Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-02-2006, 05:42 PM   #1
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Default Another "what's that sound" thread.
I hate these threads, but I would like to ask before I start throwing parts at the problem.
Last spring a boot on my front drivers side halfshaft ripped wide open, spilling its guts all over the undercarriage. I temporarly replaced it with a used halfshaft until I could make it home to put a reman one in. By the time I moved home (a month later), I wasn't concerned with it and figured I would just wait until this used one fails before I throw the reman halfshaft in.
Four months went by and I noticed that the nut on the halfshaft either came undone slightly, or I forgot to chisel the edge of the nut into the groove in the halfshaft. I took a breaker bar to it (honestly, I was too damn lazy to dig the torque wrench out) and it seemed pretty damn tight, so I chiseled the nut into the groove and let it go at that.
Fast forward two months. I was in my manual transmission class and we were told that if that nut isn't torqued, then the bearing can fail. Conveniently, a week later, I started hearing a metal rubbing metal noise from the front, sounds like the drivers side. I've been driving it with the noise for a month and its getting progressively louder and more sensitive to the steering wheel (more on that in a second). Currently, its a whining sort of noise at lower (5-40mph) and moves to a knocking sound at higher speeds. I finally replaced the halfshaft the other day (in the pouring rain ), and when I did, I took a look at the bearing and it was sill greased but thats all I could see.
When does it make the knocking sound? Any hint of the steering wheel to the right. Even just a slight nudge and it starts making the noise. Its in direct proportion to vehicle speed, but doesnt matter what gear I'm in, if at all, even going in reverse.
I would also like to note that I made two 6" creek crossings at a trip to Wellsboro, PA before the sound started.
Anyways, I am assuming its a wheel bearing, but it's going to cost me $50 to replace that, with new seals. I just wanted to run that by you guys, in case I'm wrong with the diagnosis.
Thanks for any help
-Shaun
C/N - Knocking sound, direct propprtion to vehicle speed regardless of gear or forward/reverse. Happens with even a slight turn to the right. Wheel bearing?
t3hWIT is offline   Reply With Quote
Another "Name That Spider" Thread... clucania Off-Topic 15 10-04-2007 12:14 PM
OT Photo peeps: another "What's this **** called" Thread BhamRoadrunner Off-Topic 11 05-21-2007 02:25 PM
Yep, another "Name That Noise" thread thejean Built Motor Discussion 29 02-24-2007 07:02 PM
yet another "what's that song" thread music4robots Mid West Subaru Owners Club Forum -- MWSOC 2 11-28-2005 08:38 AM
Another "name that wheel" thread.... sorry, but I just gotta know! WFOchris Brakes, Steering & Suspension 10 02-20-2003 09:42 PM
