probably never zero to begin with (unless you had it aligned before putting on the coil-overs), as the factory alignments are notorious for having toe settings all over the place.
And, as jamesohoh7 already pointed out, when you lowered the car that affected toe. I'll put even more emphasis on it than he did. Your toe is completely out to lunch right now, I guarantee it. You have major toe out, which is what is killing your tires.
To agree with james yet again, a competent shop should be able to align the car using the factory adjustments with no problems.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-06-2006, 11:13 PM   #9
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
You say in OP that you have Basics, then later that you have Flex. Which do you have? Flex come with camber plates.
silver arrow is offline   Reply With Quote
Old 12-07-2006, 12:06 PM   #10
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
Your right my mistake... i fixed that post. There just the Basic ones, no camber plates. So I could get away without having to buy the Cusco Camber plates, and still get a good alignment?? Or is it worth the extra 450 bucks to get the camber plates??
Old 12-07-2006, 05:09 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
$450 for camber plates?! Are you buying ones made of diamond?
Go get an alignment. Unless you have the car absolutely slammed, there's no reason they would not be able to get the car properly aligned.
Pat
Old 12-07-2006, 05:10 PM   #12
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
If you are going to autocross, yes it is worth it to be able to adjust camber at the track and run less on the street. For just DD it is overkill and no nessessary.
Old 12-08-2006, 04:29 PM   #13
Boosted1456
Member#: 120766
04 Wrx Stg2
Harman Tuned
Pat
No... thats for front and rear, well thanks for the help, looks like I need to start searchin for a good alignment shop
FS in FL: Brand new Tein EDFC for 2004+ WRX and brand new Cusco camber plates sonic03rex Suspension/Brakes/Handling 8 06-21-2007 11:31 PM
Cusco Camber Plates, Tein Pillowball, Razo shift knob, etc. zroom tsuchiya Suspension/Brakes/Handling 7 06-06-2007 01:33 AM
KW Variant 3 Coilovers w/Cusco camber plates + Noltec F/R Camber Plates JayD707 Suspension/Brakes/Handling 6 03-24-2007 09:29 PM
using cusco camber plates with Tein Wagon coilovers??? JohnW Brakes, Steering & Suspension 0 01-12-2004 07:48 PM
cusco camber plates, kyb agx, ground control coilovers? slvrwrx02 Brakes, Steering & Suspension 0 11-30-2003 06:29 PM
