Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 12-05-2006, 12:21 PM   #1
Turbochargers.com
Vendor Sales Rating: (0)
Member#: 133601
Default Turbochargers.com Bolt on Subaru Big turbos!
Hello Nasioc Club members! As this is our first sales post on Nasioc we decided to have a blow out sale. Turbochargers.com is the original maker of the Frankenstien turbos that where very popular for DSMs. We have a full line of turbos for Subaru:
All of these turbos are new and made to order onsite in our shop. All bolt on to 02-07 turbocharged subarus.
Frank 50 50 trim compressor, 7cm housing 450 hp = $1199
Frank 50 50 Trim, 8cm housing 500 hp = $1199
EVo3 16G = $599
18G 7cm = $699
18G 8cm = $699
20G 7cm = $899
20G 8cm = $999
Frank 35R 8cm. You want the biggest and the baddest? Try a GT35R compressor on an 8cm housing with 6H exhaust weel! -600hp! $1299
5410 burr oak
Houston, TX
77092
713-681-1111 office
800-749-7111 order line
713-939-1111 fax
AND ALL THESE TURBO'S ARE OFFERED WITH FREE GROUND SHIPPING IN THE US!
Tommy
Turbochargers.com is offline   Reply With Quote
Old 12-05-2006, 05:50 PM   #2
Dynasty336
Member#: 103561
2006 STi
I take it you decided the prices you posted to begin with were too low?
Dynasty336 is offline   Reply With Quote
Old 12-05-2006, 06:36 PM   #3
Turbochargers.com
Member#: 133601
it was a mis print!
my error
tommy
Old 12-05-2006, 07:33 PM   #4
funktrain
Member Sales Rating: (3)
Member#: 65145
2005 STi
World Rally Blue
Coolant and/or Oil lines included?
funktrain is offline   Reply With Quote
Old 12-05-2006, 07:49 PM   #5
Dynasty336
Member#: 103561
2006 STi
Lol you changed them again! but im not complaining i like the price of that 8CM 20G again. But will probably go with your Frank50. EWG configuration available?
Old 12-05-2006, 09:01 PM   #6
Paintballguy
Member Sales Rating: (10)
Member#: 77810
2006 Evo IX SE
Tarmac Black
What size is the inlet for the frank 50 trim? I'm very interested in swapping out my 20g for one and doing a ewg setup.
Paintballguy is offline   Reply With Quote
Old 12-05-2006, 09:19 PM   #7
Dynasty336
Member#: 103561
2006 STi
I emailed them the other day. I was told the Frank50 is a 2.4 inlet.
Old 12-05-2006, 09:20 PM   #8
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
sweet...
next question is if I can have one sent to me already setup for an EWG.
50 trim with a 8cm exhaust housing would be siiick. I could definitely see mid 11's in my car on c16 if I'm almost breaking 11's on my 20g on meth.
Old 12-05-2006, 09:42 PM   #9
Dynasty336
Member#: 103561
2006 STi
^^^ what he said. I want to know if it can get send with EWG config too! BTW hey paintballguy how much was your meth kit and was it hard to install?
Old 12-05-2006, 09:54 PM   #10
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
well you dont necessarily need the kit, I just want them to weld the IWG shut. I can get a 38mm tial ewg for ~200 bucks and then get a uppipe made for the 38mm.
I paid like 450 for my kit with the spec c tank. I had agile install it because I was afraid to screw something up.
Old 12-06-2006, 09:31 AM   #11
Big_Hitter
Member Sales Rating: (7)
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
bump
Tommy, pls pm me when I can come pick up my 18g
thanks - Jeff
Big_Hitter is offline   Reply With Quote
Old 12-06-2006, 04:26 PM   #12
Turbochargers.com
Member#: 133601
Originally Posted by Philistine View Post
bump
thanks - Jeff
you got a PM!
it is ready!
tommy
Old 12-06-2006, 04:48 PM   #13
kn0bby8
Member#: 97644
2006 WRX
How much cfm does each turbo flow?
