Old 12-02-2006, 12:32 AM   #1
paintballjunky
Member#: 95953
2004 WRX Wagon
2013 Aprilia Shiver
Default doing it oldschool with orion
Finished my amp/sub install this week now all I need to do is carpet the box. These subs hit so much harder than the new polk momo subs and paired with the orion competition amp they sound super clean. The [older] amp is powering the speakers and the [newer] one the subs. Cleanest sounding amps I've ever heard, and each is only 25 x 2 watts The only sideback is this set-up is pretty heavy.
Current set up:
Kenwood Dpx-301, Roady XT with GLI
2 original Orion HCCA Amps
2 [early] model 10" Polk Momo subs
All wiring monster cable
Polk 6 1/2 inch components front
Polk 4 inch rear
Dynomat Xtreme all 'round
top of the box
http://i65.photobucket.com/albums/h2...3/DSC01667.jpg
front, looking through the back seat hatch
http://i65.photobucket.com/albums/h2...3/DSC01663.jpg
from the back, in the installed position
http://i65.photobucket.com/albums/h2...3/DSC01653.jpg
night shot
http://i65.photobucket.com/albums/h2...3/DSC01649.jpg
impressions?
paintballjunky is offline   Reply With Quote
Old 12-02-2006, 05:46 AM   #2
jhull
Member#: 114359
I would turn the box around towards the back of the car.
jhull is offline   Reply With Quote
Old 12-02-2006, 11:28 AM   #3
H&H Performance
Member#: 130139
mmmm....225HCCA....sweet. I don't care how old it is, any amp that can run .5ohm stable all day is the shizzz... mind you, your damping factor goes out the window, but back in the day, competition classes were wattage based, (@ the 4 ohm rating) so 2 of those amps put you in the 100 watt and under category, and done right, would produce 800 watts. oooff...
H&H Performance is offline   Reply With Quote
Old 12-02-2006, 01:52 PM   #4
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Yes, sweet amps indeed. I would probably have played around a little more with firing directions before screwing the amps to the box though.
02BlueSuperRoo is offline   Reply With Quote
Old 12-02-2006, 02:29 PM   #5
earshot
Member#: 116046
1976 Lincoln
540 rwhp
What's the model # on those polk subs? Those HCCA's need to run at .5 ohm to get full power out of them. Those polk subs need dual 1 ohm voice coils,(or quad 2 ohm), to get all the power out of those amps. It'll make a huge difference.
earshot is offline   Reply With Quote
Old 12-02-2006, 04:12 PM   #6
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
Nice amps... but for the love of god cover that box in something and dress your wiring....
Nice gear deserves a good install....
couchflambeau is offline   Reply With Quote
Old 12-02-2006, 05:29 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Gotta love the oldschool "cheater" amps. I had an Orion 2 channel for a sub back in the day. 20x2, but put out 240 RMS when bridged....great ampl
Daishi00 is offline   Reply With Quote
Old 12-02-2006, 05:42 PM   #8
H&H Performance
Member#: 130139
actually, 2 4ohm dvc subs with all the coils in parallel on a bridged 2ch makes 1ohm. and remember, bridging an amp means each channel deals with 1/2 the given load, so each channel would see .5ohms The best setup for that would be using 1 amp for the subs, and using the other for fronts/rears in parallel, with L-pads on the rears.That would give 25x4 for the fronts, of high current power, and 400w to the subs. a bit bass heavy, but still a well balanced system.
Old 12-02-2006, 10:01 PM   #9
paintballjunky
Member#: 95953
2004 WRX Wagon
2013 Aprilia Shiver
Thanks for the positive feedback on the amps !
The subs are 2 ohms and running off of one amp. I'm not sure the model number off the top of my head.
couchflambeau- As for the messy wiring and uncarpeted box, like I said it's not completely finished up, have no fear all will be neat and clean when I am done, this was just the most opportune time to take pictures. Concerning the direction, I was just experimenting with both forward facing and I will probobly stick with the rear facing it sounds a little cleaner. Additional cascade quiet-kote spray is going in the trunk soon to I'm still getting some rattle.
