South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-01-2006, 10:52 PM   #1
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
Default Does anyone know?
Do they make a took for suspension because im tryin to tighten the nut on the stut that holds it to the tophat. But the shock just twists.. I see that the bolt has flat sides do you can grab it so do they make a wrench thats open ny fits inside a tophat? anyone have one?
szeny is offline   Reply With Quote
Old 12-01-2006, 11:01 PM   #2
Lazaride
Member#: 90336
2004 Forester
Subaru Stars
This sounds like a question for [email protected] - JAMES WHERE ARE YOU! - he will know
Lazaride is offline   Reply With Quote
Old 12-01-2006, 11:19 PM   #3
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
If i remember right you can put a allen key into the top of the strut and use a wrench to tighten it up
Poweredbysnail is offline   Reply With Quote
Old 12-02-2006, 01:15 AM   #4
gormonk
Member#: 98960
1978 brat (fo realz)
red
^^ correct.......... me and James had to do it a few times to his RS
gormonk is offline   Reply With Quote
Old 12-02-2006, 02:46 AM   #5
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Ah thats only if its not adjustment knob thru the top.
I use a impact a few times. But I think its a 14mm box wrench that hold the damping rod. Depending on which strut you are using. Make sure to get a alignment done before driving it much.
06STi is offline   Reply With Quote
Old 12-02-2006, 03:53 AM   #6
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
this is on KYB AGX's.... its a 19mm nut and has a spot on top for a crescent or small wrench... couldnt get a box wrench in there
Old 12-02-2006, 03:54 AM   #7
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Damn your still working on it..... I know I'm working on my car too...
Old 12-02-2006, 04:02 AM   #8
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
lol no i got on and tight enogh to work yesterday.. just wondering because i dont want it semi-tight forever
Old 12-02-2006, 04:16 AM   #9
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Go to the meet in the morning. See if they can zap it down for you with a impact and a torque bar.
Old 12-02-2006, 12:24 PM   #10
Member#: 112472
2004 PSM JDM WRX
ATS TWIN PLATE Stg 22.5/6
You use an Impact on it it spins it faster than it can spin so it tightens ,Good luck
James@RPM is offline   Reply With Quote
Old 12-02-2006, 12:42 PM   #11
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
i had got a socket set at napa that has a hole straight through the top of the rachet. i used that to tighten the bolt while holding the shaft with a allen wrench. didn't use the impact at all
taerron is offline   Reply With Quote
Old 12-02-2006, 01:28 PM   #12
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
/\ that would work for stockers, not KYB's, they don't have the allen key hole. Put a dab of locktite on the nut to keep it from vibrating loose in a few 1000 miles. A quick zap with an impact is the easiest solution. The TQ spec isn't that high IIRC.
John2.5RS is offline   Reply With Quote
Old 12-02-2006, 04:13 PM   #13
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
it worked just fine for the tokico's. sorry couldn't help
Does anyone know anyone at Bob Baker? SubieFever Southern California Impreza Club Forum -- SCIC 2 08-30-2006 06:48 PM
Does Anyone Knows A Company That Does Retro Fittings? spliffpirate Electrical & Lighting 4 07-16-2004 12:58 PM
Does anyone know if VT Sports Car does engine swaps? xxtwowheelfiendxx New England Impreza Club Forum -- NESIC 12 02-25-2004 08:03 PM
Does anyone know who does work on old subaurus? TexRex Texas Impreza Club Forum -- TXIC 3 11-11-2002 11:30 AM
Does anyone know anyone who wants a Used 2.5 RS/02? ray Bay Area Impreza Club Forum -- BAIC 2 10-07-2002 03:31 AM
