Old 12-04-2006, 12:53 PM   #1
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
Default so I guess I need some sort of boost control for te 35r :D
What are my other rotated brothrens running. My tuner "Jetfan" and I are lurking for a controler. Any suggestions? I don't need anything fancy either.
03twrx is offline   Reply With Quote
Old 12-04-2006, 12:57 PM   #2
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
TXS Manual. HPBC (High Performance Boost Controller)
Your tooner couldnt make a suggestion???
ShaggyGT is offline   Reply With Quote
Old 12-04-2006, 01:06 PM   #3
03twrx
Member#: 73737
I know right. Nino out of suggestions. Actually, He's looking into it. All I can say is he's awsome with a freakin Utec. Watching him tune is like watching my brother play CSS.
Old 12-04-2006, 01:24 PM   #4
InfamousDX
Member#: 25413
Hallman.
Old 12-04-2006, 01:36 PM   #5
xsblack
Member#: 26530
2004 Sti
JBP
Cool boost control
Forge unos manual BC, or the Dtec if you have $
xsblack is offline   Reply With Quote
Old 12-04-2006, 07:36 PM   #6
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Thats what I suggested
Someone must have forgot
jetfan8178 is offline   Reply With Quote
Old 12-04-2006, 08:02 PM   #7
TheMadScientist
Member#: 23717
2005 Big red
Stock ecu with a GM BCS.
TMS
TheMadScientist is offline   Reply With Quote
Old 12-04-2006, 08:21 PM   #8
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
TMS
yes or a avcr
Paintballguy is offline   Reply With Quote
Old 12-04-2006, 09:00 PM   #9
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
AVCR costs what, 10 times more than the GM BCS?
nhluhr is offline   Reply With Quote
Old 12-04-2006, 09:09 PM   #10
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Hallman MBC.. Out of all the 35r cars I have tuned its what I use 90% of the time. The other times Blitz DSBC... Thats usually for the cars that want multiple maps pump, pump/meth, race, race meth... I have had 0 problems with either the MBC or EBC... with the EBC I was able to hold 38psi to redline...
Junior2JZ is offline   Reply With Quote
Old 12-04-2006, 11:14 PM   #11
gpatmac
Member#: 18446
2002 WRX wagon
psm
How about something a little over $3?
link
gpatmac is offline   Reply With Quote
Old 12-04-2006, 11:49 PM   #12
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
link
When the utility spring binds up... = Priceless...
Old 12-05-2006, 12:32 AM   #13
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Whats your "tuner" suggest and or feel comfertable tuneing with?
DoctorNick is offline   Reply With Quote
Old 12-05-2006, 02:04 AM   #14
03twrx
Member#: 73737
That's why I'm asking. We werent to sure what to go with for the EWG. He's used to internal gates. I kinda like the Hallman because if I want, I can install an incar adjuster.
Old 12-05-2006, 02:59 AM   #15
gpatmac
Member#: 18446
2002 WRX wagon
psm
I defer to your experience, but isn't there something you could do when putting it together to ensure that doesn't happen?
Old 12-05-2006, 06:00 AM   #16
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
The forge includes that option for less money than the hallman. Any ebc would be fine, but the forge is more cost effective, better looking, better quality IMHO and wasy to use.
Although I am researching this GM solenoid idea...
Old 12-05-2006, 06:44 AM   #17
TheMadScientist
Member#: 23717
2005 Big red
You could also do the hybird GM/MBC setup that ride5000 uses. It is a very nice setup has the advantages of both with no drawbacks.
TMS
Old 12-05-2006, 07:31 AM   #18
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
TMS
Well, I have managed to tune a few cars using just the utec and factory solenoid with no ABC before and had great success. This being with much smaller turbos though. It would be interesting to see how well the GM one would work.
Ill have to get my hands on one and try it in my car first although right now my car wont dip below 18psi with the forge actuator anyway so I may bhave to switch to the stock actuator first.
Old 12-05-2006, 08:09 AM   #19
TheMadScientist
Member#: 23717
2005 Big red
You can leave the forge actuator in but that will be your min boost setting. Adding the GM will allow you to go higher and hold the boost out longer.
TMS
Old 12-05-2006, 09:26 AM   #20
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Oh, I realize that. i was just thinking for a fair comparison test going stock actuator would give me more a more acurate comparison to the factory+abc option the utec typically uses.
I already know for a fact the actuator solve the boost loss and boost creep problems on my sti. Now I just want to reduce the amount of vacuum plumbing and bs under the hood. This sounds like a way of doing that.
Old 12-05-2006, 11:51 AM   #21
03twrx
Member#: 73737
Well let me know, I'm currently the highest bidder for the Hallman Pro at a whopping $37.50
Old 12-05-2006, 06:24 PM   #22
03twrx
Member#: 73737
Hallman BC pro on the way!
Old 12-06-2006, 12:03 AM   #23
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
AEM Makes a really nice boost solenoid.... Even comes with AN Fittings...
I have ran both the AEM and GM BCS the GM IS CRAP IMO...
Yes its more expensive but please dont say its a waste of money unless you have actually had one to compare to a GM unit.
http://www.aempower.com/ViewProduct.aspx?ProductID=23
snwman is offline   Reply With Quote
Old 12-06-2006, 07:33 AM   #24
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Ultimatly for me the appeal is the possibility of reducing components under the hood, or reducing them for that matter. The factory ECU is conjunction with a utec can do a good job of controlling boost, the weak point is the solenoid. Cure that and I expect you have a winner.
The aem looks like a EBC component, not like something I would try wiring into my factory system.
Old 12-06-2006, 07:37 AM   #25
03twrx
Member#: 73737
I didn't like the AEM one either. I just ordered the Hallman MBC nino. Hope you'll enjoy it!
How to come up with some sort of objective measure for "ride quality"? Butt Dyno Brakes, Steering & Suspension 19 06-24-2007 11:40 PM
WTB Some sort of performance springs for my STI!~~ daltrum83 TXIC Private Classifieds 1 02-17-2007 03:48 PM
Need some help with boost control 505zoom Newbies & FAQs 14 07-19-2006 09:37 PM
And here I thought this was some sort of elaborate setup for an April Fools Joke... dr_wheel Off-Topic 18 11-18-2005 02:12 AM
I need some ideas..Apexi Boost control Matty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-06-2002 12:14 AM
