#1 |
Member#: 16874
NWIC
Vehicle:2008 Audi RS 4 01 Subaru LGT Sedan |
Mine is leaking and it isn't a drain issue, it is an issue of the seal on the back edge of the glass not sealing against the car. You can see daylight through it. It has been like this forever, but before I could jockey with the switch and get it to seal. Well, it just won't seal anymore and I'm sick of it. And from my understanding there is no way to fix this short of a new piece of glass. Not spending that much money on it.
I basically never use it, so I'm considering sealing it closed and disconnecting the switch. Anyone ever do this? Jared
#2 |
Member#: 16653
NESIC
Vehicle:2012 Mazda 3 2004 Honda Pilot |
You really want to seal it up for good? Hmm...
A generic DIY would be to open it up, run a big bead of silicone sealant around the edges & contact surfaces, and then close it. Any excess that pushes out can be wiped away before it dries. |
#3 | |
Member#: 16874
NWIC
Do you have any other ideas? I really am not sold on my idea, but I don't have any others. Jared |
#4 |
Member#: 19681
RMIC
Vehicle:1998 Legacy Wagon GT Green |
You can't just get the rubber surround for the glass? Have you tried allsubaru or suburuparts or anything?
#5 |
Member#: 61907
NESIC
Vehicle:1998 2.5 GT spruce pearl |
one of my "fun" cars had a moonroof which wouldnt pass saftey tech, so i pulled the glass & motor and riveted/sealed on a thin sheet of aluminum, cut to fit, painted to match, to cover the hole. worked great. looked good.
windshield sealant works perfect. the boys at grassroots motorsports did the same to a civic i think, they might have the article online. |
#6 |
Member#: 102684
Vehicle:2013 Impreza Deep Cherry |
There's a drip tray that slides in place to keep water from leaking in along there. If you reach up into the gap that it retracts into, it's there. I'll take a picture of it in the morning when there's light.
#7 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
If you're going to be selling the car in 20 months, keep in mind that people generally aren't going to want to buy a car with a moonroof that's been ghetto sealed shut with windshield adhesive.
What about using a strip of adhesive foam rubber weatherstripping? Open the moonroof, put the weather strip either on the back edge of the glass or on the front edge of the opening in the roof, and then close the moonroof. That should work (I've used the stuff for years to seal up leaks in my Mustang's poorly designed convertible top), it would be easily reversible, and it would cost you all of $5 or less. Pat |
#8 | |
Member#: 16874
NWIC
thanks Pat. Jared |
#9 |
Member#: 16874
NWIC
#10 |
Member#: 67154
Vehicle:1997 Legacy GT/WRX White |
I very much doubt that you'd have to replace the glass. Most likely you can bring the sunroof down enough to make it seal either by removing the factory shims or adjusting the bolts that attach the whole sunroof assembly to the roof.
#11 | |
Member#: 120
AKIC
![]() Pat |
#12 |
Member#: 46456
RMIC
Vehicle:2004 WRX Wagon PSM |
#13 |
Member#: 16874
NWIC
#14 |
Member#: 17071
I have a good glass i could sell you... CHEAP!! $40 + shipping.
#15 |
Member#: 38629
NWIC
Vehicle:1999 Legacy GT (STI) White |
#16 |
Member#: 102684
Sorry it took me so long to post this:
#17 | |
Member#: 16874
NWIC
Thanks for the pic. But I think part of the problem is that I don't have the sunshade of what appears to be a drip tray in my car. It isn't there/hasn't been since I owned it. Not sure what happened... Jared |
#18 |
Member#: 102684
It wasn't there when i bought my car because it was about 3/4 of the way to the rear hatch up inside the headliner. Peek in there with a flashlight.
#19 |
Member#: 16874
NWIC
#20 |
Member#: 17071
Fyi- this weekend my old sunroof is being thrown away...so if you'd like that glass, let me know now. Also, installation and removal takes just over an hour... so its not that time consuming. I've had to do it five or so times...
| Thread Tools | |
| Display Modes | |
| Anyone need help with an install? | RubbleDTD | Mid Atlantic Impreza Club -- MAIC | 0 | 06-03-2010 05:23 AM |
| Anyone have seal leakage? | Mr Ian | Interior & Exterior Modification | 0 | 04-26-2007 03:10 PM |
| STL: Anyone have a moonroof on their WRX? | timjgx | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 04-08-2003 05:57 PM |
| Has anyone permanently removed their rear seat? | joefocker20 | Interior & Exterior Modification | 7 | 03-21-2003 05:38 PM |