Old 12-02-2006, 10:18 PM   #10
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
good to hear....
Old 12-02-2006, 10:43 PM   #11
earshot
Member#: 116046
1976 Lincoln
540 rwhp
If you only want half of those amps for the subs. Any run of the mill 70 x 2 @4 ohm amp on some nice comps could keep up with 800 watts on the subs. I'd take that over using L-pads on rear speakers just to get more power out of an HCCA amp for mids & highs. personal preference i guess
The best setup
No such thing.
You are right to only run those amps at 1 ohm mono for DD purposes
Old 12-02-2006, 10:52 PM   #12
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
No such thing.
Is too... 2 Dual 12's in a bandpass box running off an Audiobahn amp (chrome flames are worth 1000 watts), fed from a Sony Xplod HU and stock speakers... Awesome
blkwrx02 is offline   Reply With Quote
Old 12-02-2006, 11:04 PM   #13
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
I remember the old cheater PPi art series... 12.5wrms x 2 for like $700 Now theres a smoking watt per dollar ratio!
Ahh those were the days
V6TurboTA is offline   Reply With Quote
Old 12-02-2006, 11:34 PM   #14
earshot
Member#: 116046
1976 Lincoln
540 rwhp
http://ampguts.realmofexcursion.com/Orion_Concept_97.3/
FTW
Old 12-02-2006, 11:52 PM   #15
1fastsubie
Member#: 74021
Awesome! I love the HCCA series amps. I ran the XTR's in high school and I loved them. Very nice job!
1fastsubie is offline   Reply With Quote
Old 12-03-2006, 12:20 PM   #16
V6TurboTA
Member#: 9090
09 Forester Gump
ROFL! .5watts!
hahahahahah
Thats mint!
And if you believe all you read here it will "Blow your speakers via underpowering them!!!"
~v6
Old 12-03-2006, 01:21 PM   #17
LathanM
Member#: 90486
2004 WRX
WR Blue
The return of the red hunter. Killer amps, brings back so many memories. Can't wait to see the final install.
LathanM is offline   Reply With Quote
Old 12-03-2006, 07:44 PM   #18
paintballjunky
Member#: 95953
2004 WRX Wagon
2013 Aprilia Shiver
Thanks again I will take pictures when it's all cleaned up/finalized. At this point I have a few options on how to complete this. Should I keep the classic look and carpet the box, hide the wires, and go from there or do something a little more custom? Feedback's greatly appreciated minus that whole dual 12's, audiobane amp, and sony xplode head unit idea
Old 12-03-2006, 08:21 PM   #19
Daishi00
Member#: 78952
2005 WRX
CGM
Go straight up oldschool my man...carpet the thing and keep the big square box ......big
Old 12-03-2006, 11:52 PM   #20
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
If you are interested, I think I still have a 3 band parametric EQ, and a 2 way crossover from Orion that work off of the phantom power. I have the phantom power din cables with them too. They would go right in the system, and provide 9 volt preamp to those amps. I used to have lots of big red amps, including a rare 425 HCCA, and 2100 Hcca running all Orion speakers back in the early 90's.
TAPOUT is offline   Reply With Quote
Old 12-04-2006, 12:23 AM   #21
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Did someone say old-school?
Wish I still had them though
-- Dave
AcquaCow is offline   Reply With Quote
Just bought an 04 STi with mods. I want to do two things... How do I do it? hotshot2109 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-08-2009 09:03 PM
Sex with the GF while she's on her period. Do you do it? STR8OUT Off-Topic 84 02-15-2006 06:50 PM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
J/W What is a datalog and how do you do it with the UTEC? waitandbleed92 Engine Management & Tuning 2 03-21-2003 10:03 AM
Rice -- Mazda's doing it, Nissan's doing it, Subaru's doing it and it's here to stay! J-Spec General Forum Archive 47 02-21-2001 07:55 AM
