Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 12-04-2006, 08:18 AM   #1
NYCshopper
Member#: 5126
Default Volkswagen CrossTouran @ 2006 Bologna Motor Show
VW Press Release:
Right before the turn of the year Volkswagen is presenting another member of the “Cross” family at the 30th Bologna Motor Show. The CrossTouran. After the start of the CrossPolo and the CrossGolf the crossover model of the successful compact van now complements the range of options. The new CrossTouran meets the demands for driving fun, a high level of product quality and an attractive price-performance ratio.
EXTERIOR
Robust bumpers, wheel arches and side trim and more ground clearance
On the exterior numerous modifications distinguish the CrossTouran from the classical Touran design. The interplay of all body elements visible from the outside is particularly noticeable. The silver anodized roof railing with black mount harmonizes with the “matte chrome” look of the new front spoiler. The central air inlet in the front spoiler was also given a border in “matte chrome” look. All other body features of the all-around protection (bumper lower sections, side running boards, wheel arches, side protective trim) consist of robust, high-quality black-grained carbon fiber. The CrossTouran has lettering directly above the side trims. The wing mirror casings and the hatchback handle are painted to match the body color.
Fresh body colors available for the CrossTouran provide a harmonious contrast to the applications. The color palette ranges from “Candy White” to “Deep Black”. The color “Red Rock” in particular underscores the unique character of the CrossTouran: It is a flexible all-rounder that conceptually shows true can-do qualities and at the same time makes a very positive statement about life.
One look at the silhouette also distinguishes the CrossTouran as a unique model. The mixed tire arrangement with 6.5-inch wide and 17-inch diameter alloy wheels on 215/50 tires in front and, in particular, the 8-inch wide alloy wheels on 235/45 tires in back underscore the road holding of the CrossTouran and competently fill out the wheel arches enclosed by the robust extensions. The extensions merge with the side running boards, which extend up into the doors and give the car an extremely solid and powerful character.
In order to gain the extra 12 millimeters of ground clearance the CrossTouran was equipped with a modified version of the rough-track chassis that is optional for this series: it also includes a longer suspension system. The silver anodized roof railing with black mount was however not included as a component of standard equipment for visual reasons only. It is in fact a classic way to anchor the mounting system and roof boxes. The maximum permissible load is 100 kilograms.
INTERIOR / LUGGAGE COMPARTMENT
A colorful design specially developed for the CrossTouran, and great functionality make everyday driving easier
With its functional design and especially with the “Orange/Grey” interior colors, the inside of the CrossTouran imparts a youthful and pleasant atmosphere. In particular, in conjunction with the exterior “Red Rock” color this orange-grey combination has a special charm. For those who prefer to be a bit less ostentatious the “Latte Macchiato” color scheme is the fitting counterpart.
The practical individual seating system of the CrossTouran shows the way in terms of versatility. The three lightweight seats arranged next to one another in the second row can be quickly and easily moved – lengthwise and offset diagonally, folded down or removed. The CrossTouran can be optionally equipped with a third row of seats; if desired, the two full-fledged individual seats can each be easily lowered separately into the luggage compartment floor.
In terms of utilization, the CrossTouran is also extremely flexible when it comes to transporting luggage. In its basic configuration the luggage compartment is 695 liters. When necessary maximum storage volume can be expanded to 1,989 liters by removing the second row of seats and lowering the third row into the luggage compartment floor. Even bulky items or recreational equipment for the weekend pose no problem for the CrossTouran.
SAFETY
High stability passenger compartment and standard front, side and head airbags
The laser-welded and, thanks to high tensile steel, especially rigid Touran body offers a high level of passive safety. The extensive standard safety equipment consisting of safety-optimized headrests in front and on the outer seats of the second row, driver and passenger airbag, side airbags in the front backrests and a head airbag system for the first and second row of seats in conjunction with three-point safety belts on all seats provide optimal occupant protection.
A high level of active safety is provided by the ESP electronic stabilization program including counter-steering feature and trailer stabilization as well as speed-regulated electro-mechanical power steering.
ENGINES / TRANSMISSIONS
Gasoline engines
CrossTouran 1.6 with 75 kW / 102 hp
The entry level is represented by the “smallest” Touran four-cylinder engine with 1.6 liters of engine space and an output of 75 kW / 102 hp. With the basic engine and five-speed manual transmission the CrossTouran is already 176 km/h fast and accelerates from 0 to 100 km/h in 13.3 seconds. Fuel consumption is limited to 8.3 liters over 100 kilometers.
CrossTouran 1.4 TSI with 103 kW / 140 hp
The “small” Twincharger TSI deserves special attention. Thanks to twin charging via compressor and turbocharger it features an extremely high-torque and agile characteristic. Nevertheless, the engine is extraordinarily thrifty with 7.6 liters of fuel consumption over a distance of 100 kilometers. For those who like it extremely comfortable, the CrossTouran with this engine type can also be ordered with a DSG (direct shift gearbox).
CrossTouran 1.4 TSI with 125 kW / 170 hp
The most powerful direct injection gasoline engine has a sporty temperament and will be used for the first time in the CrossTouran. The gears of the Twincharger with 125 kW / 170 hp will be changed with a DSG direct shift gearbox as part of standard equipment. It also convinces with low fuel consumption with an overall average of 7.8 liters over 100 kilometers. With this engine the CrossTouran has a top speed of 208 km/h and accelerates to 100 km/h in just 8.7 seconds.
Diesel engines
CrossTouran 1.9 TDI with 77 kW / 105 hp
The 1.9 TDI with pump-jet direct injection technology and turbocharger has a standard six-gear transmission, but can also be combined with the innovative DSG direct shift gearbox. The engine accelerates from zero to 100 km/h in 13.8 seconds and reaches a top speed of 176 km/h (DSG: 174 km/h). With average fuel consumption of only 6.2 (DSG: 6.5) liters for 100 km it is also extra thrifty.
CrossTouran 2.0 TDI with 103 kW / 140 hp
The pump-jet four-cylinder direct injection of the 2.0 TDI attains a full 320 Nm of torque. In combination with the standard six-gear transmission it has a top speed of 196 km/h. The 140 hp TDI can be optionally equipped with direct shift gearbox. As a TDI DSG Germany’s most popular compact van goes 194 km/h. It has average fuel consumption of only 6.2 (DSG: 6.8) liters over 100 km.
CrossTouran 2.0 TDI with 125 kW / 170 hp
The second 2.0 TDI provides superior driving performance: The engine is equipped with a highly innovative Piezo pump-jet high-pressure unit-injector system and two balancer shafts. This very quiet four-valve TDI has an output of 125 kW / 170 hp (4,200 rpm), developing torque of 350 Nm (1,750 to 2.500 rpm) and accelerating the CrossTouran to 100 km/h in only 9.2 seconds. Top speed is 210 km/h (208 km/h with DSG). Here too average fuel consumption is only 7 liters over 100 kilometers.
NYCshopper is offline   Reply With Quote
Old 12-04-2006, 03:57 PM   #2
ktzdaddy
Member#: 125975
i would drive that wagon.
ktzdaddy is offline   Reply With Quote
Old 12-04-2006, 05:08 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I like it. Its like a better looking Element with ground clearance.
