Old 12-03-2006, 02:38 PM   #1
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Default Hvac
anyone know where i can get the hvac bulbs other than the dealership?? I can get them from the dealer but ive got it all taken apart and was looking for somewhere to get the bulbs so i dont have to wait until tomorrow. Any ideas?
Thanks!
legacy1907 is offline   Reply With Quote
Old 12-03-2006, 03:05 PM   #2
chahny
Member#: 42750
1995 Legacy Outback
Now 25% more Blue!
http://www.scoobymods.com/forums/showthread.php?t=91
clif's notes version, Radio Shack bulb #7219, catalog number 272-1092.
chahny is offline   Reply With Quote
Old 12-03-2006, 03:22 PM   #3
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
thanks a lot
Old 12-03-2006, 03:24 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It's usually not the bulbs, but the connections. Give them a wiggle before you spend $$.
Wiscon_Mark is offline   Reply With Quote
Old 12-03-2006, 07:53 PM   #5
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
has anyone changed their bulbs before? Did you find putting the circlip back on around the wire controlling the temperature to be a major PITA??
Old 12-03-2006, 08:46 PM   #6
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
^ Yes! I replaced them in my car! IT was a PITA!
dplacen is online now   Reply With Quote
Old 12-03-2006, 09:27 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
try breaking it first. That's even worse.
It's not that bad, honestly. But you can break stuff easily and send it spinning down into hard to fix.
Old 12-03-2006, 11:57 PM   #8
chahny
Member#: 42750
1995 Legacy Outback
Now 25% more Blue!
PITA fo sho!
Old 12-04-2006, 12:13 PM   #9
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
This isn't too bad, but be prepared to curse those little E clips that hold the mechanical-temperature-wire-thingie onto the HVAC module. They're very easy to lose, so if you do then Lowe's should have replacement E clips. I lost one of mine over the summer, but it was okay as long as I didn't move the temp from Cold (why would I during summer?).
Went to Lowe's when it started to get cold out, got some more E-clips, and before pulling the module out, I vacuumed. Guess what my vacuum picked up? Yep, the lost e-clip. After much cursing, I got the damn thing back on and all is well again. yay for working HVAC bulbs!
GTWagon_Phreak is offline   Reply With Quote
Old 12-04-2006, 12:53 PM   #10
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i lost one of my clips so im going go head over to lowe's or home depot or something to look for more
Old 12-04-2006, 12:56 PM   #11
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Lowe's in Cary has them for sure, where I got mine.
Old 12-04-2006, 02:04 PM   #12
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
where is the lowes in cary?? is it over there by cross roads?? i know theres a home depot up there for sure but im not sure about the lowes
Old 12-04-2006, 02:36 PM   #13
skunkfifty
Member#: 73102
1998 legacy outback
white
to avoid the E-clip problem disconnect the cable from the passegners foot well instead. it's pretty easy to do.
skunkfifty is offline   Reply With Quote
Old 12-04-2006, 02:45 PM   #14
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
so by doing this I can take the whole cable out?? cause that would make it easier to get the clips back on.
Old 12-04-2006, 03:20 PM   #15
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Be interested to know where this is as well
And yes, the one at Crossroads. Head up the beltline, take the Cary Crossroads exit, hand a left on walnut st and it is a couple lights down on the right, can't miss it.
Old 12-04-2006, 05:00 PM   #16
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
finally got my E-clips and bolted it all back together. Just hope those E-clips wont fall off cause that would be an even bigger PITA!
Old 12-04-2006, 05:12 PM   #17
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Okay, look under the glovebox. There'll be a space along the left side of the heater manifold. There's a cable that connects to a switch, that's the one that's connected to the HVAC controls.
Old 12-04-2006, 10:25 PM   #18
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
i would get them at the local junkyard, just remember to bring the right tools with you and just put what u need in your pocket (small stuff only obviously)
bugeye829 is offline   Reply With Quote
Old 12-04-2006, 10:34 PM   #19
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
I got mine new from SubaruGenuineParts.com for under $10 shipped I believe, but I ordered some oil filters and stuff at the same time.
HVAC blower Tar--Mac Private 'Wanted' Classifieds 4 06-06-2010 08:15 PM
If you need new HVAC -- now's not a bad time to buy jpicheva Off-Topic 32 06-04-2010 10:06 AM
02 HVAC swapped with 05+ auto HVAC Loomin Interior & Exterior Modification 14 01-04-2009 03:22 AM
WRX Dash, Bar, HVAC Controls, HVAC ducting, Console, Glovebox, Silver Trim - $400 gedwrx Interior/Dressup/Audio & Security 7 03-18-2007 05:33 PM