Specifically the 8cm 18g, 7cm 20g, 8cm 20g, and 8cm frank 50.
kn0bby8 is offline   Reply With Quote
Old 12-06-2006, 05:50 PM   #14
Turbochargers.com
Member#: 133601
these realistic CFM numbers for each compressor wheel!
EVO 3 = 550 cfm
Big 16G = 550 cfm
18G = 600 cfm
20G = 650 cfm
50 trim = 700 cfm
60 trim = 800 cfm
GT35R = 900 cfm
HT 61 = 1000 cfm but not yet tested but will be soon as we have them on the way from turbonetics as we speak!!!!
the difference between the 7CM and 8CM in spool up is about 300-500 RPMS!
hope this answers the question!
thanks
tommy
Old 12-06-2006, 06:03 PM   #15
subaru222
Member Sales Rating: (66)
Member#: 92967
2009 wrx hatch
dark grey metallic
Any kind of warrenty..also is the 20g td05 or td06
subaru222 is offline   Reply With Quote
Old 12-06-2006, 06:38 PM   #16
Turbochargers.com
Member#: 133601
you get a 1 year no fault warranty!!!!
unless you requested different our 20G come with TD06H TW and and 8CM housing!
thanks
tommy!
Old 12-06-2006, 06:58 PM   #17
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Ok so the 7cm is a tdo5 ...or td06 and just to double ceck before i buy it come with oil line and banjo
Old 12-06-2006, 07:17 PM   #18
Turbochargers.com
Member#: 133601
both the 7CM and 8CM housing can use the TD05H wheel but the 8CM housing is the only one that can use the TD06H wheel!
and it is the best bang for the buck unless you just want the TD05H turbine wheel!
yes all our turbo's come with water lines and a drain tube unless you order them without!
thanks
tommy
Old 12-06-2006, 10:07 PM   #19
tundra
Member Sales Rating: (20)
Member#: 9290
02 Built 2.5L wrx
As asked above, do you offer a turbo with the wastegate welded shut for EWG setups?
tundra is offline   Reply With Quote
Old 12-06-2006, 10:55 PM   #20
Paintballguy
Member#: 77810
2006 Evo IX SE
Tarmac Black
yes they do
Old 12-07-2006, 06:42 AM   #21
TitaniumForge
Member#: 96081
TOMMY
I would like to keep my TMIC. Is the 18/20g or even Frank 50 50 trim with 8cm would be ok with STI TMIC? If not what would be the largest I can use with the STI TMIC.
TitaniumForge is offline   Reply With Quote
Old 12-07-2006, 08:22 AM   #22
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Originally Posted by TeamTurbo View Post
you got a PM!
it is ready!
tommy
schweet - see you in a few
Old 12-07-2006, 11:06 AM   #23
jim1969
Member#: 34877
2005 Legacy GT sedan
you guys planning on making a Legacy GT specific turbo to replace the VF40?
jim1969 is offline   Reply With Quote
Old 12-07-2006, 11:26 AM   #24
Turbochargers.com
Member#: 133601
Originally Posted by TitaniumForge View Post
TOMMY
yes they do clear with the TMIC!
now not sure about the 3" cover but i dont know to many people that are using the Frank 60 and Frank 35R that are not already running the FMIC!
on another note:
Philistine good luck and happy turboing and if you have any questions or need anything dont hesitate to give me a shout!
thanks
tommy
Old 12-07-2006, 11:27 AM   #25
Turbochargers.com
Member#: 133601
we have been approached several times about it but nothing as of yet!
Bolt-on 35r sized Turbo - $1050 Fongers SCIC Private Classifieds 6 02-22-2009 01:06 AM
Bolt-on 35r sized Turbo - $1100 shipped Fongers Engine/Power/Exhaust 6 02-21-2009 09:51 PM
Bolt on GT Series Turbos ? SideWay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-21-2008 06:36 PM
1 bar Wastegate Actuator for big bolt-on, internally gated turbos. dug-e-fresh Engine/Power/Exhaust 8 03-31-2008 09:19 PM
Big bolt on stock TMIC turbo for 05 STi?? WrxRick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 08-06-2007 05:23 PM
