Old 12-03-2006, 11:54 AM   #1
06BluePearl
Member#: 129609
06 FP Green w/Meth
425hp 445tq
Subaru Stars header, up pipe, and down pipe
to all, i just put a header, and up pipe on my 06 wrx. the header is not an equal length header. when i installed it everything went good. when i drive it it sounds like i have a exhaust leak. but i checked it 3 times on the lift. i felt no leeaks, i heard no leaks. i hade a friend put a rag on my muffler to make back pressure. and still no leaks. now i installed it on friday. now 3 months ago i installed my invida down pipe no cat, divorced. and it also soundid like an exhaust leak, but again nothing to be found. now im thinking that if i were to rap the down pipe that it will get rid of this. but i could be wrong. please write back with some info. the mods i have if this will help but i dont think that it will are
1.cobb ap
2.e bay top mount
3.aps blowoff valve
4.aps short ram
5.boost controller set to 16psi
6.header
7.up pipe
8.invida down pipe cat less
9.invida cat back no resinator or cat
10. turbo in let pipe
again thanks for your help
06BluePearl is offline   Reply With Quote
Old 12-03-2006, 12:25 PM   #2
FraudulentNeon
Member#: 29108
2002 Impreza WRX
Have you ever modified the exhaust on a turbo car before? Are you aware of the different noises the car will make?
FraudulentNeon is offline   Reply With Quote
Old 12-03-2006, 12:32 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
there is a torque sequence for header/exhaust manifold.
and up-pipe..i suggest that you go and get new up-pipe
down pipe gaskets and torque to specs..
Old 12-03-2006, 12:35 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
1.cobb ap
2.e bay top mount
3.aps blowoff valve
4.aps short ram
6.header
7.up pipe
dear GOD......d000d....if it isn't blown up already it will be soon
ya MUST have engine management of these cars or they will blow up.
EDIT....and a 'boost controller' kills yer AP's control of boost
....SO MANY kiddies.....SO MANY nice kars to kill
Old 12-03-2006, 12:47 PM   #5
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Did you miss #1?
RP31 is offline   Reply With Quote
Old 12-03-2006, 12:49 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by RP31 View Post
Did you miss #1?
...can you say 'stupid'????
proper EM controls boost........any 'boost controller' 'un-does' that.
can you say PTFB????
can you say 'POP' goes the motor????
Old 12-03-2006, 12:50 PM   #7
RP31
Member#: 123574
CGM STi
I wasn't saying what he did was smart or right. Just pointing out your telling him he needed EM, when he already has it.
Old 12-03-2006, 01:27 PM   #8
06BluePearl
Member#: 129609
06 FP Green w/Meth
425hp 445tq
yes i have torqued the bolts to the proper torque. and yes i have worked on turbo cars before. and for the boost controller i have talked to cobb at sema in vegas and also on there tech notes for stage 2, i says that fuel cut is at 17.8 psi and that the boost is raised to 15.5. also i spoke to them about putting a boost controller and they said as long as i put a resistor in the plug that there will be nothing wrong with that. and plus if i write that i have cobb ap that means i have em. and no i didnt miss 1. also after wrote this i went and checked my car out again. and i found that one of the bolts for the up-pipe are loss. so its my fault for putting this thread up but dont go and put people down on **** that even you dont know the answer to. so thanks for info guys you been a reall big help
Old 12-03-2006, 03:16 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You are getting crap because you have the three evils of Subaru on your car which are a MBC, BOV, and intake. I can guarantee that even the guy that sweeps the floors at COBB Tuning would tell you that your combination is bad ju-ju. While you posted a simple leak question, we are here to warn you that what you are doing is NOT KOSHER and that WHEN you pop your motor, you have been warned. You need a protune quick, as in today or tomorrow.
FS: EL Header, Up-Pipe and Down Pipe ImpreziveWRX Engine/Power/Exhaust 2 12-25-2007 02:02 AM
stock WRX up pipe and down pipe, intercooler, and more...gota go! IllNastyImpreza Engine/Power/Exhaust 0 08-04-2006 11:53 PM
up-pipe and down-pipe with stock 3rd cat and cat-back=LOUD? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-12-2004 08:51 AM
Self-Install time of Up-pipe and Down-pipe?? commandoe99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-03-2002 11:58 AM
UP PIPE and DOWN PIPE atcvader Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-17-2001 12:05 PM
