Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 12-02-2006, 12:59 PM   #1
autodoodad.com
Vendor Sales Rating: (16)
Member#: 105563
Default [B]Kaixen HID Kits, High quality HID kits with 1-year replacement warranty![/B]
Hey guys,
I have KAIXEN HID Kits available for NASIOC members at a great new lower price. These are one of the highest quality HID light kits you can buy, with one of the lowest defect rates in the industry.
Here goes the basics:
What is HID?
HID (high intensity discharge) : The light is emitted from an arc discharge between two closely spaced electrodes hermetically sealed inside a small quartz glass tubular envelope capsule. To operate, they require ballasts, which supply proper voltage and control current. The amount of light produced is greater than a standard halogen bulb, while consuming less power, and more closely approximating the color temperature of natural daylight.
3 X brighter than any Halogen bulbs. Typical halogen bulbs will give you anywhere between 500 to 1000 Lumens, while consuming 55 watts or more. HID on the other hand will give you 3200 Lumens (based on 4300K) which is more than 3 times the light output of halogens.
The difference in light output is like day and night.
Whiter light: The color temperature of HID lighting more closely approximates the color temperature of natural daylight than does a halogen system, which appears yellowish in comparison.
You also have the option of getting Pure White (5000K), Crystal white (White with blue in certain angles)(6000K), Cyrstal purple (6500K), and Crystal blue. (8500K)
Consume less power. Only 35 watts of power is used.
Lasts almost 10 times longer than halogens. HID bulbs will last about 2500 hours. This means, it will last about 3 to 5 years of regular usage.
In case some of you are not aware of the KAIXEN brand, here are a few key facts:
KEY FACTS:
1. These are a 100% genuine Made in Korea brand.
2. Kaixen HID kits were first sold using Philips / Matshu****a ballasts and bulbs starting in 1999. Since then, Kaixen has recieved its own license as well as hiring several key engineers from Germany to develop its own high quality ballast / bulbs since 2002.
3. Kaixen is the only company other than Philips to develop the diamond-cut bulbs.
4. Kaixen is ISO2001 registered, E13 certified, and KQA quality assurance certified.
5. All kits are made direct in the factory, and are not "rebased" as most Philips HID kits are made.
6. Fit and finish quality is second to none.
7. Quality comparable, equal to, if not better than, OEM material.
8. Comes with 1-year full replacement warranty handled in the USA.
Competitive comparision:
1. Made in China / Taiwan products: Yes, it's cheap. But not by large margins. Although "Made in China" products have improved in recent years, most of the HID manufacturers in China are poorly managed, uses cheap labor (more risk of defects), uses cheaper raw materials (risk of defects), and fit and finish is poor compared to other Korean / Japanese / German brands. There's a reason why many of these kits (mostly sold on EBAY) are sold for around $200 or $250. It's because it costs that much less to build, many times, cutting corners in areas that shouldn't be cut.
2. OEM / Philips: Direct OEM replacements cost around $600 per one side (over $1000 for both sets). Therefore, many people go to the "next bext thing" = Philips. However, what most people don't know is that Philips do not make a variety of sizes. Philip's buyers (like Audi do not use all variations of sizes). This is why many resellers "rebase" the Philips bulbs to make it fit into sizes that are not originally made from Philips factory. There is a risk of product defect because of this modification. This is also another reason that many Philips kit's warranty is only valid from the reseller, and not from Philips head office.
As a comparision, Kaixen manufactures all sizes and colors directly from their manufacturing facility in South Korea. There is no rebasing or modification done outside of the factory, and all warranties are offered directly from Kaixen.
Here are some pictures of other cars with KAIXEN HID Kits:
More pictures found on www.kaixenkits.com
Colors available:
5000K (Crystal Natural), 6000K (Crystal White), 6500K (Crystal Purple), 8500K (Crystal Blue).
Less Kelvins (K) has better Lumens (Brightness).
More Kelvins (K) has more Color.
