Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-17-2001, 12:06 AM   #1
mikesoob7
Member#: 2500
Default Engine Power - Compression?
Hi,
I've got 175K on my subie, I expect there to be a bit of power loss at that mileage but just would like to know if a compression test is a fairly accurate measure of the origional performance. I am not able to do a leak-down test and I realize this is part of the diagnostics. I just want to know if compression is a fairly accurate measure of engine performance.
Mike
mikesoob7 is offline   Reply With Quote
Old 11-17-2001, 12:36 AM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
it's somewhat usefull if compared cylinder to cylinder. You don't want more than 10% difference maximum variation from highest to lowest. For example if your highest cyl is 150psi, lowest should be no less than 135 psi. (don't take these numbers seriously, I just picked some out of my head that were easy to use). However, if all cylinders measure 10 psi, thats bad (low compression) even though they are all even. A leak down test is better. If you know how much compression your engine made when new or fairly new, you can compare that to now, and see how much you have lost.
yamarocket630 is offline   Reply With Quote
Engine Misfire! Compression Results! em199si Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-02-2007 01:30 PM
xs engineering power intake system bcristea Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-04-2002 03:56 PM
XS engineering power intake MONGster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-30-2001 11:39 AM
Cold engine power trick HRE | giulio Normally Aspirated with bolt-on Forced Induction Powertrain 41 12-12-2001 05:04 AM