'02 ~ '03 WRX (Impreza) takes 9007 application:
9007 is a bixenon application bulb on a bixenon application housing.
Meaning, you do low beam to high beam using one halogen bulb by going from 55 watts to 100 watts.
Why does this matter? - well, by having bixenon application, you get two things:
1. Bulb has to be bixenon (for high beam and low beam)
2. Housing will give off more glare than other counterparts (like H1, and H7).
Fact: Kaixen only has single low beam 9007. Meaning, you will lose high beam function (which is what I have, and don't mind it much - I just honk if someone cuts me off on the road instead of high beamming.
As for glare, you can reduce it little bit by leveling the headlights.
However, projector retrofit would be best way to go for a good result.
2004 ~ 2005 WRX takes H1 application (most popular).
From the pictures I've seen so far, the Subaru WRX '04 and '05's have the best cut off line I've ever seen on an H1 housing.
Cut off is better than RSX other other H1 housing cars.
And don't worry, you guys use seperate high beam bulb, so theres no worries of losing high beam / low beam functions.
2006+ WRX takes H7 on projector lens:
Consider yourself lucky. Your car was designed for HID, and it should have HID. You're car is practically begging for it.
Cut off is as best as it can be, and results are excellent.
And yes, these are true "plug and play" kits with easy install.
Don't forget the 1-year full replacement warranty
handled by AutoDoodad here in the U.S. and backed by Kaixen!
PRICE:
$279 shipped anywhere in the U.S. & $299 shipped to Canada for single beam kits.
Kaixen replacement bulb sets are available for $89 with free shipping within the US.
Feel free to email me ([email protected]) or PM me for details.
To order, you can pay via Google Checkout at [email protected].
In stock delivery time is about 1-3 business days. We will then ship them USPS Priority Mail.
autodoodad.com is offline   Reply With Quote
Old 12-04-2006, 07:58 PM   #2
autodoodad.com
Member#: 105563
Thanks psuwrx.
Old 12-04-2006, 08:38 PM   #3
Javier
Member Sales Rating: (1)
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
can you get 1 ballast? If so, can you pm me a price... Thanks
Javier is offline   Reply With Quote
Old 12-04-2006, 09:18 PM   #4
05blkwrx
Member Sales Rating: (9)
Member#: 104954
05 wrx
black
im very interested in this but kinda short on money with the oncomming holidays how long is this gb gonna last
05blkwrx is offline   Reply With Quote
Old 12-05-2006, 10:52 AM   #5
autodoodad.com
Member#: 105563
I can get 1 ballast PM me with details on Model etc.
Old 12-05-2006, 07:41 PM   #6
autodoodad.com
Member#: 105563
PM me we can talk about your situation.
Old 12-05-2006, 08:55 PM   #7
jabba827
Member Sales Rating: (4)
Member#: 103719
2004 wrx
JBP
i'm interested in these for my 04 wrx. i heard you will need an extra 20amp blade fuse for the install and to disconnect the DRLs. do you guys know anything about this? thanks.
jabba827 is offline   Reply With Quote
Old 12-06-2006, 11:42 AM   #8
autodoodad.com
Member#: 105563
The 20 amp fuses you need come in the kit.
Old 12-06-2006, 01:09 PM   #9
Big-Sexy907
Member Sales Rating: (26)
Member#: 59057
2004 Impreza, STi.
Can you hook me up with another kit for my 99 chevy tahoe?
Bump for good guys that sold me a awesome product!
Big-Sexy907 is offline   Reply With Quote
Old 12-06-2006, 07:31 PM   #10
autodoodad.com
Member#: 105563
I need to know if they are replaceable halogen capsules or a sealed beam headlight (6054) .
Old 12-06-2006, 07:46 PM   #11
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Composite headlights with replaceable halogen capsules.
Get these things guys! The ones that I installed in my Morettes were AMAZING!
Old 12-06-2006, 11:47 PM   #12
alpnwhite96
Member Sales Rating: (2)
Member#: 115482
2006 WRX Limited
very very interested in 5000k H7
alpnwhite96 is offline   Reply With Quote
Old 12-07-2006, 01:31 AM   #13
autodoodad.com
Member#: 105563
You need a set of 9006's
Old 12-08-2006, 02:45 AM   #14
autodoodad.com
Member#: 105563
PM'ed
Old 12-08-2006, 03:06 AM   #15
Sko
Member Sales Rating: (17)
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
You mentioned 9007 as a probable retrofit, what about H4's and H3's? No problems?
Also, you guys really need a nice yellow bulb too :P
Sko is offline   Reply With Quote
Old 12-08-2006, 12:33 PM   #16
autodoodad.com
Member#: 105563
Need to know what vehicle it is on or what aftermarket headlight you have.
Old 12-08-2006, 01:48 PM   #17
Sko
Member#: 90396
2005 Legacy 2.5i
2001 RS, H4 Headlight bulb, H3 Foglight bulb
Old 12-08-2006, 03:12 PM   #18
Gfunk720
Member Sales Rating: (33)
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
So these require no modification for installation to stock 04/05 headlights?
I am interested in one of your kits, especially if they are plug and play
Any pics of kit installed on a 04/05?
Gfunk720 is offline   Reply With Quote
Old 12-08-2006, 05:41 PM   #19
autodoodad.com
Member#: 105563
If you have an H4 headlight it is no problem. The H3 foglight I can do but it is special order. Also we do have a 4000K that is a yellow color.
Old 12-08-2006, 07:28 PM   #20
autodoodad.com
Member#: 105563
It is plug & play, 04/05's need an H1 you need to pick a Kelvin (color/brightness). I do not have any pictures of the 04/05 maybe someone who has ordered in the past would be kind enough to post some photos.
Old 12-09-2006, 12:24 PM   #21
Crazy650
Member Sales Rating: (7)
Member#: 109498
05 Wrx turned STI
8500K (Crystal Blue) would like one set? price pm me thanx
Crazy650 is offline   Reply With Quote
Old 12-10-2006, 09:40 AM   #22
explosivexover
Member Sales Rating: (6)
Member#: 88906
2005 Impreza WRX
WR Blue
On the Kaixen website, there is no 4300k(oem). Can you verify that you have 4300k HID kits?
explosivexover is offline   Reply With Quote
Old 12-11-2006, 02:21 AM   #23
autodoodad.com
Member#: 105563
I know they are discontinuing the 4300K's for the H4D (dual beam) kits. I have contacted the head office and I am expecting an answer soon on what they are doing about other models of 4300K's. If they are discontinuing all the 4300K's I will find out what they are replacing them with.
Old 12-11-2006, 05:35 PM   #24
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
These are for my 1999 Tahoe correct?
When will they ship?
Old 12-11-2006, 06:29 PM   #25
SubieRon
Member Sales Rating: (28)
Member#: 64485
2004 GGA
i have an 04 wrx wagon...debating on 6000k or 8500k
SubieRon is offline   Reply With Quote
In stock! Kaixen HID Kits - highest quality HID kits for NASIOC members. autodoodad.com Exterior/Styling 428 01-27-2009 07:01 AM
[B]Kaixen HID Kits - Highest Quality HID Kits for NASIOC members.[/B] autodoodad.com MWSOC Vendor Classifieds 7 09-25-2007 12:26 AM
Kaixen HID Kits - Highest Quality HID Kits for NASIOC members. autodoodad.com MAIC Vendor Classifieds 1 07-02-2007 12:49 AM
High Quality Hid Kits!! Aerosim Research Ltd Exterior/Styling 31 10-04-2006 12:40 AM
GB: KAIXEN HID KITS for NASIOC members. High quality HID kits with solid reputation. autodoodad.com Vendor 'Group Buy' Classifieds 432 09-20-2006 11:25 PM
